Question about Video Cameras
I need national inverter dv- 505-750 sa
National inverter dv 505-750 sa in put :ac 220-200 v 50/60 hz out put: 1.7 kva 5.0 a
SOURCE: kls-320ve-j inverter/backlight board
If you have to ask these questions then you should leave it alone. The high voltages produced by this board are LETHAL ;)
Posted on Aug 19, 2008
  • 3 Answers
SOURCE: need ac adapter for use
I just bought a replacement power supply with the round 4-prong plug for the i333 from lcdpayless on e-Bay.  Contact them and maybe they will sell you the plug only. Link is below:
http://cgi.ebay.com/24V-AC-adapter-for-Sharper-image-iTower-SI333-speaker_W0QQitemZ360150936670QQcmdZViewItemQQptZOther_MP3_Player_Accessories?hash=item53daab2c5e&_trksid=p4634.c0.m14.l1262&_trkparms=%7C301%3A1%7C293%3A1%7C294%3A30
aschaef
Posted on May 07, 2009
  • 70 Answers
SOURCE: 1 KVA inverter battery not charging
if its an inverter then the car battery is not supposed to charge but if you trying to charge something with the inverter then it might be the fuse or something internal on the inverter
Posted on Aug 03, 2010
Pensivecoder
  • 86 Answers
SOURCE: DVE AC ADAPTOR, model :NO.: DV-91A, INPUT :
You dont need an exact replacement for your router to work, just check on radio shack for generic adaptors with the same specifications, they would work fine, make sure voltage is the same as well as wattage...thats all that matters, and obviously input being 120vac, Hope this helps..
Posted on Oct 25, 2010
epettingill
  • 175 Answers
SOURCE: Have (2) 7 kVA's &
Please Call me at Gruber Power Services tech support. It's free tech support. Ask for Eric
Posted on Aug 24, 2011
What power inverter is required to back up retail general store?
Hello satyam, If you are looking for best inverter for your shop, then luminous inverter is best option for you. I think you need at least 5 kva UPS for your large area shop. Buy Best Luminous Inverter UPS for Home Online at Best Price
Oct 12, 2017 | General Televison & Video
What is the general specification of Genset 20kv?
Generally 20 Kva power generator can produce more power. The voltage used in this 20 kva generator is 3 phase with frequency 50 Hz. 20 kva generator engine is already very enough for use on buildings that require large electrical power or public places such as shops. According to me HARGEN provides the best high quality genset.
To fill the fuel tank to the full required 62 liters of fuel in order to use this 20 kva generator engine with more leverage.
20 kva generator engine is also issued a noise that can reach 61.7 db or can be heard up to a distance of 7 meters away from where this generator is located.
Sep 11, 2017 | Cars & Trucks
We are from South Africa and moved to Canada what do we need to change the volts and hz to use our Bernina Bernette embraudery machine?
probably nothing as they make the machine for the country's utility power supplies
you will have to go to places like JAYCAR to get a step down transformer or go to an electrical retailer to get an inverter to do what you want
go to a sewing machine repair shop and discuss the problem
Nov 25, 2016 | Bernina Sewing Machines
Generator had been running for 3 hours with a/c and refrigerator and lights (on concession trailer)when we experienced a loss
the unit has gone into over load
The total power requirement has exceed the output of the generator
for example if the generator is a 2.500 kw or kva then it will generate well at 1.8 kva or kw but it will not run forever at 2.5 kva -kw
When a ac is running the power requirement will be constant on the generator and with the fridge as well then the load will be at the maximum out put of the unit.
when the fridge starts again the extra load will exceed the max out put of the generator and it will slow down ( lights dimming ) and eventually go into overload mode
have an accredited electrician calculate your maximum load requirement for an external power supply and then get a unit that is at least 15.. kva kw better that required
generally fridges use 1000watts , ac conditions will draw over 3000watts and any thing else adds up . I am guessing that your generator is only 2500 unit
Apr 12, 2015 | Northstar Electrical Supplies
Does any one know how calculate power saving comparition in VFD and DOL?
1. Refer from the devices manufacturers guide to attain written instructions complimenting operations also complimenting setup from anothet location. 2. Visit the devices manufacturers online networks during business hours to attain expert assistance to operating devices .
Oct 23, 2014 | Electronics - Others
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
I live in New Zealand which has 240 volt supply on the grid. The zantrex 2000 works with an input supply of 120 volts. How can I use it?
Hi, OK, there are two ways to achieve this. One. Using an external STEP DOWN Transformer, 240 V AC, to 120 V AC. The ONLY thing that matters is KVA. As long as the KVA is the same ir will work. This means as long as the Output Voltage and Current are the same, it's irrelevant whats on the Secondary. So if
The second, is to remove the existing transformer, and substitute with an exactly the same Secondary Outputs, BUT with a 240 V AC,. Input winding. Most likely it is a simple step Down transformer anyway, that steps down, whatever the external voltage is, down to say 12 -18 V AC. Therefor ANY suitable 240 V AC transformer with the SAME secondary winding(s) will work, no problems. You can even get some transformers Overwound, for 240 V AC, a very common thing, depending on transformer construction. There are a few transformer manufacturers in the "Yellow Pages" contact one of them and inquire.
As a tip, sometimes the existing transformer has TWO 120 V windings, and sometimes only ONE side is used, for US power, and for 240 V AC, you simply connect the other winding in series, and NOW you have got your 240 V AC to whatever.
Sep 01, 2010 | Inverter Xantrex MS2000 Sine Wave Charger...
Aug 01, 2010 | Whistler PI-1200W 1200-Watt Power Inverter...
AC not stops working when compressor starts.
how many amp service do you have in the house
May 17, 2009 | Heating & Cooling
Video Cameras Logo
55 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
