Question about York Tools & Hardware - Others
Reset high limit switch - York Tools & Hardware - Others
  • 827 Answers
Reset what high limit ? you need to give more information as to what this is for
Posted on Nov 24, 2013
Igniter isnt lighting
IF YOU LOST POWER WHEN FURNACE WAS RUNNING IT TRIPPED ROLLOUT SWITCHES AND POSSIBLY THE HIGH LIMIT . IN CENTER OF ROLLOUT SWITCHES IS A LITTLE RED BUTTON THAT YOU RESET . YOU CAN ALSO TRY FINDING HIGH LIMIT WITH POWER SHUT OFF TO FURNACE PULL BOTH WIRES OFF HIGH LIMIT AND USE PAPER CLIP TO JUMP BETWEEN THE TWO WIRES MAKE SURE YOU DONT SHORT OUT AGAINST ANY METAL WHEN YOU TURN BACK ON IF IT WORKS YOU NEED A NEW HIGH LIMIT SWITCH.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
High limit switch gas hot water giant
Tank-type Gas water heater: high limit can the FV system, the ECO-TCO reset located on front of combustion chamber, or the one-time-use ECO located in the gas control valve thermostat probe.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/images/Whirlpool-Resettable-ECO-20.jpg
http://waterheatertimer.org/images/Gas-valve-ECO-124.jpg
Tank-type electric water heater has a reset button:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Other types: Tankless, indirect, boiler, solar assisted, hybrid, etc, please refer to product manual or add comment and describe the product in detail
Apr 07, 2013 | Water Heaters
Reset hi limit switch
there might be a resettable one in the top if you take it off if not replace fusible link if bad if ok replace the hi limits under where the plumbing goes in
Mar 20, 2012 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Furnace quit working after power outage
Check the high limit switch and reset it... the latent heat in there trips the high limit...
The high limit is usually near the blower compartment and has a little red button in the center that you need to push back in to reset it...
heatman101
Dec 14, 2010 | Heating & Cooling
Can not get fryer to turn on. when you flip the switch to the on position, the high limit light flashes and go back off emediatly, and no power comes back on. i can here a click in the board behind the...
The High Limit is a self resetting thermostat that acually works like an oven control. If the fryer is too hot it will cut off the gas burner valve voltage:
OEM PN is 00-854453
Original PN VUL854453
Source 1
http://www.3wire.com/webstore/parts/PartSearchResults.aspx?searchText=Switch+High+Limit&mfrCode=VULCAN
$98.50
Source 2 Must log in.. new account
http://www.a1service.com/vulcan/vulcanlimit.htm
$90.20
The 854453 number comes up often in the part search for the high limit.
The high limit contacts can be checked and reading the NO and NC terminals. This control / switch is normally closed until opened by heat at 450 Deg F.
Thanks for Choosing FixYa,
Kelly
Sep 28, 2010 | Vulcan GRD45 Deep Fryer
I have a dyno glo rmc-fa100dlx forced air heater. It will light and work for a few minutes, up to about 5, then it will stop heating and the fan will keep blowing. any ideas? thanks!
If the unit comes on and runs but then shuts down, that sounds like an indication of a high limit trip.
Most, if not all, furnaces have high limit switches that keep a constant check on the temp inside the furnace or air handler. On most systems, once this high limit switch has been made (got to hot), the limit switch breaks control voltage to the heating device (strips, gas, fuel, etc.etc..). The blower motor continues to run until the high limit has dropped in temp and reset itself.
On some models, the high limit is a manual reset, meaning you need to reset the switch yourself or shut the unit off and then back on to reset it.
Check all filters and replace as necessary. Check the coils and fan blades for dirt build-up and cleanliness. Check motor belt (if applicable). If all these fail to solve the problem, then your issue either lies within the blower motor itself not moving enough air for proper heat transfer. Or the high limit switch itself is failing.
Jan 09, 2010 | Heating & Cooling
Where is the high limit switch and how does one reset it?
the high limit switch is on the duct exhaust
and unfortunately it cannot be reset
need to be replaced
Oct 05, 2009 | Bosch WTA4410US Dryer
Frequent tripping of the hight limit switch
The high limit switch itself is getting weak , replace it and problem solved!
Sep 12, 2007 | Wells F-49 21148 Deep Fryer
Tools & Hardware - Others Logo
56 people viewed this question
Top York Tools & Hardware - Others Experts
vince
Paul Carew
Are you a York Tool and Hardware - Other Expert? Answer questions, earn points and help others
