Question about Fujitsu MHW2120BJ-G1 Hard drive 120GB internal 2.5" SATA 7200rpm buffer: 8MB laptop hard drive. 60 d...
MMB212OUB Fujitsu drive not recognised - Fujitsu MHW2120BJ-G1 Hard drive 120GB internal 2.5" SATA 7200rpm buffer: 8MB laptop hard drive. 60 d...
Hard disk is not boot up after windows screen appears
It seems you computer is not recognising the hard-drive, on boot up, because it doesn't know where to look, i.e. it is booting up to a different drive letter. Have you got more than one drive on the system? If you have you will need to reconfigure the bootup list. Good Luck. George
Mar 29, 2013 | Fujitsu MHW2120BJ-G1 Hard drive 120GB...
How do i use recovery cd's if i have no cd rom drive? i have an external cd/dvd drive plugged into usb port but the fujitsu 1510d lifebook does not recognise it? thanks dave
When you boot your computer, start up your BIOS, then under the boot menu, make sure USB is listed as the 1st option.
To log into your BIOS, press the "Boot Option" key. It might be F1, F2 or Delete
Feb 28, 2011 | Fujitsu LIFEBOOK P1510D Tablet PC
I have a Fujitsu 80gb Sata hard Drive (2.5) which I have an adapter to use as a external Harddrive. However my computer and others only recognise it as a 14 gb drive. How do I get the full 80gb?
It seems this is caused by setting jumpers on your hard disk. Checkand return it to the correct position. Normally, your disk should be inthe position of Master or Slave.
Jan 16, 2011 | Fujitsu 50PK 80GB SATA 5400RPM 2.5 IN...
Dvd drive not regognising discs? Fujitsu E Series Laptop
Try it out in other machine before coming to a conclusion. If it is recognised make a copy and try again in your current machine. Also clean the lens using lens cleaner CD.
May 23, 2010 | Computers & Internet
Computer recognises drive but does not show drive letter
Click Start
Right-mouse click on My Computer
Choose Manage
Click to get to Disk Management (local)
Use Disk Management to "create" and "format' a partition onto the disk-drive, and to assign a drive-letter.
May 07, 2010 | Fujitsu Siemens (MAN3184MCB) Hard Drive
I want the bios recognise usb flash
Start Windows.
Insert the USB flash-memory device.
Windows should recognize the device, and assign a "drive-letter", such as 'E:' or 'F:'.
Open "My Computer".
Select the 'E:' or 'F:' drive, and browse the files/folders.
Nov 14, 2009 | Fujitsu AMILO D-7820 Notebook
Cd rom not recognised
you will need to install the driver for the cd. If you are on the internet go to device manager. On the list that appears select the drives, open the properties tab and it wil ask if you wish to install the driver.
Oct 15, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
No wireless settings come up at all
Oh yea I'm sure it had a lot to do with it..when you format a drive you lose everything including drivers. Check the device manager, look for Network Adapter, the click on the "+" to open If you see your wireless deivce then right-click on it and then choose to reinstall drivers..good luck, let me know how it goes and if you have any questions.,
Please rate this solution.
Mar 27, 2009 | Fujitsu AMILO PC Laptops
Fujitsu v2000
I assume you mean cd driver..
your cd is recognised as plug and play and shouldnt need any drivers installing .
on the underside of unit youll find retainer screws for cd ..remove these to slide cd drive out ...startup pc and when in windows slide drive back in and sys will detect and install it .you may have to remove other covers to gain access to retainer screws for cd drive.
dont really matter which screws you remove whilst looking as long as you dont forget where they go and to replace them
Jan 25, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu MHW2120BJ-G1 Hard drive 120GB internal 2.5" SATA 7200rpm buffer: 8MB laptop hard drive. 60 d... Logo
21 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
