Question about Home
Need to change battery
Changing battery
  • 2,113 Answers
Make sure to only use the newest preferably not a bargain brand alkaline battery. Then press the test button for 10 seconds or more to reset all
Posted on Nov 24, 2013
Car was running fine until new battery was installed,now car stalls when you idile
Just check the new battery is fine . take a multimeter and keep at both the ends of the new battery and check whether the charge is optimal .
Sep 05, 2015 | Cars & Trucks
York stamina treadmill
what is the power source? does it work by batteries or AC or both.
If it works by batteries check the batteries to determine if they are good or bad and need changing.also check for short circuits or corrosion in the operating panel controls.Ususally it is just the batteries that need changing and the compartment holding the batteries need to be cleaned.After cleaning and changing the batteries,make sure that you dry the soluables with a paper tawell or a clean rag,After you have done this the unit should return back to nomal operation if it does not you may have a problem with the computer itself and if that 's the case you will
need to find diagnostic codes designed to troubleshoot the computer.Hopefully just the battery change and the clean up will
be sufficient to return the unit back to intact.
Nov 09, 2013 | Exercise & Fitness
2006 bought, stopped working, does it need a battery change? Is it worth changing the battery?
It looks like you paid over $100 for the watch, I suggest to give a try changing the battery. Actually if you take it to some watch repair shop.. some of them will NOT charge you if replacing the battery does not bring your watch back to life!
I hope this helps!
Marcelo
Oct 23, 2013 | Seiko Coutura Chronograph Watch
Is changing the battery hard?
No, it is quite easy - remove battery cover by appyling pressure on the covers latches. you will need a ratchet and extension to loosen the battery grip at the bottom of the battery tray, I believe its a 14 mm socket.
Apr 06, 2010 | 2003 Volkswagen Jetta TDI
The memory seat, mirror, and pedles donot work. After changing the battery. Have checked the fuses and wiring.
Yea, after changing the battery you've lost your settings. You'll need to save them agian. Can't help you there.
Dec 16, 2009 | 2003 Lincoln Town Car
My htc touch dimond consumes the battery all of a sudden. i changed the battery but the problem is there. the battery shws full charge and after 3 4 hours the mobile goes off , and the battery has to be...
Make sure that the WiFi and Bluetooth is disabled unless you need them. Try changing the charger and use the wall charger instead of the USB one. In case after changing the charger, the battery still dries out, then it might be some fault (voltage leak in the mainboard) or it is time to change the battery.
Nov 15, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Changing the battery in the 2003 Odyssey
Product Description 12V 13.0AH
YB16L-B" height="44" alt="ODYSSEY PC545MJ
12V 13.0AH
YB16L-B" hspace="0" src="http://us.st12.yimg.com/us.st.yimg.com/I/yhst-54175651448798_2048_1057539" width="70" border="0" />
***FREE SHIPPING ON THIS BATTERY***
**2 Year Full Replacement Warranty
4+PCS Call us: 1-800-346-0601!
ODYSSEY PC545MJ
CATALOG# 0770-2020
12V 13.0AH
With metal jacket
Apr 02, 2009 | 2003 Honda Odyssey
Ready to change battery in zire 72s
Here is a video I found on replacing the Zire 72 battery. I hope this
helps.
Mar 26, 2009 | Palm Zire 72 Handheld
How do i change my car battery without losing my radio.
You need to keep a supply to it. You can buy various devices that plug into your cigar lighter. The quite simply have one of these square 9 volt radio type batteries in them. This keeps power on while changing battery. You could easily make something up with one of these batteries and a couple of leads going to the terminals after loosening the bolts. Be careful though and make sure your wires are secure so the do not come off while wrestling with the battery.
Cheers John
Dec 18, 2008 | Volkswagen Passat Cars & Trucks
Home Logo
123 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
