Question about Food Mixers
Hi I took apart the hobart v1401 mixer although I take good notes as I take all parts of I was left with a washer I think from the top of the clutch and brake unit that I'm not sure where it goes now the clutch doesn't work its always engaged Please help
    New Friend:
  • 20 Answers
Are you still having this issue? If you have taken the parts out in order, then take a deep breath and let's go back over the diagram -- something is either NOT lining up OR you have forgotten something.
Let me know if I can help.
Posted on Jan 19, 2014
bigg t
  • 640 Answers
SOURCE: Disassembling the mixer
does the plug run through the base or the back of the unit?
Posted on Aug 01, 2007
  • 49 Answers
SOURCE: Hobart C-100 mixer HELP!!!!
This is common there is a key on the shifter shaft and when you removed it the key came out and is floating in the grease in the tranny ready to destory the gears. That are no longer available at Hobart. if you want the shifter /switch plate off, remove the pin in shifter and the handle thats all. Hobart has a special puller I have two of them but you can use a H type puller to get to the pull threaded holes Mixer should be upside down on head to repair trans.
Posted on Sep 30, 2008
ricardok45
  • 135 Answers
SOURCE: Mystery part to a 1950 Hobart N50 Mixer; serial number 997185
Go to www.hobartservice.com, register, then go to select "food machines" in the Product Group, then "mixers"and look for the Discontinued Products, then find the N-50 mixer drawings, they are all there, even the old ones. Look through the "exploded" drawings for your extra parts. It seems to me that the tech who put this together should know if they belong to this mixer or not. Does he work for Hobart? Or is he a repair person who states that he knows how to repair Hobart products. If he does'n't work for Hobart, these parts may have been on his bench BEFORE he looked at your mixer. A true Hobart Tech has access to specs on ALL models and the ability to access the Service Manuals. If you find this solution helpfull, please rate it. ricardok45
Posted on Jan 04, 2009
SOURCE: Manual for Hobart Mixer A200
You can go to hobartcorp.com and register for free then you can print or download a parts
manual to help you to do repair. Hobart provide service manual to their technician only.
Posted on Jan 17, 2009
  • 44 Answers
SOURCE: Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Posted on Jun 10, 2010
I have a v1401 and its oil level is low. Where
you can buy @any hobart office in your area.
Jan 15, 2010 | Food Mixers
V1401 slips in all gears; what to adjust?
Take the top cover off,in front of you is the brake.Turn the mixer on and you will see it spin (put it in 1st gear),stop the mixer.on the right side you will see a pin that catches the brake flange,if its worn you can replace it,if its not worn then the brake needs adjusting as it acts like a clutch.Let me know,im a hobart tech band repair these units often.
Nov 18, 2009 | Hobart Food Mixers
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
I suspect my D300T Hobart Mixer has a broken shaft I Need a parts/manual listing to help me take apart mixer, retreive broken parts and then order required parts
Hi. Go to hobartservice.com, register for free. This will allow you access to the parts files for your D300T mixer. Download them. When you begin your disassembly, take a photo of every piece that you remove, lay these pieces on a piece of cardboard or something suitable in the order that they were removed. This will help you greatly with your project. Good luck! ricardok45
May 12, 2009 | Hobart D300 Stand Mixer
Hobart v1401 mixer slipping when in 1st gear.
Sounds like the planetary brake needs adjusting or the pin is worn.
Feb 12, 2009 | Hobart Food Mixers
A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Jan 17, 2009 | Hobart A200 Stand Mixer
Hobart V1401 Shaft Broken
I'd advise that you contact your local Hobart Service Branch for guidance on that question. Please visit the service website at www.hobartservice.com and click on 'Locate an Office" - you'll be able to locate the closest Service Branch to you for advice. Hobart does also sell replacement parts to end users direct as well - through the local Service Branch.
thanks
Sherri Wilmoth
Hobart Marketing
Oct 07, 2008 | Hobart Food Mixers
Aug 20, 2008 | Hobart N50 Stand Mixer
Jun 10, 2007 | KitchenAid K5SS Heavy Duty Commercial...
Food Mixers Logo
119 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
