Question about Compaq (103180-B21) Mouse
Compaq notebook right mouse button does not work
Right click doesn't work
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 75 Answers
New mouse modules are fairly easy to replace. JBGaming.com has them for nearly any model. And cheap.
Posted on Nov 26, 2013
2 Suggested Answers
  • 52 Answers
SOURCE: my compaq optical ps/2 mouse doesnot scroll
get the screw's out and check the support of you're scroll, and if the scroll button didn't move from its position. if is new take it to warranty for repair's.
Posted on Dec 15, 2008
The slimtype dvd drive in my acer aspire 7739z doesn't work
check: right click on my computer in desktop then choose manage. then click on device manager then if u see a yellow symbol then right click on it and update the driver through internet then it will say u what u have to do exactly.
good luck
Feb 17, 2013 | ASUS K52F-BBR9 Notebook
Rotate screen back to horizotal
Try pressing Ctrl + Alt + UP Arrow Key, or try Ctrl + Alt + and a different Arrow Key.
If that does not work: Right-click on empty Desktop > Graphics Options > Rotation.
or
Press "Ctrl-Alt" and an arrow key (left, right, up or down) to rotate the screen.
Continue pressing the hotkeys and arrow keys until you reach the desired rotation. This works with most video drivers on Windows XP. If it doesn't,
Click "Start," then "Control Panel," then "Display," then the "Settings" tab. Click the "Advanced" button. Check for an "Orientation" option. Select your desired orientation.
hope this helps
Jul 25, 2012 | HP Pavilion tx1000z Notebook
Why doesn't my Verbatim "clip
click start right click on computer select properties then device manager scroll to universal serial bus controllers if you se a yellow question exclamation mark ? ! or a red X you will need to update/reinstall drivers right click select update drivers
once inserted windows 7 should automatically install the drivers
if you computer came with a motherboard disk the drivers could be on it
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem check the usb leads inside your computer usually
usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Sep 06, 2011 | Verbatim VER95327 USB Hard Drive
LSR6132E agitator doesn't work, won't spin?
open the lid,on the right side you'll see a hole in the top panel,stick a screw driver into the hole,you should hear a click or close the lid,lift it up an inch or two and close it down,if it doesn't make a clicking sound the lid switch is bad part number 3949247 and it's around 45 dollars.
Sep 03, 2011 | Whirlpool Washing Machines
Im trying to scan a document but its saying error code 2106. i have it hooked up through wireless
Try these things:
1. place a doc to scan in the scanner. Close the lid and hit MENU, COPY document, START.
If that doesn't work you'll need to contact kodak. If it does then try this next:
2. Check for ADMINISTRATOR rights.
  1. RIGHT CLICK on the kodak icon and select Properties > Compatibility tab > Run this program as an administrator
  2. Select RUN AS ADMINISTRATOR
  3. click APPLY
  4. click OK
Then try scanning again. If it still doesn't work then-
Reload the driver:
  1. select Start > Run.
  2. Type %windir%, then click OK.
  3. Double-click twain_32.
  4. Right-click Kodak, then select Delete.
  5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to (cd drive: > printer > scanner.
    Double-click aioscannr.msi, then follow the instructions to remove it
  6. Then go to cd drive: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  7. Open Home Center Software
  8. Select Scan Documents and Pictures.
  9. Scan a document
If it still doesn't work then you'll need to take it in for service.
Jun 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
HOw to replace the mouse left click and right click
The mouse click changes are based on OS used.
In windows OS ..Click Start button on your windows desktop. Select and click on Control Panel from the menu. Select and click Mouse from the control panel. From the Mouse Properties Window, select the Buttons tab. Select and check the Switch Primary and Secondary Buttons check box. Click the OK button.
Your mouse buttons should now be switched around, so now when you click your left mouse button, it will behave as a right-click, and clicking your right mouse button will behave as a left click.
Dec 01, 2010 | HP Compaq Presario C306US Notebook
How do i change the mouse buttons on a compaq 6735s
Are trying to switch to lefthanded settings?
Converting to Left Hand Mouse for Windows XP Users:
  • Call up the Start menu by clicking on the Start button or by pressing the Windows logo key (located between the Ctrl and Alt keys). Alternatively, you can press Ctrl + Esc
  • Click on Settings and select Control Panel.
  • Double click on the Mouse icon to display the Mouse Properties
  • Select the Buttons tab and click on the check box marked Switch primary and secondary buttons to set the mouse buttons up for left-handed use.
  • Click OK or press Enter to confirm your choice and exit the mouse properties (note: you should be using the mouse’s right button now to make selection)
http://www.tipandtrick.net/2009/customizing-the-mouse-for-left-handed-users-in-windows-xp/
Jan 02, 2010 | HP Compaq 6735s Notebook
On my compaq nc6120 the menu keeps popping up even though i did not right mouse click
Check that you do not have a key sticking on the keyboard and that the right mouse button is not stuckor defective. If not then reinstall the mouse driver and if possible try another mouse as it could have a cable fault.
Nov 12, 2009 | HP Compaq nc6120 Notebook
Compaq (103180-B21) Mouse Logo
19 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
