Question about Pioneer Car Audio & Video
Radio not switching on
Just lights the screen but does not write anything and cannot switch on. does not produce any sound. once in a while the there is some writing on the screen wuth the word off on top left corner and some lines in japanese at the bottom
    Scholar:
  • 141 Answers
Check your fuse for the radio.
Posted on Nov 24, 2013
I have an AKAI radio/cd/tape player combo. For about a year I had to toggle the switch around a few times just to get the radio to come on, now I cannot get any sound at all with the cd or radio
Akai used to produce quality gear. Today in common with lots of premium manufacturers the gear is less repairable and a whole lot more disposable. This is because it is less "engineered" and more designed for cost-effective assembly.
Mechanical switches and potentiometers for instance, add weight and expense to the manufacture and shipping and they wear out or get dirty and don't work - but they can be replaced or cleaned relatively easily. Soft touch controls and electronic switching is cheaper to produce and more pleasing to some buyers but when they go wrong cleaning rarely works and repairs are beyond the usual scope of the hi-fi enthusiast, meaning expensive repair-shop costs. It is worth attempting to clean the switches if there is access and you feel adventurous.
It sounds as though you have nothing to lose. There is a wide selection of switch and electrical cleaners available, some with an added lubricant for mechanical switchgear and potentiometers though for some things a cotton bud or a slip of paper dipped in methylated spirit works well.
Aug 10, 2016 | Audio Players & Recorders
My Yamaha psr650 doesn't produce any sound and the display screen does not show anything when I switch on.
if it makes no sound and has no display it is not switched on or has died . check power to the power switch with a multimeter, is it what it should be.
Jul 08, 2015 | Yamaha Audio Players & Recorders
Some times car won't start then I turn the key on and off many time then it starts , happens once a week
It sound like your ignition switch is going. Does anything else turn on such as the radio or the heater fan? If they turn on it is most likely your ignition switch.
Feb 11, 2014 | 2004 Volkswagen Beetle
I have a 2008 dodge magnum se I have been having problems with it starting, You could put the key in the slot and hold it and eventually it would engage after a few failed attempts. Then one day it would...
sounds like a bad ignition switch, which is most likely what blew the fuse the first time, the igniton switch does'nt have anything to do with the lights on the dash or headlights, but it will affect the radio and the starting of the car
Jan 12, 2011 | 2008 Dodge Magnum
The screen will not come out and the unit will not play. The blue light comes on to switch from radio/cd/tv, etc. and the red light comes on when you push cd eject, but otherwise it will not play any
MAKE SURE YOU PRESS THE SOURCE BUTTON AS THE SCREEN WOULD NOT COME OUT FOR THE RADIO BUT WHEN PRESSED AGAIN WILL PROBABLY COME OUT FOR THE TV
May 04, 2009 | Car Audio & Video
Hi My VW Golf radio is bust! It switches on and
past its day, get a new one they arnt very expensive these days
Apr 03, 2009 | Sony MDX-65 6-Disc MiniDisc Changer
I have a Ranger 6900F Jumbo
left to right,Volume,on/off(center) Squelch (outside)2nd knob is mic gain (center) this controls how much adio output you produce.. and rf gain,(outside) This adjust how sensitive the radio recieves.3rd knob is pa/fm/am This sets the radio up for using a public address horn if hooked up, or to transmit and recieve on am (most common) or fm.
The next knob controls what bands o channels you operate on .6 bands of channels with 40 channels each.The next knob controls the amount of echo and reverb you use when you talk.The center controls the echo and the outside controls the speed,or reverb effect.The next knob controls the talk back(so you hear what you sound like on the center control, and the outside controls how much power you put out.The next knob, the biggest one is your channel selector.The push buttons are top l to r are:1 is the dimmer switch for your lights,the middel top is noise blanker and automatic noise limiter. This blanks out a lot of static and outside electrical noise.the last top switch is a roger beep switch to turn it on and off. When it is on you will produce a quick beep when you unkey the mike. This was originally used to let the other people on the bands know you stopped talking.The bottom left shuts off the frequency counter(the numbered display ie27.185,the middle sets the meter to be used as an swr meter or a regular s/rf meter.the last on the bottom will boost the frequencet up100 kilohertz.if you go to the following url you can get more info:http://www.rangerusa.com/.
Hope this helps
Feb 07, 2009 | Galaxy Radios DX-95T Base CB Radio
Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Jun 05, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Car Audio & Video Logo
24 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
