Question about Sub-Zero 690 Side by Side Refrigerator
Control Panel inside subzero refrigerator broke. Can this wire part be ordered and replaced
The wire runs through a grommet on top inside to black snap connector on control panel. Some of the wires pulled out and tore from the connector and are hanging. Is this control panel wire a part that can be ordered and replaced?
  • Sub-Zero Master
  • 15,937 Answers
What is the model number?
Posted on Nov 24, 2013
4 Suggested Answers
JOE LLAMA
  • 26 Answers
SOURCE: Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Posted on Mar 31, 2008
SOURCE: Refrigerator light goes out
look like door switch
HTML clipboard http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Posted on Aug 19, 2008
  • 291 Answers
SOURCE: Ice keeps forming inside on the back panel of mysubzero model 550
If the ice is on the back panel especially a block of ice in the middle left part of your panel, then you have a sealed system problem. Check to make sure that your condensor coils above the refer are clean, and if it continues to have an ice block then you have to have a technician come out an do a major repair. This is not something you can do yourself, most subzeros have a 6 to 12 year sealed system warrantee that covers either all of the repair or just parts. This is an expensive repair if it is not warranteed, but when the refers cost 8000 to 10000 new it is usually well worth it. Most often it is the result of a slowly leaking evaporator, though most inexperienced technicians replace the compressor first, so make sure you use an experienced Sub-Zero technician. Good Luck, Appliance Specialits
Posted on Dec 14, 2009
Wire to control panel on subzero refrigerator broke off
Any part can be replaced or repaired, if you can see where the wire origionally sat, then it may be possible tosolder it back on.
Nov 24, 2013 | Refrigerators
MY kENMORE HAS FREEZER ON BOTTOM, the upper refridgerator isnt cooling properly ,the fan is running. The freezer is working fine.
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 Phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Hope this will help to solve the problem....
May 17, 2011 | Kenmore Refrigerators
My DGS18LBR GE Refrig does not cool the top refrigerator, but the bottom freezer seem to be find. Is it the dual control unit?
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired to gather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Take care in solving the problem......
May 12, 2011 | GE GDS18LBR Bottom Freezer Refrigerator
How do you replace the thermistor
remove the wire from the control board cut off plug use tape and tape the end that goes inside fridge to it. go in fridge and remove the grommet from the wire and pull the new thermistor in
Oct 24, 2010 | Dometic RM2652 Refrigerator
Sub zero 690 light switch won't come on
It is probably the switch - they go bad with some regularity. See this link http://www.repairclinic.com/SSPartDetail.aspx?s=t-subzero+690-%3d%3di1557694&PartID=1557694
You can't buy the part from them anymore - call subzero and get the parts dealer nearest you.
As you will see the light switch is easy to replace - just open the top panel to your unit (after turning the unit off) and unplug the wiring harness. Then as you see in the photo of the part in the link above there is a small retaining clip that you just apply a little pressure to to push the switch through. New switch is installed in the reverse order. I haven't ordered one of the switches in a while but I think they are not more than $10.
Sep 08, 2010 | Sub-Zero 690 Side by Side Refrigerator
My double door KIC fridge(Freezer on top and fridge bottom)The freezer works fine but the fridge does not cool sufficiently, with the result that the compressor runs constantly. I have changed the...
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator 's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the advisable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Good luck and take care....
Aug 13, 2010 | Refrigerators
The milk is not that cold in my subzero and the icecream is very soft
Most problems related to subzero are the condenser coils. They are the lungs of you refrigerator and need to be cleaned every six months. Remove the top panel on the right hand side you will see your coils they probley look black but they should be silver. Take a vacuum cleaner with the brush tool and gently clean the coils. This should solve you problem good luck.
Jun 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
Subzero 590: freezer works, refrigerator not cooling
This is a Sub Zero and many technicians do not realize that these units most all run on 2 separate systems. 2 cold controls 2 compressors 2 evaporators. They share a condenser and condenser fan motor. What you are describing is most likely a bad cold control. It is pretty common for these to get some age and go bad. If you are very savvy with repairs yourself then if you access the compressor area and feel that the compressor on the right is cool and the compressor on the left is warm then you know that the ref. compressor has not been running. UNPLUG THE UNIT OR CUT THE BREAKER OFF. Remove the shelving from the fresh food section and the cover to the lights and the panel below the lights and lean the back panel forward to access the cold control. You will see 3 wires to the cold control. The green wire is the ground wire of corse. Unplug the other 2 wires remembering their location on the control unit. Take a jumper wire and jump these 2 wires. If when you power the unit up the right side compressor comes on then you know that your fresh food cold control is bad. Replace fresh food cold control.
Feb 01, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
37 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
