How to bleed a motorbike rear brakes - Computers & Internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,190 Answers
Find the rear caliper and there should be a bleed nipple on the top , find the reservoir by the rear brake lever and make sure its full ! undo the nipple with a lenght of pipe on it to catch fluid in a bowl and gently press the brake and hold it down then tighten nipple , release brake and repeat this several times ! keep an eye on the fluid level so not to run out !! test and try ! P...
Posted on Dec 12, 2013
I have a ford escort xr3i 1988 i have replaced the brake master cylinder, bleed the brakes but still have no brakes what could be wrong?
Your car has a diagonally split brake system. Each side of this system must be bled as an individual system, and there is a correct bleeding sequence to be followed. First bleed the right rear brake, second, bleed the left front brake, then follow with the left rear brake and lastly, bleed the right front brake.Here's a link on a repair guide for bleeding your brakes. Repair Guides Brake Operating System Bleeding The Brake System AutoZone com
May 24, 2015 | Ford Escort Cars & Trucks
Bleed brakes
https://www.youtube.com/watch?v=tflWI-ieCpA
http://www.therevcounter.co.uk/motorbike-articles/34369-motorbike-brakes-beginners-information-bleeding-guide.html
Have a look at the above links. They are very good at explaining everything regarding the brakes. The clutch is done in an almost identical manner. You can get auto bleeders , but I would recommend this is a 2 man job.
Aug 08, 2014 | 1998 Suzuki GSF 1200 Bandit S
2008 Hyosung GT650R how to bleed the rear brakes
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Hyosung, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Help with adjusting and bleeding front and rear brakes clutch fluid
How to bleed your front rear brake calipers on your motorbike motorcycle
HYOSUNG Aquil GV650 Service Manual
http://www.alpha-sports.com/hyosung_parts.htm
HYOSUNG GT 650 Manual
Dec 05, 2017 | 2008 Hyosung GT650R
How to bleed motorbike rear brakes
FILL THE BRAKE FLUID UP GET WRENCH TO FIT THE BLEEDER VALVE. PUMP BRAKES 4TO 5 TIMES AN HOLD DOWN AN OPEN BLEEDER VALVE AT THE SAME TIME. CLOSE VALVE BEFOR LETING OF THE BRAKES THIS MIGHT TAKE TWO PEOPLE. CLOSE VALVE CHECK BRAKE FLUID DO NOT LET RUN DRY. REPEAT THESE STEPS UNTIL YOU SEE NO AIR BUBBLES CO MING OUT.
Nov 24, 2013 | 2000 Yamaha TDR 125
Canot get the rear brake to bleed
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Cleaned brakes dot 4 fluid change Brakes not working xt1
http://gigi600.altervista.org/immagini/xt125r/XT%20125%202005_service.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xt-owners-manuals
Dec 29, 2012 | 2007 Yamaha XT 125 R
I just bought modenas CT last month on 22... wen i brake use my leg..its sound like sumthin wrong... summore d tyre not safe at al... wat should i do... i feel like not safe at all riding tis motorbike..
check the rear tyre pressure if its correct look at the tire tread, if its ok then move to the brake, wind the nut in on a drum if its drum brake to make it more sensitive and on hydraulic brake if the lever goes and theres not braking power, you have air inside the system, bleed it out and try again. if you dont know how, take it to a mechanic.
Sep 28, 2012 | 2011 Modenas CT100
2005 Honda Silverwing 600 how to bleed the brakes
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $27 you can download another one.
Need Help With The Brake Bleeding
Honda 2002 2003 2004 2005 2006 Silverwing service manual Download Manuals... $27
https://www.partsfish.com/page/oem-parts-for-honda
Honda FSC600D 2005 SILVER WING Owner Manual
Jan 25, 2012 | 2005 Honda Silverwing 600
I have a'90 goldwing,I cannot get brake fluid thru
Your rear brake pedal operates the rear caliper and the front disc. When you tried to bleed the left front caliper you let air into the rear brake system. Bleed the rear brake and front left caliper using the rear brake pedal that should restore the rear (and front) brakes.
Jul 20, 2011 | 1990 Honda GL 1500 SE Gold Wing
Replaced rear brake shoes then bled brakes.couple days later pedal went to floor before i had brakes.rebled brakes thinking air in line. Worked for a couple hoursthen went down again. Checked for leaks...
i am not sure about the process that you used to bleed the brakes, whether it was a one man bleeding kit, or anything else, but this is a bleeding process which i have used for over 10 years on everything from motorbikes, cars, trucks and rally cars.
It is as follows : ------
Use 2 people....i know this may be hard to arrange but i have even used my mom.
Use one person to sit in the vehicle, engine off. Now firstly go to the furthest brake bleed nipple from the reservoir. If the reservoir is located on the left hand front of the vehicle, then go to the right hand rear nipple (with wheels off, preferably). And vice-versa.
Next, with the nipple CLOSED, get the assistant to pump the brakes slowly (do not go fast, it is not a race....lol). Down, as far as it will go, and all the way up....repeat 2-3 times.
Next, get them to hold the brake pedal down, now OPEN the bleed nipple, and ask them to repeat, all the way down, and then up again, 2- 3 times, then CLOSE the nipple. This flushes the system out. Again, sloooowly.
Next, with the NIPPLE closed, get assistant to pump the pedal again SLOWLY 2-3 times, this action forces the remaining air in the system to the nipple end of the brake lines.
Next, have your assistant hold the pedal down, gently OPEN the nipple slowly until the fluid comes out...as the fluid is still coming, CLOSE the bleed nipple. DO NOT let them get to the bottom of the stroke.
What happenes if they reach the floor, and you still have the nipple OPEN, is that a small amount of air leaks into the system, and after a couple of days driving with heat expansion, your brakes are spongy again.
Repeat this 2-3 times on that wheel.
Go to the opposite side of the vehilce now, the left hand rear wheel and perform the same action.
Then the right front wheel.
And finally the left front wheel, the closest to the brake master cylinder reservoir.
Remember to use fresh, new up to date brake fluid.
And use a clear tube or straight into a bucket, so that you can see successfully the air coming out of the system.
Failing this, if you have bled the sytem properly, and this still occurs, and you have no leaks, it is time for a brake master cylinder replacement. As there is a number of rubber seals that keep each brake sytem seperate, within the master cylinder as a safety precaution. If one sytem fails...ie left front brake hose leaks, then that side of the sytem (the left front and right rear, in a opposite system) will leak out, BUT the right front system(which includes the left rear as well)will still maintain pressure to be able to slow the vehicle down to a stop (obviously with increased pedal travel)
REMEMBER not to get any brake fluid on the paintwork, as it is a great paint remover (over time). If you do get it on the paintwork, just wash off with water immediately.
I hope this helps all of those who read this advice.
Please vote if you liked it !!!
And happy motoring.............
Jun 30, 2010 | 1992 Pontiac Sunbird
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
