Question about Car Audio & Video
I have a AC 4000 1d planet audio amp my protection light keeps coming on
  • Gizmo5000 Dec 10, 2013
    Hi Cle Williams, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: protection light keeps comin on
Unfortunately, P/A does not release schematics - even to repair techs. You have to find a knowledgeable repairman, or ship it to P/A.
1-888-990-1236 for support, and RA# info.
Plan to be without your amplifier, as NEW WARRANTY repairs are backlogged approx. 6 mo.
Rule out external problems by hooking it up to an isolated bench power supply.
If planning on doing your own repairs, see this site for info.
P/A has an ONLINE SUPPORT WEBSITE to order parts etc, and may be a useful resource as well. Do some fishing, and you may find what you're looking for.
I will too, and post any findings.
Posted on Jan 19, 2009
etirbynnor
  • 655 Answers
SOURCE: Protection light keep coming on
Make sure your head unit is off.
Reset the amplifier using the manufacturers specified method. Usually this is just power down briefly and then back up. I usually pull the amp fuse and make sure all LED's on the amp go out. Wait 10 seconds, and then put the fuse back in.
If the LED comes back on when you reconnect power, without the HU being on, you've got a bad amp.
If the LED does not come back on after reset, then check for short circuits on the speaker leads. Still leaving everything off, from the amp terminals, remove both wires to a specific speaker and check for shorts.
Posted on Mar 24, 2009
jryc32
  • 408 Answers
SOURCE: Protection light is on my REM 4300 planet audio
That means that 2 wires must have touched and the protection light came on to prevent further damage.. There is usually a reset button somewhere on the amp and pressing it should reset that light
Posted on Sep 08, 2011
  • 444 Answers
SOURCE: I just bought a planet audio amp from a friend,and
Not connected up poperly.
Posted on Oct 27, 2012
Why this planet audio protection light always comes on when i turn up the car audio
The amp in question is a very entry level amp. Meaning it needs to be ran at moderate ohm load. And have plenty of power to feed it. Check your grounds. Pos. Etc.
Feb 03, 2013 | Planet Audio AC1500.1M ANARCHY CLASS AB...
What normally burns out in an amp for the protection light to come on?
The protection circuit is in place to try to protect the amp and speakers from damage should something go wrong, as in a shorted speaker wire, an under or over power situation from the car's battery or alternator or it may be be driving by a speaker load that is too low. You can check your owner's manual for further details or look on line.
Feb 20, 2012 | Planet Audio RX2.400 Car Amp
Protection light is on my REM 4300 planet audio amp
Sep 08, 2011 | Car Audio & Video
Red protection light
make sure amp is not grounded out or shorted out like if u miss and touch ground to power or the other way around protect light usaully comes on be resets once u turn the amp power off then back on . if that don't fix it maybe ur amp needs some repairs inside.
Jun 06, 2010 | Planet Audio VX4002 Car Audio Amplifier
What does the red and green light mean ???
red and green light? there is most likely a protection and a power light. The red I assume would either be a protection light or a clipping light signal. Does the amp kick off then these lights kick on red then to green?
May 31, 2010 | Planet Audio VX4002 Car Audio Amplifier
Mar 21, 2009 | Car Audio & Video
HELP
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 24, 2007 | Planet Audio VX1502 Car Audio Amplifier
Kole audio q1-3000d
This amp is similar to many of the planet audio class D amplifiers. These amplifiers have quite a few problems. If the amplifier has failed, it needs to be serviced by someone who is familiar with the amplifier.
Do not repeatedly replace the fuses. It will lead to more damage and a more expensive repair.
Nov 12, 2007 | Kole audio Q1-3000D Car Audio Amplifier
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
