Question about Smeg Refrigerators
Electrical problem with FA561XF
Our fridge freezer is 9 yrs old - has worked perfectly until recently when the appliance kept tripping the electrics. We replaced the motor - but 7 days after which it was working perfectly - began tripping again. The electrics in the house are fine as we have isolated the problem to the machine itself. Do you think it will be the compressor? There must only be two things that can go wrong surely?
    Top Expert:
  • Smeg Master
  • 12,962 Answers
Could be the breaker. Sometimes breakers just get old and will not hold when a power surge goes through it as when an electric motor first starts up. You have already replaced the compressor with a new one so I would check out the breaker situation. STAY with the same size breaker
Posted on Nov 24, 2013
Oceti
  • 51 Answers
SOURCE: fridge/freezer trips my circuit breaker
This sounds like a grounded wire in your defrost system. Start by finding the defrost timer and checking the wires. One may have been pulled loose or pinched while it was being moved.
Posted on Dec 13, 2007
  • 1314 Answers
SOURCE: Burning Smell
go to the appliaces store and buy an rc4 three in one reley its simple to put on and more than likely the culpret it you have any promblems putting it on reply to me esp if the reley thats on it is white
Posted on Feb 18, 2008
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
  • 31 Answers
SOURCE: Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Posted on Jan 07, 2009
  • 16 Answers
SOURCE: refrigerator compressor not working
unplug the fridge,remove the electrical cover on the compressor to see if any wires are burnt off.you may have a defective start relay,wire off or compressor seized,that age not cost wise to replace compressor
Posted on Apr 11, 2009
Samsung rsh1nhmh fridge freezer not turning on and tripping electrics.
sounds like electrical fault within your freezer any small fault will throw your contact breakers on your consumer box without blowing the fuse in the appliances plug
Aug 30, 2015 | Samsung Refrigerators
Find out why my freezer is shorting
Is your FREEZER is plugged into a wall socket which is protected by an EARTH LEAKAGE UNIT or RCD [Residual Current Device] ???
Most manufacturers advise NOT to have this type of appliance connected through an RCD as the start load required when the COMPRESSOR "kicks in" is quite large [especially in larger fridge/freezer units] AND will quite often TRIP your RCD. These appliances are better connected to a separate electrical circuit if at all possible and not protected by an RCD.
Sep 20, 2014 | Refrigerators
Fridge/freezer keeps tripping
Try to plug into different circuit, if it trips that breaker on the board then the appliance is probably at fault.
I must assume that you have not acquired something plugged into the same circuit as the fridge.
Sep 26, 2017 | Beko Refrigerators
Freezer not freezing.just put new thermastat in it
fridges and freezers work on the following principal: the freezer area is cooled and the cold air is circulated and shared with the fridge area.
So the keys to a good working unit are first to set the freezer so that it is at the desired temperature, then adjust the fridge control to get the desired fridge temperature
air flow is the only thing that the fridge thermostat controls, so keep the clutter in the fridge to a minimum
also dirt and hair dust etc build up on most appliances that have a fan so clean the areas around the back and bottom of the unit
remember any time you work on an electrical appliance unplug it first
lastly fridges with frost free designs need to have a clear drain from under the freezer all the way down to the bottom where the compressor motor is make sure this is also kept clean
if this fails to solve your problem then likely there is a leak in the system or compressor problem, but if this is the case your freezer will not work correctly either
remember the only cooling is done at the freezer znd cold air is sent through the fridge
lastly obviously the fridge and freezer are highly insulated and sealed and these are both important
Sep 02, 2011 | Refrigerators
My Hoover Nextra fridge freezer is 9 years old in perfect condition. Fridge has stopped cooling but freezer is working ok. I have turned up temp control to super, motor is warm but silent. What could have...
Hi, I have a Hoover Nextra Fridge Freezer and last night it tripped all my electric. When I plugged it back in, it sounds like it is starting, but then after a couple of seconds clicks off again. Any ideas?
Dec 26, 2010 | Refrigerators
Magic Chef refigerator/freezer stopped running
if you said stop running id assume that there is no power?? even with good electrical input..
for that instance, better check.charred cables.. if not there maybe a problem with timer itself..
Nov 05, 2009 | Magic Chef CTB1922 Top Freezer...
Refrigerator compressor not working
Apr 09, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kelvinator F/Freezer not working. Not fuse
Sounds like gas is out.Probably leaking Contact the dealer where you bought it,Should still have guarantee.Jan
Feb 12, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge not cold, freezer on bottom works fine
you have defrost problem 1 timer defrostthermostart or heater
Jan 19, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Refrigerators Logo
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
