Question about Frigidaire Refrigerators
Ice cream and breads only freeze if its set on highest level
I sometimes also notice a very thin layer of frost inside on cartons or walls like the door was ajar but it wasnt.
    Top Expert:
  • Frigidaire Master
  • 12,907 Answers
You have ice buildup on evaporator coils caused by self defroster not working. Check defrost timer and defrost heating element for proper operation.
Posted on Nov 28, 2013
SOURCE: water freezing at bottom of freezer, food not freezing
Maybe a bad defrost timer
Posted on Dec 08, 2007
  • 45 Answers
maybe? yeah but have you checked that the drainage hole is is clean and clear from any trapped dirt, that is sometimes a major problem, it stopped my freezer from functioning for weeks!! but the day i cleared it the water was gone, and the freezer was working as good as new!
Posted on Dec 22, 2007
  • 3 Answers
SOURCE: ice build up
Check that the door is closing properly otherwise the freezer will be working overtime to cool and ice will form. If the door seal is good, it is possible that the thermostat needs to be checked.
Posted on Oct 02, 2008
  • 1462 Answers
SOURCE: not cold enough to freeze ice cream, frost on back wall
is it a frostfree type?
Posted on Nov 16, 2008
  • 82 Answers
SOURCE: GE GSS27RGMFWW Freezer Not Freezing..
Hello. I just now found your post here on fixya. Do you still need help with your frig?
Posted on Dec 05, 2008
Freezer ice cream is soft and so are breads but didnt used to be until now
That sounds so much like the thermostat needs replacing. Not so easy on a freezer as it is a fridge. On a fridge it is a 2 minute job, but on a freezer, the wire on the back of the thermostats generally runs up and down the rails of the top shelf. Only way to check is to replace, of course, you ave to disconnect from the mains first! Good luck
Nov 24, 2013 | Frigidaire Refrigerators
I lost the instructions for the Baskin Robins ice cream maker. Are there some available online?
General Ice Cream Maker Instructions... This should give you the general idea on how to use any ice cream maker. Typically, the ice cream straight out of the maker will be soft so the ice cream typically goes into the freezer to "set"/harden the ice cream.
The ice cream maker should have a container inside of the larger outer container. The ice cream mixture goes into the inner container and the outer container holds the ice-salt mixture.
1. Prepare your ice cream mixture and chill.
2. Pour the chilled mixture into the inner container about 3/4 fulls.
3. Insert the Mixing paddle and cover the inner container
4. Turn on motor and while it's running, add 2 inches of ice on the bottom of the bucket. Sprinkle about 1/4 cup salt over ice. Continue layering ice and salt until the ice level reaches the top of the rotating ice cream can.
5. As the ice cream maker runs, add more ice and salt to ensure the ice level is above the mixture level in the inner container.
6. In about 20 to 40 minutes, the ice cream maker should stop churning.
7. Remove the lid and pack down ice cream in the can.
8. Cover and place ice cream can in freezer for several hours to harden. http://www.epinions.com/review/Baskin_Robbins_Ice_Cream_Maker/content_25404149380 The instructions are on the "mix" packs, all you need is the half & half, rock salt and a freezer. Freeze the canister, insert the canister into the receiver, add the mix and the half & half (on the pack), cap it add the ice around the canister, add the salt over the ice, turn on the machine and stand back.
May 05, 2011 | Toys
White mountain freezing problem
NO SOLUTION but I have this same problem with my machine.
Jul 04, 2010 | White Mountain F-69204-X Ice Cream Maker
Water pooling and freezing on bottom of freezer. Cools poorly.
Check door gaskets if sealing properly? Check to verify freezer is level? If all of the above are fine then look at your drain for the condenasation. It's located at the bottom of your back wall underneath the aluminum evaporator that the cold air comes from. (You will need to remove the back panel inside of freezer wall To get to the drain. It's probably plugged and frozen over. Do not use a chisel or knif instead take a cup of hot water and pour it Oder the drain area and let it sit. (Your freezer will not be running for an hour or so so think ahead or work fast). That being said you have to unplug unit first :-) once you remove all ice push a straw or something through drain to verify its draining through. You can also flush more water down it to watch it drain showing you that it's working. Start with this first.
Jun 22, 2017 | Kenmore Freezers
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore refrigidaire, bottom freezer
It depends somewhat on the quality of ice cream. Some brands freeze easier than others. One reason is cheaper brands have more sweetener/sugar in them.
I think if your freezer is freezing water into ice cubes, it should freeze ice cream of good quality.
Try putting the ice cream where the ice cube tray is and verify ;this.
Mar 31, 2008 | Refrigerators
Water freezing at bottom of freezer, food not freezing
Dec 22, 2007 | Maytag 23 cu. ft. Side-by-Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
