Question about Frigidaire Ovens
The heating element on my Frigidaire RBE-97N has cracked and broken. How easy or hard is it to replace it?
    Prodigy:
    An expert who has answered 500 questions.
  • Frigidaire Expert
  • 650 Answers
I assume it is the bake element. These are very easy to replace. make sure the power is off and you can access the screws from the oven cavity. remove the screws, pull gently on the element. If the wires are long enough you should be able to disconnect them or unscrew the wires from the terminals. reattach the wires to the new element. reinsert it back in place and there you go.
Posted on Nov 26, 2013
3 Suggested Answers
ltfrc
  • 227 Answers
SOURCE: I have 1950's Frigidaire electic oven by General
Partselect.com had the oven element for my '60s Frigidaire GM stove. They have a good "narrow your search" feature that was helpful as the model number is no longer recognized.
Give them a try. Pull your bad element and measure it to get a match.
Posted on Oct 18, 2010
  • 472 Answers
SOURCE: Have a frigidaire oven, model#
mos likely yes... but to confirm is very easy... unplug unit or turn circuit breaker off... in the oven with door open you will see the back of bake element where it goes into oven wall a couple of screws remove them and you should be able to gently pull element out...there are 2 terminals connected to element with a wire attached to each of them... first we are making sure the wire hasn't burnt off or cam edisconnected and second we can remove wires and use a volt meter and test power... set it up so you don't get electricuted and tuen oven on bake 350 do you have power coming to the wires with element diconnected from wires...if so then you have a bad element if not then a bad thermal cutooff usually located in back of unit ... good luck to you...
Posted on Jan 12, 2011
Testimonial: "Thanks. I have no power going to the coil so I'll check the thermal cutoff."
Old frigidaire wall oven model RBE-94N emitting strong odor & not baking
Hello - From what you have described it sounds like the unit has faulty elements or could possibly be experiencing a wiring issue with the EOC. Try resetting the oven by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately to properly diagnose the unit.
Nov 10, 2012 | Frigidaire Ovens
When trying to turn on the front right burner it doesn't heat at all what do I need to replace?
Check the wiring to the element, be careful shock hazard. On my electric range the wires were broken where the element plugs in socket. Socket kits are about $9.00 us If you have a volt meter unplug the element and turn the control on if you have voltage then replace the element. Thanks Tom
Nov 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Have a frigidaire oven, model# PLES389ECE. Broiler heating heats up but lower (bake) element does not. Element need replacing?
Jan 11, 2011 | Frigidaire Ovens
The elements will not heat up on bake.
The problem is the Bake heating element. This is easy to check and usually inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 02, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
After using self-cleaning option, oven took a long time to reach temperature; then I wiggled the heating element and got popping sound and spark and now it doesn't work at all. Could I easily fix this by...
Question where did spark come from. Is element broken? If came out of back connection then connect and element should be replaced, If element is worn or broken then replace element, easy to fix yourself, just make sure you disconnect power for safety.
Feb 26, 2010 | Ovens
I need to replace the lower heating element in my older model oven. I think the serial number is 316071601. How do I remove the old element? I am clueless at repair but this should be relatively easy to do...
YES IT IS EASY BUT UNPLUG IT FIRST. REMOVE THE SCREWS FROM THE BACK WALL ABOVE THE ELEMENT AND SLOWLY PULL THE WIRES WITH THE ELEMENT THROUGH THE WALL ABOUT A INCH AND DISCONECT THEM FROM THE ELEMENT
Jan 12, 2010 | Frigidaire Ovens
My frigidaire oven won't heat. The burners work
You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
Aug 23, 2009 | Frigidaire Ovens
I have 1950's Frigidaire electic oven by General Motors and the top heating element is broken. Where might I find a replacement?
Jul 11, 2009 | Ovens
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
80 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
