Question about Kitchen Appliances - Others
Ccp600 stops turning when popping
The popper turns the seeds and then it shakes then it stops turning and the popcorn gets stuck inside.
    Champion:
  • 252 Answers
Check in this order.
-popping with oil, you can not dry pop.
-needle bearing at top of shaft is not missing
-block that cabinet gear is attached to is not cracked, or loose.
Beyond that, that model machine does not have any parts availble, it is not fixable
Posted on Nov 26, 2013
  • 9 Answers
SOURCE: popcorn popper
I am also looking for replacement parts for my ccp-509, specifically the kettle plug connector (female)
Posted on Feb 04, 2008
SOURCE: Salton Popcorn popper Model# PCST22Y
I owned one of these and it worked for 2 whole months.
It's a popcorn machine, how hard could it be? Make sure the stirring bar it tight on it's shaft, make sure the plastic bolt is tight. Add about 2 tablespoons of vegetable oil, and 1/4 to 1/3 cup popcorn kernels. Turn the machine on. Turn the machine off when the popcorn stops popping, or you might scorch the popcorn.
Posted on Sep 01, 2008
  • 3 Answers
SOURCE: Where can I find an instruction manual for this popcorn popper?
Go to http://www.nostalgiaelectrics.com/ and click on their customer support link.  At the bottom of their customer support page there is a box to enter the model number of your popcorn popper to get a manual.
Posted on Oct 07, 2008
SOURCE: ccp-510 popcorn popper pops only small amount and quits
I had the same problem when I firs bought mine. I followed the instructions as to the proportion of corn to oil. Forget the book! I found that with this machine I had to use three times the oil that was caled for in the instructions to get all of the corn to pop. Better yet, we started purchasing the premade kits with the oil, popcorn and salt. Since changing to both of these systems we have enjoyed GREAT ppcorn!
Posted on Mar 28, 2009
fossilruins
  • 114 Answers
SOURCE: Salton PCST22 Popcorn Popper Measurement
This is the typical measurements for salton poppers
for 3 quarts/litres of popcorn:
1 tbsp. (15 ml) of oil
1/3 cup (85 ml) of popcorn kernels
1 (15 ml)* of butter margerine
Posted on Oct 19, 2010
Popcorn popper isn't popping popcorn
If it heats up, your popcorn may be old and dried out. If it doesn't heat up and the stirring rod does not turn, check your power cord for defects. Procedure: plug in the popper (check both ends of the cord!), turn it on, and gently wiggle the cord right at the plug or where it goes into the popper, and watch the stirring rod to see if it moves. If it starts and stops as you wiggle the cord, you've found the break in the cord. Repair it or replace it (West Bend lists it online for $5) and be more careful with the cord in the future (never unplug by yanking on the wire, always pull on the plug itself).
If the stirring rod turns and there is no heat, the thermostat or thermal fuse is probably open. This can happen in some poppers if the air vents are blocked on the bottom. Remove the obstruction from the vents, let everything cool off, and try again. If it does not heat up from a cold start, there may be a blown thermal fuse inside. If you decide to replace the thermal fuse or thermostat, it MUST have the same temperature and current rating as the original.
Jun 17, 2016 | West Bend Westbend Popcorn Popper Stir...
Our store owns a gold medal #2656 popcorn popper but now it will not pop but few kernels. is it not getting hot enough or is it something else?
no you shouldn't have to do that. you are correct about the heat. what happens is it doesnt get hot enough for the moisture in the seed to expand to pop it, but its hot enough to dry it out so it cant pop. so it burns instead and you end up with a bunch of old maids. the thermostat is the first place to check.
Feb 05, 2016 | Gold Medal Products Gold Medal 2656 6 oz....
The unit only pops half of the popcorn
The symptoms of only pops half the popcorn is a hard one to trouble shoot.
1.Check your popcorn, old popcorn dries out. As it loses moisture its ability to pop is reduced. Popcorn only lasts about 90 days after opening the air tight packaging.
2. If it is a oil popper, make sure the stirring rod is turning during the popping cycle. They sometimes can stir, but once the popping starts the pressure of the corn can stall a motor. This results in the first half popping, and the second half burning on the bottom.
3. Popper is too cold. This has symptoms of a long, long popping cycle, and half the corn popping the other half just turning brown. Some machines had adjustable thermostats inclosed, most home units do not. Letting it pre-heat longer does not help, the temperature is controlled by a thermo-stat.
Mar 07, 2013 | Kitchen Appliances - Others
Popcorn machine model tpc-603 manual
Treat Time Model TPC-603
Turn on light and popcorn buttons, for 2 minutes to heat up the popper's kettle.
Then turn off the popcorn button, this stops the turning gears while loading oil and popping corn.
Warning the stainless steel kettle will be hot. Might want to wear an oven mitt.
1 tablespoon of oil (I use coconut oil) and 1/3 cup of popping corn. This makes est. 6 to 8 cups of popcorn.
NOW turn on the popcorn button so the gears start turning, this turns a wire on the bottom inside the kettle to keep the kernels from sticking or burning to the bottom.
If making multi batches, during the process it states in the manual to allow it to cool 5 to 10 minutes. I normally pop 3 to 4 batches and then let it cool down.
When finished popping, turn off both the light and popcorn buttons.
Dec 28, 2012 | Kitchen Appliances - Others
How to use
Put popcorn in bottom up to where the ring in bottom levels off for a maker full or less if you don't want a maker full. Cover with popcorn oil, I use the butter flavor oil. Put some butter inside of lid compartment and put lid back on butter compartment. Now just put lid onto popper and plug in. The light on side will come on and popper will start to heat. You will then hear it start to pop. Popping is finished when light on side goes out. Carefully lift the whole popper and shake right side up and then turn upside down and shake. Remove bottom, add some popcorn salt if you like and enjoy it right out of the lid. Delisious!!
Aug 13, 2012 | Hamilton Beach Butter-up Corn Popper Self...
I CANNOT FIND INSTRUCTIONS HOW MUCH OIL AND POPCORN DO I PUT IN AND WHERE? THANKS, ARLENE,///
I have the same popper and the instructions. You do not need any oil. There is a circle lid piece at the top of the popper. You put the pop corn seeds in that lid and then pour the seeds in through the hole at the top. The popper needs to be off while you do this. Once you've added the popcorn you can then turn on the switch located on the back of the popper. It looks like a small light switch. The popcorn will start popping and it may smell funny at first if you haven't used it or used it properly. You have to monitor it and turn it off yourself- using that same switch. And per the manual you need to wait 15 minutes before you use it again.
We use ours all the time and love it. Hope this helps.
Aug 21, 2010 | Nostalgia Electrics OFP501 Old-Fashioned...
Do i need to add oil to the machine
oil is not necessary for this brand of popper. The seeds will pop themselves. Just make sure you don't overfill it with seeds. You have to turn it off when it is done. You'll need a bowl to catch the popped popcorn. Wait 15 minutes after popping before starting again.
Aug 13, 2010 | Nostalgia Electrics OFP501 Old-Fashioned...
How to pop corn in a westbean corn poper
put about 2 tablesppons oil into the popper. Put 2 or 3 kernals into the oil. Turn the popper ON. When the kernals pop,.the oil is hot enough. Add 1/2 to 3/4 cup corn and enjoy when its done.
Feb 04, 2010 | Walter Drake Old Fashion Popcorn Maker
Cuisinart popcorn popper directions
If you are using the Cuisinart pop corn poppper, don't use olive oil. Use vegetable oil. Two teaspoons is enough with 1/3 cup of premium kernels. That is it. Turn on the machine and wait til it stops popping. I LOVE my new pop corn popper. I will not do the hot air one again. I always had kernels flying all over my kitchen and popped popcorn everywhere, The Cuisinart popper is the best....
Apr 10, 2009 | Cuisinart PartyPop Maker Popcorn Maker
Popcorn won't pop
Hints for getting the best popped corn: Don't pop popcorn in butter as the butter will burn before it can get hot enough. Popcorn pops best in temperatures of 400-460 degrees F. If your oil starts to smoke which happens at 500 degrees F, you've got it too hot. Any oil will work. Use enough oil to cover the bottom of the pan. For your health, you should choose a light cooking oil or better yet, skip the oil all together and use an air popper. The movie houses use yellow dyed coconut oil which does a great job of popping the popcorn although there are healthier oils you can use than coconut oil. To see if you have the oil hot enough, drop a couple of kernels into the hot oil. If it's hot enough, they should pop in just a few seconds. If you don't have a popper, any thick bottomed, high walled pan will do. Popcorn can even be easily made in a Dutch oven over a camp fire. When your oil is the right temperature, pour in your popcorn, shaking the pan to cover all the seeds in oil. Do this with the lid on to prevent burns should the hot oil try to splash out of the pan. Using a lid helps the kernels to heat more evenly and keeps the popping corn from flying all over the place. (If you are using a popcorn popper, shaking it isn't necessary because of it's rounded bottom.) As it begins popping, it's important to continue to shake a flat-bottomed pan. This helps any un-popped kernels to settle to the bottom of the pan where they can pop. As soon as you hear the popcorn stop popping, pull the pan off the heat and pour the popcorn into another container. It will burn if you leave it in the hot pan.
What can you do if you've done everything right but your popcorn still doesn't pop very well? As mentioned above, popcorn must have about 13.5 to 14% moisture to pop properly. This is because as the popcorn kernel is heated, the moisture inside the seed is turned to steam creating a huge inner pressure. As this pressure continues past the shell's strength to keep it in, the skin ruptures and the inner starchy layer of the kernel greatly expands and turns itself inside out. If the moisture isn't there, this pressure build-up can't happen. If you find your popcorn has excessive old maids (un-popped kernels) in it, the problem might be that it lacks moisture. Place 3 cups of un-popped popcorn into a quart bottle. Add a tablespoon of water, put the lid on and shake it to get water on all the kernels. If the water puddles in the bottom of the bottle, shake it again every 10 minutes until enough of the water has been absorbed to prevent puddling. Now let it sit for two or three days while the moisture is evenly distributed into the kernels. If it still doesn't pop correctly, repeat this process but add no more than 2 teaspoons of water the second time. Yes, it's also possible to get it so moist it won't pop, so definitely, don't add water a third time. Lastly, you can even take your old maids that didn't pop, rejuvenate them with water using the above process and re-pop them. (With a measurement of three cups un-popped popcorn, 1 tablespoon of water will increase the moisture content 2.5%. A teaspoon of water will increase the moisture level almost 1%. Air dried popcorn will probably never get below a 10% moisture content on it's own, so adding even two tablespoons of water would be pushing it, raising the moisture content to 15% - that is if it started out at a moisture level of 10%.)
Nov 06, 2008 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
Kitchen Appliances - Others Logo
63 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
