Question about Lutron S-600-wh Skylark Incandescent Dimmer
There is a delay for light to come on when dimmer switch is turned on
2 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: I'm attempting to wire a 3 way switch with a dimmer
Hello Chris,
What has happened, is that you've got th two "traavelers" reversed on the plain toggle switch. These are the RED and BLACK wires. turn off the power and reverse the position of these wires and the switch should work correctly from either the Dimmer switch or the plain switch.
Here's a link with a diagram, which might not exactly match your circuit configuration, but you can also watch a short video that explains how 3-way switches work.
It is just a matter of getting the travelers on the correct screws in order for the circuit to operate properly from either switch. Also, depending on the type of dimmer you've installed, the other switch will only turn the lights on at the dimmer setting that you've left the dimmer switch in. So be sure that you're not turning the dimmer all the way down before you shut it off (at the dimmer) otherwise, the other 3-way switch won't be able to turn the lights on, regardless of whether you've got the travelers in the correct locations.
Remember to turn the power off to the circuit you're working on while you rewire it and flip the breaker back on when you're done.
http://www.electrical-online.com/3waydiagram.htm
Hope you find this Very Helpful and best regards!
Posted on Nov 17, 2009
2012 jeep Sahara- dome light will not turn off
you sure its not just on delay...could be 10 minutes....and did you check the dimmer switch for the dash lights. if its turned all the way up it will turn on the dome lights.
Mar 02, 2015 | Jeep Cars & Trucks
Interior light delay
Same for both doors? If not, I'd check the switch(s) on the drivers door (may be more than one), or may be just one that has multiple contacts and the ones for the lights may be faulty.
Jul 01, 2017 | 2008 GMC Sierra 2500HD 2WD
Ford windstar interior lights will not turn off while driving. when parked lights will go off nut longer than the normal delay
Make sure the interior lighting dimmer is not set to the full ON possition.
I believe the Windstars dimmer is under the headlight switch yet in 2000.
Sep 29, 2011 | 2000 Ford Windstar
The headlights will not turn off - then after 10 min they will shut off by pushing the headlight switch
Look for other light controls, this sounds like sentinal lighting, which has what looks like a dimmer style control that sets this light off delay. the goal is to give light until you get in the house. the delay is adjustable.
Oct 06, 2010 | 1994 Buick LeSabre
On my 1999 mercury mystique (4 cyl) the interior dome light has a delayed shut off of about 10 seconds or so. Last week the delay has gone to infinity (the dome light just won't go off at all). I had to...
sounds like a bad door switch ,also make sure dimmer switch is not all the way up that truns inside light on, if dimmer is not on then i would say driver door switch is no good. hope this helps.
Oct 25, 2009 | 1999 Mercury Mystique
1999 Mercury Sable Dome Light won't shut off
Next to the headlight switch is a dimmer dial for the interior dash lights... if you turn it all the way up, the interior lights remain on... there is a "detent" on the dimmer. turn the interior dash lights all the way full on ...you'll feel the detent, then turn it down back past the detent a little bit...that should cancel the interior courtesy lights... wait a bit because the interior lights are sometimes on delay timers....
good luck let me know what happens.
May 09, 2009 | 2001 Mercury Sable
Two switches with two hallway lights-one delays going on.
What it sounds like to me is that the second light may have fluorescent bulbs - either the compact fluorescent type or maybe a circular bulb. The fact that when you turn off the switch and then immediately on and it works fine, also makes sense if that is the case.
Jan 28, 2009 | Fantech DB10 Pressure Switch Kit w/ Delay
Interior lights will not turn off. all doors checked for proper closure
check you dimmer switch. if your dimmer switch has been moved uo than your interior lights will come on and stay on until shut off.
Aug 02, 2008 | 1997 Ford Windstar
Lutron S-600-wh Skylark Incandescent Dimmer Logo
41 people viewed this question
Top Lutron Electrical Supplies Experts
jdthefixer
ken skalski
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
