Honeywell ct87k4446 CALIBRATE
CALIBRATE THERMOSTATIC HEAT CONTROL
Honeywell part number is needed to determin which procedure to use.
Nov 24, 2013 | Honeywell Programmable Thermostat Heater
Thermostat not running furnace properly
Assuming that particular thermostat has a common mercury switch, the wiring behind or just inside the unit may be causing a strong enough magnetic field to throw off the balance of the mercury (liquid metal). The same scenario could be caused by other wiring or devices near the thermostat.
To test this theory, hold a compass as near as possible to the thermostat and wait it to come on automatically. If the needle moves when the switch engages, the magnetic field is strong enough the throw the balance off.
When tucking-in the wires for the thermostat, avoid winding the wires in a spiral or wrapping them around anything. An active current through wrapped or winding wires will create an electromagnetic field.
Oct 28, 2012 | Heating & Cooling
Is there a way to calibrate the Honeywell TH8000 thermostat
with my knowledge, there is no calibration, but setting only depend on. Please visit for further detail:
http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating
Hope it will be helpful?
Dec 20, 2010 | Heating & Cooling
Need to know how to calibrate my honeywell RTH221
This thermostat is not field servicable,you cannot calibrate this thermostat.May want to consider moving it closer to return air of equipment, for more accurate sensing of building temperature. Why do you feel that it needs calibrated? Suggest setting another thermometer on top to verify its accuacy.
Nov 24, 2010 | Honeywell Heating & Cooling
The unit says the indoor temp is 5 degrees higher than the actual temp in the house. Is there a way to calibrate the temp?
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 07, 2010 | Honeywell Programmable Thermostat Heater
How do you calibrate the thermostat?
Only the old analog thermostats can be calibrated, and even then its very touchy. The newer digital thermostats are not made to be calibrated.
Jan 10, 2010 | Honeywell Heating & Cooling
Honeywell Thermostat RTH7400D
The thermostat will not cut off the A/C until the thermometer reading gets to 76.
If there is not a heat source near/behind the thermostat which is causing the thermometer to read higher than actual room temperature, it sounds like the thermostat thermometer is out of calibration.
There are ways to calibrate it, but much to involved to go into here.
One solution is to just set the thermostat at 80, knowing that it's really set on 76.
Another solution is to replace the thermostat.
Charlie
Aug 14, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
