Question about Tablets & eReaders
Hard reset eyo pad x6? anyone know how to do so?
Reset asus memo pad kow to factory settings?
If you cant reset your phone normally try hard resetting it.
  1. First of all, download the "cleardata.zip". You can get it from support.asus.com (e.g. Asus clear zip )
  2. Afterwards unzip it to your MicroSD card.
  3. In order to turn the device off press the Power button for a short while.
  4. First of all, download the "cleardata.zip". You can get it from support.asus.com (e.g. Asus clear zip )
  5. Afterwards unzip it to your MicroSD card.
  6. In order to turn the device off press the Power button for a short while.
  7. Select Clear User Data using the Volume buttons to navigate and Power key to select.
  8. When "Please remove installation media!" inforamtion appears on the screen remove the microSD card from your device.
  9. Success! The hard reset has just been performed.
If this doesn't work use the link below
ASUS ME176C Memo Pad 7 How to Hard Reset my phone HardReset info
Mar 17, 2017 | ASUS Tablets & eReaders
My x10 air pad needs password which I have forgotten
AirPad Reset Procedure - X10Wiki
kbase.x10.com/wiki/AirPad_Reset_Procedure
Apr 10, 2014 - If you play around and install a bunch of Apps to get familiar with yourAirPad you might want to know how to do a factory reset, that way you ...
Hard Reset from external buttons - X10 Community Forum
forums.x10.com > ... > Problems and Troubleshooting
Sep 11, 2011 - 6 posts - ‎2 authors Since the manual text and markings on the AirPad both describe a Reset button but the Reset/Mic hole on the AirPad is obviously just a Mic, the ... Airsight IP wireless camera - Password reset - X10 ...
Dec 26, 2014
X10 Airpad X, nothing works how do I reset it ...
Oct 3, 2012
X10 remote key fob won't register
Sep 19, 2012
AirPad 7p ICS / Gingerbread images - X10 ...
Mar 9, 2012
More results from forums.x10.com
Nov 28, 2015 | X10 AirPad 7" Android 4.0 Tablet
Does anyone know how to reset my kids Click N Kids tablet?
Hard reset or soft reset? Softreset, push a pin into the reset hole on the back or side. Hard reset, hold down vol- and power until the reset screen appears.
Aug 03, 2015 | Tablets & eReaders
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
How do I reset?
find a pinhole on the side and insert a paperclip and press for about 3 minutes.
Jun 21, 2014 | ASUS MeMO Pad HD 7
Screen locked and alignment wrong
To restart, press and hold the on button on the upper right of the device. Select 'Restart' from pop-up menu.
Not sure if you can recalibrate your screen.
If all else fails, perhaps you can try hard reset:
http://hard-resets.com/hard-reset-asus-memo-pad-hd7/
Try if you can avoid wiping data by selecting option not to wipe.
Apr 21, 2014 | ASUS MeMO Pad HD 7
I want to clean my eepad prior or giving to my granddaughter
The way to Hard Reset ASUS Eee Pad Transformer TF101-A1 to Full Factory Reset: For those who have any troubles with your ASUS Eee Pad Transformer, use the 10-12 sec force power off trick to attempt a fix. If that doesn't help, backup whatever you want to keep and perform a full factory reset.
Some times you will discover error when asus transformer hard reset, like not responding to your device or your gadget not responsible. Don't be worry, simply just restart this and wait a minute. I think's it's side-effects of hard reset ASUS Eee Pad Transformer TF101-A1.
Mar 05, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
I HAVE A TBS "T-PAD" THAT I NEED "DETAILED" INSTRUCTIONS ON HOW TO FACTORY RESET OR HARD RESET. I HAVE NO MONEY TO TAKE IT TO A REPAIR SHOP , HELP ME!!!
you should be able to go into you settings and find the factory reset there and before reseting it check to see if there is a back up and restore box if there is click it so when you turn the tablet back on you should be able to restore all of your apps and music content back.
Nov 11, 2013 | Tablets & eReaders
Tablets & eReaders Logo
205 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
