Question about Paragon 8145-20 Defrost Timer
How to set the timer of timing moter 8145-20 - Paragon 8145-20 Defrost Timer
  • Paragon Master
  • 5,089 Answers
Copy following links:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#set
http://waterheatertimer.org/images/8145-work-image.jpg
Install defrost trippers on dial at times you want defrost to begin.
8145-20 is generally time initiated, and temperature or pressure terminated... but you can set the defrost duration on smaller center dial..and this setting will terminated defrost cycle mechanically if the pressure or temperature sensor fail. Then manually rotate timer dial until current time lines up with time marker in upper left side.
Gene
h.
Posted on Nov 24, 2013
Dryer works, auto dry doesn't advance
Does it advance in timed dry? If not the timer moter is bad, if yes the cycling theromstat will have 4 wires on it and it needs to be changed
Oct 19, 2011 | Amana DLE330RAW Electric Dryer
Dryer won't start
Is the door switch working properly?
Sep 14, 2007 | Maytag LSE7806A Top Load Stacked...
I have an old Searsd Coldspot upright freezer, Thr
on the side of both defrost controls is a diagram black is normally power white is normally nuetral wire the black wire will go to the center of the switchs defrost heater
will be on one side compressor to the other white to the clock moter green was hooked to the metal case if you have a mutitester the clock moter will have constant continuity even after the timer has been turned till it clicks the heater will go on the contacts that have continuity for the shortest amount of time
on the back of most older units was a wiring diagram constant defrost has power even when t-stat is set to off
cumulative the defrost only has power when compressor is running the diagram on old defrost timer should be simaler to the diagram on the old defrost timer the lighter colered tab is normally white wire
hope you have a tester but if you are inclined hook up black and white only turn control till clicks when you have the black wire in the correct position the moter will run no matter where the control is turned
then find wire that starts compresser it will need to be placed on the switch that maintains contact the longest leaving the
heater wire to hook to the contact that stays closed for 20 to 30 minutes
most defrost controls wire the same be careful wiring is 120 volt
Dec 13, 2009 | Cell Phones
My Jacuzzi jetted tub has stopped working. During the last 3 or 4 times used, it initially wouldn't work when I turned the timer dial switch on, however, after a few minutes it started working. It also...
other than your switch , it could only be the moter or connection to it. always make sure you have enough water in the tub before turning it on or you'll ruin it.
Sep 17, 2009 | Home
Describe your Intermatic & Indoor/Outdoor Rain Tight Timer Problem I have the model T104 I think, stamped E10694 on it. I can set the start/stop but it does not come on, I have...
is the dial turning, or is it in the set mode, were its not engaged. if it does turn are the trippers tripping the levers. if everything is working make sure the trippers are not bent, this will keep it from engaging anything.
Aug 02, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Won't heat, won't advance on auto, won't shut off on timed. air only fine
I suspect you have a timer motor problem. My experience has been in most cases you cannot buy just the timer moter, you need to purchase the entire timer....at costly expense. If you can get your ear near the timer while running, first listen to hear the motor. Usually when the motor is going to quit, it becomes fairly noisy. In any case, the timer should advance,
Apr 22, 2009 | Dryers
Wont agitate on its own
IT SOUNDS TO ME LIKE THE START CONTACT IN THE TIMER IS NOT MAKING A CONNECTION UNTIL YOU PULL OUT ON THE SHAFT OF THE TIMER. MOST TIMES IT NEEDS A NEW TIMER.
Jan 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Paragon 8145-20 Defrost Timer Logo
124 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
