Question about Diamondback Fitness DiamondBack 600EL, 600ES, 600R And 600U Power Supply / AC Adapter
My diamondback 600 el won't adjust tension - Diamondback Fitness DiamondBack 600EL, 600ES, 600R And 600U Power Supply / AC Adapter
Diamondback 460ub tension adjustment? how?
http://www.bing.com/videos/search?q=diamondback+460ub+tension+adjustment&qpvt=Diamondback+460ub+tension+adjustment&FORM=VDRE
May 22, 2015 | Diamondback Cycling
Diamondback tess 24 has clicking in gears and is hard to shift
sounds like the derailleur cable is stretched out and needs to be adjust. search here or google on how to adjust a derailleur, or take to your local bike shop, it's a cheap repair.
Apr 12, 2014 | Diamondback Girls Tess 24 Mountain Bike...
I was riding my diamondback viper and i put on the brakes, and when i let go they were still touching the rim. They seem to be jammed in place.
Internal brake cable friction or gross maladjustment is at play here. The brakes must spring back under their own spring tension or they will stay engaged.
http://www.parktool.com/blog/repair-help/categories/brake-service-and-repair
Simple search engine querieswill find answers to well0-crafted questions like "how to adjust...."
Aug 06, 2011 | Diamondback Viper X BMX Bike (20Inch...
HOW TO ADJUST TIRE RIMS ?
Adjust rims? Do you mean to true them and tension the spokes?
http://www.parktool.com/blog/repair-help/wheel-and-rim-truing
Or Google "how to ...."
May 12, 2011 | Diamondback Sorrento Sport Mountain Bike...
My diamondback mountain bike brakes need adjustment. the pads sit too close to the rim and rub constantly. how do i adjust the caliper so the wheel turns without interference? is there a document...
For brakes you need an instruction manual or repair book. Brakes are a little too complicated to explain in detail in a simple document. Although the service manuals for the brakes have a decent amount of explanation, they do not outline specific tools and other helpful information.
For the component owners manual you will have to visit that component companies website (ex. Shimano = (www.shimano.com) and look under tech documents.
For a good book, try Zinn and the art of mountain bike maintenance or The big blue book of repair from Park tools.
Side note: double check that your cable and housing is seated throughout its route from lever to brake, if the housing comes unseated from the frame stops it will shorten (tighten) the brakes, Also check to see if you have any adjustment at the lever to reduce the tightness of the brake cable (there should be a knurled nob at the end of the lever where the brake comes out, if that is screwed out away from the lever this will shorten (tighten) the cable tension, screw it back into the lever. Finally you can loosen the cable at the brakes, opening them up, then retighten to make the brakes work.
Dec 13, 2010 | Diamondback Outlook 26" Mountain Bike
No chain tesion adjustmen older (yellow) Remington EL.1 chain saw
just undo the singe nut slightly the pull so chain tightens then re tension the nut....about all you can do on those old models.
Jul 24, 2010 | Remington Garden
1. se enreda el hilo abajo y se rompe el hilo de arriba. 2. muy baja tensión del hilo de abajo. está en el límite de ajuste. Ajusté la bobina y mejoró pero sigue con el problema...
Hola! Espero que puedo ayudarle con su problema--pero, como hace mucho tiempo que no escribo en espanol, por favor, tenga paciencia conmigo.
Muchas veces ese problema de enredar el hilo del abajo resulta de la presencia de pequenos pedacitos de hilo en esa zona. Use un pequeno cepillo para saquar toditos.
Generalmente, no hay que adjustar la tension de las canillas (bobina?). Adjuste al punto que hay un poco de tension cuando jale un poco al hilo.
Casi siempre adjustando la tension de arriba solucionara todo.
Use hilos de diferente colors en la canilla (bobina) y arriba. Tambien, es major usar un aguja nueva. Usando un pedacito de su tela normal, empieza a coser. Cosa unos centimetros, y pare para cequear. Siempre adjuste la tension con la pie prensatelas abajo.
Si se ve el hilo de abajo (el del bobina) en la parte superior de la tela, el hilo superior esta demasiado tenso. Gire el equilibador de tension para disminui el numero.
Si el hilo superior esta demasiado flojo, se ve el hilo del bobina en el lado inferior de la tela. En ese caso, hay que amentar el numero.
En todo caso, hay que hacer las correciones lentamente,
Sequn mi guia, se rompe el hilo de la aguja:
1. No esta enhebrado correctamente 2. La tension del hilo de aguja es excesiva. 3. La aguja esta despuntada o doblada 4. La aguja no esta bien colocada. 5. Los hilos de la aguja y del bobino no estan bien colocados debajo del prensatelas al empezar a coser 6. La tela no se ha extraido hacia atras al terminar la costura 7. El hilo es demasiado grueso o fino para la aguja.
Ojala que eso le ayude y que mi espanol no esta demasiado feo.
Robbie
Feb 22, 2010 | Kenmore Sewing Machines
How do you adjust chain tension? I have the 16" Remington electric chain saw, and the chain will not stay tight; it slips off the rear sprocket as soon as I try to use it. I don't feel everything is...
Here is a link to instructions for EL-8 series saws ... http://www.desatech.com/pdf/115499-01_EL8_Series_Chain_Saw_Tension_Adjustment.pdf. For series LNT-2, LNT-3,EL-1, and EL-7 according to the manufacturer... "WARNING: The cutting edges on the chain are sharp. Protective gloves should be used when touching the chain. Unplug the chain saw from the power supply. Allow chain to cool. Loosen the guide bar nuts until they are finger tight. Ensure the adjusting block is in the adjustment hole in the guide bar. Turn the chain tensioning screw clockwise to increase tension. Turn the chain tensioning screw counterclockwise to decrease tension. Check for proper chain adjustment by pulling down on the chain at the bottom center of the guide bar. You should see no more than a ⅛ inch gap between the chain cutting links and the guide bar. The guide (or drive) links should not come out of the guide bar grooves. The chain should rotate freely around the guide bar. If it does not, chain tension should be decreased. When the chain is properly adjusted, tighten the guide bar nuts securely." On the M series if your chain keeps slipping off your sprocket... The Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. I hope this helps you!
Jul 01, 2009 | Remington 16" Electric Chain Saw
Timming chain adjustment
Most likely you have anautomatic cam chain tensioner, which cannot be tensioned, and the only remedy is to replace the cam chain (if it's stretched). If, however, you have a manualy adjusted cam chain tensioner (highly unlikely), you have to look up the tensioning value in your workshop manual.
Jun 13, 2009 | 1986 Yamaha FZ 600
Tension problem Bottom thread is loopy and sloppy
You should do a Tension assembly test.
Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Aug 07, 2008 | Brother SE-270D Computerized Sewing...
Diamondback Fitness DiamondBack 600EL, 600ES, 600R And 600U Power Supply / AC Adapter Logo
44 people viewed this question
Top Diamondback Fitness Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a Diamondback Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
