Question about Hardware & Accessories
Dont know how to set it or get it to turn on and to make it worst dont know he type of gzrrison i have beside baseboard heather
  • 5,089 Answers
Http://waterheatertimer.org/How-to-set-timers.html
Add a comment and describe product in detail, and what it does.
Gene
h
Posted on Nov 25, 2013
Heather hose diagram
I suppose you mean "heater". My cars do not have "heather"s. It would be helpful to know what type vehicle you have.
Dec 31, 2014 | Cars & Trucks
Schematic plf504d thermalinc
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
Dec 13, 2013 | Lasko 5610 Baseboard Heater
Burning Smell from Old Baseboard Heather All of a Sudden
If it was the first time started this season, then it was dust buildup burning off. If burning smell continues, call for service.
Dec 15, 2009 | Cadet Manufacturing 4F1000-8A Electric...
Heater wont heat
It sounds like the thermostat is loose and needs to be adjusted or replaced. Leave this to a professional if you don't know what you're doing. So many fires are caused by baseboard heaters.
Oct 01, 2009 | Honeywell HZ519 Baseboard Heater
Honeywell HZ517 Electric Baseboard Heater not powering up
first.... did they work in the past?? if so... you may have a defective thermastat. if not, usually it is a incorrect wiring problem. wiring in two baseboard heaters to one thermastat can be tricky if you do not know what you are doing. baseboard heaters by design seldom go bad.... if wired correctly the problem could be a defective thermastat or safety limit switch.
Feb 09, 2009 | Honeywell HZ517 Baseboard Heater
How far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
Instructions for 1987 mattel baby heather interactive doll
hi i have a baby heather and she works fine ,
hope this is some help ,
look at the back of heather
you will see two battery compartments the large1.5v box and above that a button stating grow up
press this once ist stage baby
press again goes to 1 year old
press again goes to final stage two year old
directly below the large battery compartment
two rubber buttons
one grey one red
red means enter the programme mode
the time she first says is the time set to work on
push the grey button to change hour keep doing this till you get the desired hour to match our time
press red enter button
does this quite quickly or she will say exiting program mode
heather then instructs you
on to morning wake up time
press the grey button to enter wake up time keep doing this untill you get desired wake up time
heather now knows her wake up time
press red button again for night time sleeping mode ,and follow the same steps as above till you want her sleeping time press red enter her sleep time is stored
if you press the red button again she tells you her developement status , baby 1year old or two years old , confused yet i hope this is clearer than it types
ok other functions
below her aa battery box the small thin batterys there is a switch
to the left it says off eyes closed
when switched to this the doll will switch off with her eyes closed
when switch is in the middle she s on and ready to play
when switched to off eyes open heather is switched off but her eyes remain open
still havent understood the clear round button but give me time
under her left arm if she is facing her away from you is her ticklish spot she likes that sometimes if she doesnt she will soon let you know ,
below her tummy is another sensor this is her hug sensor so if she asks for a hug gently push her tummy and she will know , heather can hear you and she will look around to hear your voice her eyes move left and right and her head turns as she working out where you are
also peek aboo if you d like to play, gently place your hand over her eyes she will respond ,
also horsey if she wants to play gently bounce her up and down and be careful these dolls can suffer from loose or detached legs ,
other tips if she doesnt have an original outfit pick one that wont restrict head movements , as for feeding , or hair brushing im working out if she does need original items or another doll item will do
have fun
russell
Nov 15, 2008 | Toys
Baseboard heaters
measure each room you want to heat. multiply the length x width, this will give you the square footage of the room to be heated, multiply that by 10 and that is the number of watts needed to heat the room using 220/240v baseboards.
Sep 11, 2008 | Fahrenheat PHH15002 Oil Filled Baseboard...
Hardware & Accessories Logo
26 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
