Question about Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat
When you plug it in asoon as the thermostat kicks on the motor hums then starts and runs bacward. If you spin the fan the correct direction when it is humming it will sart and burn properly. I do live in the states and polarity seems to be correct on my wiring.
    Genius:
  • 1,198 Answers
Look for a capacitor. Have it tested, it may be a start capacitor for the motor, which would get it going the right way. Don't worry about polarity on the cap, but you can mark the connections if it looks important.
Posted on Nov 24, 2013
My rooftop air conditioner is making a humming noise, but will not blow out air. The fan will not kick on manually from the thermostat. The humming stops when I turn the thermostat to off.
check the capacitor of the fan motor may be it was bust u can see physical by the size bulge if u found damage. change it to new one with same rating then it will fix your humming problem.
Aug 20, 2016 | Heating & Cooling
Thermostate kicks pump motor on ok. but when its time for the fan motor, all you here is a loud humming then the breaker blows
check for a failed start/run capacitor for the motor
if the motor spins freely then the humming will be a frequency hum because there is not enough power to start the fan running
the extra current will blow a cb
Apr 08, 2016 | Mastercool 67680 Evaporative Cooler Air...
Goodman air handler ARUF036-00A-1A does not blow air in heating or cooling mode only hums/buzzes, what could it be?
Looking at the wall thermostat, you will see the fan switch that has two settings: fan auto, fan on.
You will need to place the fan switch in the fan on position for testing purposes.
This will make the indoor fan run continuosly, and never cycle off.
In the fan auto position, the fan will turn off when the thermostat temperature setting has been satisfied.
Remove the air handler access panel.
Is the air handler fan operating?
If the fan isn't working see if you can listen closely if it is humming, or can touch the motor to see if it is hot.
If it is humming and has a bad capacitor, you can tell this without having an electrical tester by spinning the fan wheel by hand.
Be very careful... making sure your hand won't get cut by the fan wheel spinning when it starts up.
If the fan spins and picks up full speed, replace the defective fan capacitor.
It is the shiny silver metallic cylindrical object with electrical wires attached to it.
Make sure you write down where those wires attach and turn the power off before removal as they carry 240 volts to the fan motor.
If you find that the fan wheel doesn't turn freely when you try to spin it by hand, the bearings have seized and you will need to find another fan motor of the same size, shaft length , speed , and horsepower to replace the defective motor.
Keep in mind that a humming sound in the air handler COULD be from the transformer instead of the fan motor.
The transformer is a black cube shaped device with electrical wires attached to it.
If the 24 volt transformer goes bad, your thermostat will not function and nothing will come on.
Dec 01, 2014 | Goodman Heating & Cooling
Motor hums but won't kick in
Hi simpsonruth1..
In the back of the compressor motor you will see a fan, remove the plastic cover to get to it..
Once you have the plastic cover removed and the fan exposed, plug the compressor in and spin the fan with your fingers...be quick as the fan could cut your fingers if you do not get them out of the way..
If the compressor starts working, then the start capacitor is bad on the compressor...if it does not run then you have motor troubles, either replace the motor or get it rewound.
Please take time to rate me
Sep 06, 2011 | Paasche 1/8 HP Diaphragm Compressor
I have a problem with my reddy heater 170t. it fires up runs untill it reaches set temp.but when it goes to restart the motor runs bacwards?after i manualy turn it off/on 2-3times it fires back up...
The thermostat is not the problem. The motor has a starter capacitot attached that gives the motor a burst of energy to get it going the right direction. It is not doing its job. The motor must be replaced.
Nov 27, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Makes electrical humming noise but does not pump water
This is could be the capacitor that has failed. The capacitor gives the motor the initial kick in the right direction to get it started. You can confirm it is a failed capacitor and that the motor is still ok by flicking the fan blades with a stick in the direction it should spin just as you switch the pump on. The pump should run normally. You can get them off Amazon or ebay for around 5 Pounds (GBP)
Oct 11, 2010 | Karcher K2.26 Electric Power Washer
Air on heat pump not cool outside unit humming but not kicking on
This could be an inoperative condenser fan.System will kick off on high pressure without proper air flow.The hum indicates voltage is present. Providing the fan motor is not locked up and will spin,Check your run capacitor which helps boost the motor voltage initially and will get it turning.If the cap is good,you may be faced with motor replacement....good luck
Aug 19, 2009 | Carrier 38CKC042 Air Conditioner
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
Master Heaters Master B115DT 115,000BTU Fan Forced Air Heater with Thermostat Logo
82 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Mike Squire
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
