Question about LG Remote Monitoring Laundry System - RLM20K
Help I have the LG remote monitoring system and no matter what i do, the washer never gets reconized by the monitor only the dryer. I was sent a new set becuse we thought it was the the equip, but as it turns out still no luck any suggestions.
  • 1 more comment
  • tach Mar 23, 2008
    I have the same problem. Can someone send me a copy of the manual? ...or describe the reset process in this log?
  • Anonymous Jan 17, 2009
    I am having the same problem with my remote not recognizing the washing machine. I am on my second remote. Both worked fine for about 2 months, then suddenly stopped working (for the washing machine). I have tried resetting the codes but no luck.
  • tare_girl Jan 17, 2009
    I am having the same problem the LG remote monitor not recognizing the
    dryer. I am on my second remote and it just failed like the first one.
    Both worked fine for about 2 months then suddenly stopped recognizing
    the washing machine. I have tried resetting all the codes but no luck.
    New Friend:
  • 60 Answers
Follow the directions in the remote monitor system owners manual on clearing and resetting the home code. That should take care of the problem.
Posted on Dec 20, 2007
SOURCE:
LG monitor will not turn on.
My guess would be a bad power board. The capacitors will blow on them and cause this issue. If you can solder you can take it apart and replace the caps or buy a new Power supply board for your monitor and replace it. The caps hold power for the monitor and when they go bad they may try to hold a little power until they are incapable of doing it anymore. Best way to find out it to unplug monitor from power and computer and take the back off. A blown capacitor will look like a small round thing sticking up and it will look like its oozing something out of it or the top of it will be rounded and bubbled.
Apr 04, 2013 | LG Electronics M2262D 22" LCD Monitor
Hello i have a 19 inch LG M197 WDP monitor/tv, when i switch it on the screen is white with a little gray bock that flashes and slowly moves across the top of the screen reading v3.02.0 which i presume is...
I also had an LG M197WDP tv/Monitor with the same problem. It comes straight on when plugged in, but with the blank screen and scrolling version number across the top.
The solution:
1. Use the remote control (check batteries first)
2. Point at the working TV and press either MENU or EXIT
3. Static should be seen on the screen.
4. Switch to standby using the remote, by preesing POWER button.
5. Switch back on using the POWER button.
All should then be working normally
Jun 20, 2011 | LG M197WD-PZ 18 inch LCD Monitor
I am having a blurred display on my LG flatron Ez T710BH 17 CRT monitor. The pictures are better but the text is almost illegible. Please help me. The problem started when I sent it to a repair shop. I...
Ya gotta be kidding! You still have a CRT monitor? CRTs have a focus adjustment around the neck of the big tube. The shop screwed it up. Spend $50 and get a nice used LED or LCD flat screen.
Sep 04, 2017 | LG Flatron Ez T710BH 17" CRT Monitor
Not turning on, on switch flickering, just changed drain pump.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
8uy
Jun 02, 2009 | LG WD 14311 RD Monitor
Replaced power supply, monitor won't come on.
Could be that you need the disc to start up your new monitor to get it to reconize on your system - It is just like setting up a new mouse, they always come with a disc.. If you have another monitor hook it up and go to the manufactures website and download their driver. This should fix your problem
May 16, 2009 | Computers & Internet
LG W2452v - Monitor turns on and off every 5 minuites...
I solved the problem by not using the DVI cable. I used the D-Sub cable. If your pc does not have D-sub connector then use an adaptor. I not only solved the problem but got the full 1920 x 1200 resolution
Mar 05, 2009 | LG Flatron L2320A 23" LCD Monitor
Drivers
go to http://www.Lg.com support drivers you need to check for you model make serial and windows tipe if you can not get it from there you can go to http://www.driversguide.com fill out the registration and go to the LG monitor and look for your model serial and windows system
Dec 14, 2007 | LG Flatron 775FT 17" CRT Monitor
Washing Machines Logo
179 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
