Question about Canon PIXMA iP4300 InkJet Photo Printer
CANON IP 4300 PRINTERS WILL ONLY PRINT ALTERNATE LINES
I have a text document that is a series of Text box's sized 150mm by 20mm high to form a table. When I try to print it out either with or without text inserted the printer will only print to boxes & or text sporadically, printing the top text box border & two lines of text,then jumping two lines , then printing the cycle again. I have carried out all the usual cleaning & deep cleaning Plus nozzle alignment & removal & flushing of Print Head together with re loading the latest operating system, please can someone help
  • 2,113 Answers
I think your text document didn't fit the page. I have done that before. It overruns and the extra becomes the lines inbetween. To fix this use microsoft publisher to print it so that you can choose the paper size and the borders and fit the document within the space allowed.
Posted on Nov 24, 2013
3 Suggested Answers
SOURCE: Canon MP800 PGBK black ink will
I have the same problem.  I turned off the printer, then selected "auto head alignment from the printer's maintenance menu and it worked!
Menu -> Maintenance/Settings -> Maintenance -> Auto Head Align
Posted on Feb 04, 2009
  • 71 Answers
SOURCE: Canon Pixma iP90 - Jagged text and lines
The printer has a plastic band that runs from one side to the other. The print head has a sensor that passes over it each time it moves. The band is a little transparent and appears to have vertical lines in it. That needs to be cleaned.
  1. Remove power from the printer,
  2. Wipe it clean,
  3. Move the head manually to other side to clean the other areas.
Hope this helps.
Posted on Jun 02, 2009
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
Erratic print with canon ip 4300 printer
The document should be formatted as a table with text inserted rather that a group of text boxes.
Nov 24, 2013 | Canon Office Equipment & Supplies
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
I have an HP 4V laserjet printer. It was printing fine until today. Both trays are full but it wont print. Form feed light is on, LC load letter message is flashing.
This is looking for Letter Sized Paper and presumably nit A$ that you normally use. This is usually caused by printing US documents and not resetting the paper size in the application before printing as the paper size will be embedded in the document in its original format.
Simply select the whole document and then reset the paper size to A4. You may need to check the document for lost images and tables but generally the text should be OK. Also the index and table of contents will also be affected as you will presumably have more A4 pages in the reformatted document that in the original.
Sep 21, 2009 | HP Office Equipment & Supplies
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Print size
My print is too small. how can i fix this problem?
Oct 08, 2008 | Canon PIXMA iP1600 Printer
Same lines won't print
Sorry, but this is impossible, as a "printer problem". This is clearly a "software/buffer/document" problem.
This can ONLY happen (on two printers, same results) if the DOCUMENT has "exclusive" properties or instruction sets, or "invalid data" for the "missing" lines. For example, you may be printing an HTML document with "DO NOT CACHE" meta tag or java instructions about specific lines or form entries. Many sites (like banks, registration, or encrypted mail/login pages) do this as a security measure to prevent critical data from being inadvertently printed (and ending up outside in trash cans for an ID thief to pilfer). Other possibilities: The lines are NOT text data, they might be IMAGES of text, and saved in a format the printer/buffer does not support. Any of these examples would allow the software to DISPLAY the specific (missing) lines of text -yet NOT print them.
To test my theory (almost a certainty really), simply open the document and select PRINT SCREEN key (or use whatever key commands capture the screen as an image). This copies what YOU see, to the clipboard as a single "image" file (instead of a variety of ASCII characters, images, and code).
Next, open "PAINT" in accessories under MSlop (or any IMAGE editor like Photoshop, Gimp, etc)
Select NEW and agree to the screen size you are using (1024x768, 800x600, 1280x800, etc)
Select PASTE from file menu (or CTRL/V keys). Your document will now appear.
Print the document. The "missing lines" will now show up! If the document is too long for one screen shot, you may have to scroll down, recapture (PRINT SCREEN, etc) and paste one or more images into each other before printing it as a single IMAGE.
Nov 18, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
172 people viewed this question
old marine
old marine
