Question about ASUS F3Jv PC Notebook
F3jv catch release - ASUS F3Jv PC Notebook
I have released the hood on my 2009 Rio but now it won't catch as I close it.
Try lubricating the catch and release cable. Maybe cable hasn't released properly stopping the catch plate from springing back.
Apr 04, 2017 | Cars & Trucks
Instructions on how to replace the DC17 cyclone release catch
Hi Craig,
This isn't a part that we would recommend fixing yourself as there is risk of further damage to the product.
Please make contact with Dyson directly and give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
Thanks
Allan
Oct 30, 2015 | Dyson Dc17 Cyclone Release Catch, Part...
Door handles slack feels like springs dropped so cant open door
You can release the catch from inside just keep trying and thern you need to replace the door catch itself this is a simple job
Jun 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Im having a problem opening my hood on my 2000 land rover dis 1
You don't specify whether its just that you can't find the release catch, or whether the release catch is stuck / broken,
In the UK (Right hand drive car) the release catch is situated in the left (passenger side) footwell, within about a foot of the lower front door hinge. In a Left Hand Drive car, I guess this would be reversed (i.e. right hand side footwell). Pull, and it semi releases the hood. Next, walk to the front of the car, pull the hood up about 1" and insert your fingers about a foot left of center. Sweep to the right, and you'll release the secondary catch and the hood will be open.
However, if its stuck / broken, then ......
You need to work underneath the front of the vehicle - the idea is to get at the catch and release it with a long screwdriver flicking the catch to open the bonnet -or getting a grip of the cable if it is hanging loose ( i.e. broken ) then getting a grip of the cable with mole grips or even pliers - to pull and release the cable / bonnet.
Once the bonnet is open - you can deal with renewing the cable assembly, or greasing it thoroughly.
Feb 21, 2010 | 2002 Land Rover Freelander
The hood will not release to open. I released the inside lever & the hood poped up a little. In the grill there is a plastic "T" lever that you pull to release the hood. I have pulled it hard & the...
So I gather that the release inside the car has release the hood's primary catch, but the T handle is not release the secondary catch to allow the hood to fully open.
If this is the case, take some lithium grease or WD-40 (lithium grease is much better and lasts much longer) and spray it onto the catch assembly.
Try pulling on the T handle some more after a few minutes of the grease soaking in and see of that releases.
If that doesn't work, then take a long flat screw driver and press it against the catch gently hit the screw driver with a hammer (you should be trying to push the catch towards the driver's side of the car)
You may need someone to be pulling on the T handle as you hit the catch with a hammer. I actually had to do this with a jetta before....
Nov 20, 2009 | 1998 Volkswagen Passat
The pass. side bonnet catch will not release and open the bonnet.
Have someone lift on the bonnet while you pull the release handle.
Nov 06, 2009 | 1997 Mercedes-Benz E-Class
Renault clio bonnet wont open
Get a second person to pull bonnet catch and you push up and down on the bonnet whilst catch is being pulled. 1, cable possibly stretched, 2, look at bonnet catch under the coloum to see if wire is attached, 3, try and lie under car and look up the back of the bulkhead to see the catch and release it manually. Hope that helps.
Aug 17, 2009 | 2004 Volkswagen Golf
ASUS F3Jv PC Notebook Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
