Question about Crosley CR7002A-OA Troubadour Turntable - Oak
LPs wobble on turntable.
The turntable turns smoothly but as soon as an LP is put on it, the record klicks up and down. It seems like something is interrupting it at the base of the tone arm but I don't want to fiddle and cause more problems.
    Genius:
  • 1,198 Answers
Usually you can lift the turntable and check for problems. Sometimes there is a clip holding the turntable in place, but with small tools you should be able to get the clip free. Don't be too worried about getting the clip back on, as long as you aren't going to turn the unit upside down.....
Posted on Nov 24, 2013
Testimonial: "R"
LP recorder incompatibility
The software (LP recorder) does not recognise your soundcard. Download a different free program to record your LPs.
Dec 19, 2013 | Xitel INport Deluxe for PC
Some of the lps i buy do not fit the table. for instance, usually the edge of the record scrapes the arm stand. Now though, i have a record that wont even turn because it seems too wide. any idea?
I had the same problem, at first I would just gently file down the edges of the records with a nail file, but when they got too many I decided to tackle the root of the problem and used a sharp blade to shave off some of the plastic of the arm stand, about 1 mm. No problems since!
Aug 25, 2012 | Pioneer PL-990 Turntable
My Jensen JTA 450 is playing LPs too slow even though 33RPM is already set. The songs are slower than usual. Please help me.
The record that you are trying to play maybe a 45rpm recording. Some 45's were released in album size recordings.
Jun 20, 2012 | Audio Players & Recorders
I can play LPs, b ut when I click on "record", and
Uninstall the upper and lower filters scroll down to how here: support.microsoft.com/mats/cd_dvd_drive_problems
Also, this can be as easy as your burning software as have that problem allot. Download the below ad try doing something on the drive: www.nero.com/eng/downloads-nero8-trial
Hope helps.
Aug 01, 2011 | ION Audio Audio Players & Recorders
VINYL PLAYER SLOWS WHEN I STACK A COUPLE OF LPS sounds funny play fine with just 1
The labels on the LP's stick up higher than the vinyl. These slip on each other when you stack LPs.
One LP sits directly on the turntable mat and has enough friction to turn.
The only solution I can think of is to put something 'tacky' on the labels but this might be detrimental to the label.
Dec 16, 2010 | Audio Players & Recorders
Turntable does not turn
Remove the 'E' clip at the center of the turntable. Cup your hand around it and pop it off with a screwdriver. It can fly across the room. Clean the inside rim of the turntable, the rubber drive wheel and the motor post. If you can find "Vita Drive" that's best but Radio Shack will have something comparable. Make sure there is NO film left on any surfaces. At WORST, you will have to replace the drive wheel.
Jul 31, 2009 | Kenwood KD-291RC Turntable
Only records Lps and CDs, but not other cassettes
there are programs on the net that will copy from tape to cd via the computer if you have a cd writer on the pc hope this helps regards Jim
May 02, 2009 | Audio Players & Recorders
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Record LPs into desktop computer.
If you have an line level audio output on the shelf unit, you can as then the other end would connect up to your input to the sound card, if there is only a mic. input and no line input you can get whats called an antenuator, or get another audio sound card for the computer with a line level input jack. Good Luck
Mar 21, 2007 | Teac DC-D6300 CD Shelf System
Crosley CR7002A-OA Troubadour Turntable - Oak Logo
77 people viewed this question
Top Crosley Kitchen Ranges Experts
Rob
Rob
Level 1 Expert
Lawrence Oravetz
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
