Question about HP LaserJet Pro P1102W Printer
Message says printer is offline
My printer was in the middle of a job and suddenly gave me an error message and started saying it was offline. There is no jam (I checked) and I have turned it off and on, and restarted the computer.
    Genius:
  • 1,198 Answers
Sounds like your usb connector or cord. When you change the printer to a different usb outlet you may have to go to control panel and select the printer as the default printer. Always use the same plug if it works good.
Posted on Nov 24, 2013
All Office
  • 58 Answers
SOURCE: Mechanism Error - Print Cradle won't move! - HP 5650
This "plastic strip" is called the "carriage encoder strip". This strip dictates the timing of the carriage assembly. If the end slots aren't broken, you can re-attach it. Otherwise, you'll need to replace it. They are about $10.
Posted on Jul 03, 2007
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
Posted on Jul 03, 2008
  • 544 Answers
SOURCE: Paper jam that isn't
You could try a partial reset of the printer
Unplug the power cord
Reconnect power cord
When lights are flashing, press & hold On/Resume and PaperSize buttons
When only the On/Resume light is flashing, release both buttons
When On/Resume light is steady, reset is completed
Posted on Feb 22, 2009
  • 26 Answers
SOURCE: HP Officejet Pro L7780 constantly gives false"paper jam" error
Step 1:
The rollers should be cleaned if the paper fails to feed smoothly into the unit. All document and media rollers should be cleaned using a lint-free cloth lightly moistened with water.
1. The unit must be powered down and the power cord unplugged before cleaning the rollers. This will allow the rollers to be turned by hand in most cases. The paper should also be removed before cleaning the rollers.
2. Remove the rear access door to access the rollers. Clean any dust and debris from the rollers.
3. Open the unit and check the four small metal paper rollers (not the rubber rollers) in the interior of the unit. They should be clean and move freely. If these are not bright and shinny or have buildup on them, they should be cleaned. Also clean any dust and debris off of the rubber rollers.
4. Close the unit and reattach the rear access door.
5. Plug the power cord back in and power the unit up. It should reinitialize for about 20 seconds.
6. Print another extended self-test page.
Step 2:
==== Partial Reset ====
Press and hold # and 3 button on the unit while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+) instead of #.
==== Semi Full Reset ====
Press and hold # and 6 button on the unit while plugging in the power cord.
NOTE: For models that are not fax capable, press plus (+) instead of #.
==== NVM RAM Reset ====
Press and hold OK and Cancel button while plugging in the power cord
Posted on May 19, 2009
nyilasrobert
  • 627 Answers
SOURCE: Trying to print 'offline'.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Posted on Oct 05, 2009
Message error queue says printer is offline
Try turning it off, pausing for a minute, and turning it back on again
Jan 08, 2013 | Epson stylus nx110 All-In-One InkJet...
When I try to print I get the message " Printer
Check the following steps to fix printer offline error :
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
May 04, 2011 | Brother MFC-490cw All-In-One Inkjet...
WHEN WE GO TO PRINT, IT SAYS PRINTER OFFLINE.
Start-->printers and faxes-->right click on the printer-->properties-->make sure it's set to print online.
or
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 03, 2011 | Office Equipment & Supplies
My HP Officejet 6210 All-in-One printer goes offline whenever I don't use it for about 15-20 minutes, and when I put it back online, nothing happens. Looking at the printer from the control panel, I see...
HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
Disconnect the power cable from back of printer
While holding the # and 3 button, connect the power cord to printer.
*Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Printer Offline Message
Get more information to fix printer offline error :
http://printers.iyogi.com/errors/printer-offline-message.html
Hope this information helps you.
Jan 07, 2010 | Epson Aculaser C1100 Printer
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
False "printer is offline" message
Try to cheeck the port from ur printer to ur cp is been connected.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer offline or does not respond
oh my friend. just click the printer icon 1)click start on task bar. 2)go to settings or printer and faxes options. 3)in there you can see the printer icon 4)just right click that printer icon 5)there u will get the option 6)beside of which option there is a tick mark that is applied/enabled. 7)if there is tick mark beside the pause printing and offline option. 8)just click that option and that tick mark will go away and it will start working.
Jan 05, 2009 | Canon PIXMA MX300 All-in-One Printer
HP LaserJet Pro P1102W Printer Logo
87 people viewed this question
Seeker5211
Seeker5211
