Question about Refrigerators
Wire to control panel on subzero refrigerator broke off
Can this part be replace?
    Champion:
    Habit-Forming:
  • 275 Answers
Any part can be replaced or repaired, if you can see where the wire origionally sat, then it may be possible tosolder it back on.
Posted on Nov 29, 2013
2 Suggested Answers
  • 135 Answers
SOURCE: Subzero 690 refrigerator. Freezer is cold but main
if u live near madison . i fix it charge $65 labor
Posted on Jan 13, 2011
Lights on but not cooling, LCD display is lit up but blank
The LCD is light up by the lights in the refrigerator, so that doesn't mean the board is turning on just the interior lights. I would have to recommend a service call.
Sep 21, 2013 | Sub-Zero Refrigerators
I have a subzero BI42 SD fridge. Just replace the water filter. It now does not make ice. Turned on the icemaker but get a blinking ice indicator on the control panel. Looked into the trouble shooting...
this is abrand new fridge.if the ref is less than 2 yr old. better call a tech. your problem FOR SURE. water valve, ice maker, or a combination of 2. also tell your tech. to check the arm in the i.m. and the brackett. do not trty to replace the ice maker. is a little tricki.(SUBZ.less than 2 years old is cover by the manufactor subzero. zero money for you.)
Apr 19, 2010 | Sub-Zero Bottom Freezer Refrigerator
Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Oct 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Refergerator side back panel freezing up with ice
2 posibles problems. if the ice is only about 4 an 8 inches you have a seal system problem.(evaporator freon leak) need replace the evaporator asap. if the ice cove a big part of the back wall you have a thermostat problem. for replace the evaporator better call a tech. remember to call a subzero factory authorized company. maybe still under some warrantty> good luck LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU....... THANKS
Sep 06, 2009 | Sub-Zero 561 / F
We have been getting service code 50 for our SubZero -- it;s a 690 model fridge/freezer. I cleaned everything however over last three weeks the error repeats. I reset the board by pulling power from the...
Error code 50 means excessive refrierator section compressor run. Possible causes include: dirty condenser, stopped condenser motor, faulty termistor or an evaporator refrigerant leak. If it is a refrigerant leak it usually shows up as frost or water driplets half way down on the back wall. Clear codes by holding the alarm button in for 15 seconds.
Aug 26, 2009 | Sub-Zero 632 / S
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
My lights are off in the subzero 650.
replace light bulbs or light switch...... is cooling ok?
Feb 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Mar 12, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
