I have KRX 891 Kenwood Stereo system... The receiver just stopped working one day about 4 years ago... i found out that Radio Shack sells fuses, and i have asked in the past if it could be a fuse, but never got a resounding yes... but of course there must be fuses... I bought this brand new about 20-22 years ago.I cant figure out how to get to the fuses.
Karen, this may be an easy fix. There are a couple of screws on top of the unit and about 8 or 9 around the back edge. First make sure the unit is unplugged. Remove these screws andyou can lift the cover off. On the left side you will see 2 glass fuses. Gently pry these out and you will see they are marked on the end caps with voltage and amperage ratings. Replacements are very affordable at Radio shack. Good luck! B-) wayne2ears@gmail.com
Posted on May 08, 2015
FRANKSFIXIT
  • 72 Answers
SOURCE: 96 dodge neon radio not working
Hello Jim,
Not sure where you are measuring your "good" 12vdc voltage(s) from, as with newer radios there are actually 2 +12vdc voltages you need to have otherwise the radio will not power up?
Also - your main car fuse block fuse for the switched ACC may be bad if you are only hooking up the new radio HOT 12vdc wire to the wrong batt source. I'm not there to actually see what you are or are not doing right or wrong.
Are you measuring it at the fused YELLOW wire lead (as in ALWAYS HOT, or as in connected to BATT 12vdc unswitched power source only), or measuring it at the fused RED (connect to TURN ON +12vdc ACC only), or at both ?? VERY IMPORTANT here.
Big difference and here is why - as both of these fused +12vdc sources have to be connected to the proper voltage source or the radio won't turn on.
The YELLOW fused batt voltage source is always ON, so it can remember your radio's settings in the memory, and also allow power to the CD player part of the radio so so as to be able to accept a CD even with the Ignition switch to the OFF position.
ALSO - that YELLOW unswitched +12vdc wire lead has a FUSED noise FILTER suppressor box (BLACK in color), and there is usually a 250V 5A fast blow fuse inside that marked suppressor box as well. NEVER replace the factory fuses with a higher value, as this will only cause more circuit damage if there is a possible short in that circuit leg.
The RED fused batt voltage source is IGNITION switched so when you leave the radio ON - but turn off the Ignition switch - the power is cut off to the radio so that the batt doesn't run down. Hope this makes sense to you. There is usually an in-line 250V 1A fast blow fuse in that marked fuse holder.
Both fuses have to be good!!
There also has to be a GOOD ground return - as in a good solid connection! Dirty grounds can be a high resistive point, and actually impede current flow to the point where some electronics will not work at all. You can still read a static +12vdc batt voltage, but NO current is going to flow in the circuit. I see it happen all too often esp with dirty batt connectors in the engine compartment.
Seeings your OLD factory radio was some ~12 years old it probably failed from OLD AGE. Possibly?
If it's a higher wattage unit it may have taken out the 5A fuse in the YELLOW +12vdc lead. Again from old age - as when the older the unit gets sometimes it tends to draw more circuit current, as from wear and tear on the CD player part, esp if you play a lot of music CD's in it. Same if it's a Cassette/Radio player combo. Then again - it could still be good, but you are maybe still overlooking a blown fuse like in the "ALWAYS HOT" YELLOW lead??
Chances of getting a 2nd bad after-market radio are pretty slim odds wise. Unless maybe that after-market was bought in a USED condition? If that's the case it too may be bad. You might have bought an AS IS LEMON in that case.
Depending on where you bought the after-market radio from you might want to take it back and have them check out the "possibly defective" radio there at the store. If they can do that there? If it checks out good at the store - then you are definitely doing something wrong at home!
If any + or - wiring leads were reversed in doing your DIY upgrade installation then the 2nd radio is history as well. Very important to NOT reverse polarities!!
These hookup guidelines and hints should help solve the problem, as I can't see anything else other then possibly a bad AMP if you had a really high powered car stereo system. You never said either way??
Hopes this helps?
Best regards,
Frank
Posted on Mar 15, 2008
SOURCE: Kenwood AR 404 burning w/ open flame.
You are literally playing with fire. Obviously the unit is in dire need of service! Please, take unit in for check out by a pro/tech
Posted on Apr 27, 2008
  • 4234 Answers
SOURCE: Kenwood KR-A4070 blowing 5a 125v fuses
I am guessing that the ceramic resistor is close to the output transistors. I would also guess that one or more of the output transistors has shorted. This causes a high current draw that is blowing the fuse. You could also have a power supply problem. The ceramic resistor is a .22ohm dual emitter resistor that is used in the output stage. The transistors located close by are probably shorted and should be replaced. Start there and let us know what happens once the transistors and the resistor are changed.
Dan
Posted on Oct 10, 2008
SOURCE: Kenwood KDC-MP832U display not working
I had this problem! It was the Cars Battery. Kenwoods unit's fade or go completely blank when there is little power to power the stereo. Try charging your battery or grabing a new one from a scrappy! I was all over the net looking for help but finally sorted it!
P.S. My younger brother had to do the exact thing and it worked for him as well!!!
Posted on Nov 15, 2008
  • 4 Answers
SOURCE: I have a kenwood vr
Kenwood receivers recently have a commonly known problem with its receiving IR diode within the receiver, to fix this you will have to re-solder the connection on the receiver panel within the faceplate of your kenwood receiver.
Instructions to fix it are at the following link if you are willing to open up your receiver and repair it. lots of people have reported this fix as successful so it is widely believed to be a design flaw in the VR line-up of receivers as it has occured in all the VR families so far.
good luck.
Posted on Jan 22, 2009
I have a Kenwood krx-89 standby light on please help
Krx-89 stand by light wont turn off - Fixya
www.fixya.com/support/t14712608-krx_89_stand_light_wont_turn_off
Oct 20, 2012 - krx-89 stand by light wont turn off Stero doenst play is it because thestand by light is on? How do i turn off - Kenwood Audio & Video Receivers ...
How do you turn off standby on a kenwood krx-89 stereo ...
www.fixya.com/.../t15447523-turn_off_standby_kenwood_krx_89_ster...
Dec 20, 2012 - Hi, is the red light that says power On? If not, it could just be the fuse since I had the same problem. If you take the lid off, it should be in the left ...
Read - Document Download
Dec 14, 2015 | Kenwood Audio Players & Recorders
Kenwood car audio problems battery change
Check the owners manual for the car or stereo, it may have a theft proof setting.
Jan 08, 2014 | Kenwood Kdc-u453 Car Audio Radio Iphone...
Do all Kenwood Home stereos have fuses?
yes there are fuses. usually they are glass fuses near the power input on the board inside the unit. but you could also have fried or corrosion damaged other electronics if you have dropped water inside it
Nov 24, 2013 | Car Audio & Video
Can't locate the fuses.
There are no fuses inside a car stereo unit. The fuse protection is outside on the power circuit. Does it do anything when you power it on?
Nov 24, 2013 | Kenwood Car Audio & Video
Hi, is the red light that says power On? If not, it could just be the fuse since I had the same problem. If you take the lid off, it should be in the left rear and is a 250v 6amp fuse. I had the same problem where only the standby light and the input lights were on. Neither the radio and cassette lights were on.
Dec 20, 2012 | Kenwood Audio Players & Recorders
Free unlocking code for kdc w3037a
Unfortunately Kenwood codes are only available from the Main Dealer or by using a Radio Decoding Service who will connect a laptop to read the working code inside your radio`s memory chip (EEPROM)
Oct 29, 2009 | Kenwood KDC-W3037A CD-receiver,...
Stereo cassette receiver--hums
There could be an open filter capacitor in the power supply.
Jul 13, 2017 | Kenwood Audio Players & Recorders
Need an owners manual for a kenwood amp
HI...
try www.hifiengine.com ...those are free
or Rick at www.stereomanuals.com
Please rate my help if you can.
Thanks
Feb 21, 2009 | Audio Players & Recorders
Wiring diagram for 01 isuzu rodeo stereo
A few weeks ago I bought a new JVC stereo for my 2001 Isuzu Rodeo. I was advised that using a wiring harness would be the best option to install it. I spent an entire Saturday going from one store to the next (Autozone, Advance Auto Parts, Radio Shack, etc.) looking for the wiring harness specific to an Isuzu Rodeo but, to no avail. I searched several online sites looking for one and finally found it at http://www.beachaudio.com/ . The cost of the harness was under $10 and with express shipping I only paid about $20. Since I ordered it on a Wednesday night with 3 day express shipping, I assumed that I'd receive it the following Monday given any processing time and the weekend but, it was delivered to me just two days later. My husband installed my new stereo that Sunday using the harness that I purchased and it works great! Hope this information helps.
Nov 25, 2008 | 2001 Isuzu Rodeo
273 people viewed this question
 Grubhead
Grubhead
