Question about Panasonic NN-S963BF Microwave Oven
NN-S963BF begins operating when door is opened
Without setting cook power and time our microwave begins operating when the door is opened and stops operating when the door is closed. Seems to heat food fine and not sure if it's cooking when door is opened. Light comes on, tun table rotates and oven makes same sound when it's actually cooking. Any ideas how to fix. We've had this for 10 years without any problems.
  • Panasonic Master
  • 18,060 Answers
The door switch is bad. https://www.partstore.com/Model/Matsushita/Panasonic/NNS963BF.aspx
This site has the most parts. See if there is a contact list so that you can ask about the switch. I dont see it listed as a stand alone item.
Posted on Nov 24, 2013
  • 2,113 Answers
Duplicate
4 Suggested Answers
SOURCE:
  • 1214 Answers
SOURCE: Panasonic Microwave oven - cooking operation stops afer 2 seconds
Sounds like a short in the microwave circuit. One or more of the following four components has failed -
Transformer
Magnetron
Diode
Capacitor
Repair is not for the amateur, unless you know how to take things apart, and put them back together EXACTLY as the were found.
Parts are available on the Net, and you can get the P/N's off the old components to identify suppliers of the new ones.
Don't try and measure resistance of the diode. It's impedance is far too high to get a good reading. They're cheap anyway. Always replace the capacitor, they're cheap too. No way to test the magnetron, and the transformer is not easy to test either.
Posted on Jan 16, 2009
MicrowaveSvc
  • 9156 Answers
SOURCE: panasonic microwave nn-s963bf making grinding noise
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can
order parts for this brand from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Posted on Mar 06, 2009
garing
  • 998 Answers
SOURCE: Panasonic Microwave turns on and tray rotates when door is opened
check the door switches
Posted on Aug 16, 2009
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
My nn-s963bf starts operating when door is opened
The electronics have lost their marbles. When a nuker door is opened the safety switch connected to the door is designed to turn the unit off and not on. You just better work fast when you put stuff in or take it out!!!!!!!
Nov 24, 2013 | Panasonic NN-S963BF Microwave Oven
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
My microwave want cook
Hello
and/or circuit breakers, particularly in the case of recent power failure, and reset if necessary.
Unplug the microwave, wait 30 seconds and plug back in to the power supply to reset the microcomputer.
Open and close the microwave door firmly and press "Stop/Reset." Select a new cook time and press "Start."
Ensure a proper cooking temperature and/or time is chosen, as low cooking temperatures or short cooking times may prevent the microwave from heating food appropriately. Press "Power Level" to ensure the microwave is cooking at 100 percent power.
Contact an authorized service technician if the problem is still unresolved.
Oct 04, 2011 | Sanyo Microwave Microwave Oven
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Just purchased our Cuisinart Stainless Microwave, plugged it in, read the operational instructions and set the clock. As a test, we tried to heat water....does not work. Any suggestions?
Yes! Take it right back to the store for exchange, cause could be a bad magnetron "that heats food" and a couple parts that work together with the magnetron,or there may be issues with the keypad, none of these will be cheap to fix.
Jan 30, 2011 | Cuisinart CMW-100 Microwave Oven
We have a frigidaire microwave and in the middle of cooking, the motor stopped. The clock and cook time continued to work, but no heat. We've tried using at half power, on defrost, etc. but nothing seems...
What you are saying the microwave stop work like heating,but but the clock counts down.If it is stop heating then there is a rest on or near the magtrogron.Once it cools down it start back heating.Open and close the door will reset power to the magtrogen{sorry about the spelling].Look for loose connector,or replace the click zon it should have a small red buttom on it.
Mar 18, 2009 | Frigidaire Over-the-Range Microwave
KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 11, 2007 | KitchenAid KCMC155J Convection/Microwave...
Panasonic NN-S963BF Microwave Oven Logo
182 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
