Question about Android Apps
Highest common factor - Android Apps
Please explain how you do ratios
A ratio can be simplified by dividing both sides of the ratio by the Highest Common Factor (HCF). The highest common factor is the largest number that goes into both numbers of your ratio. In example 1 you are asked to simplify the ratio 6:8. Here the HCF is 2 so divide both sides of the ratio by 2 to give 3:4.
https://www.youtube.com/watch?v=cbjQWf411O8
Mar 04, 2015 | The Learning Company Achieve! Math &...
Ways to find highest common factors?
Do a prime factorization of the two numbers. Use condensed (power) notation for each prime factor.
Example
N1=(2^5)*(3^4)*(7^2)(11^3)
N2=(2^4)*(5^6)*(11)
2 is a factor in N1 and N2, the smallest power of 2 is 4, thus 2^4 is common to N1, and N1. You could write 2^5=2*2^4
11 is a factor in N1, and N2, the smallest exponent of 11 is 1, thus 11 is a common factor of N1 and N2.
Highest common factor of N1 and N2 is (2^4)*11
Sep 02, 2014 | Mathsoft Computers & Internet
My casio fx-83GT Plus calculator wont do HCF for me
There is nothing you can do to make the calculator find the HCF for you. No point complaining about that. But if you are interested in doing it by hand (using the calculator to do the divisions for you) here how it is done.
  1. Decompose the first number in prime factors. If a prime factor is repeated use the exponent notation: That helps.
  2. Decompose the second number in prime factors too, using the exponent notation.
  3. Now look at the two decompositions. If a prime factor is present in both decompositions it must be in the HCD /HCF, with the smallest of its two exponents.
  4. Do that for all prime factors
Example: Here are the decompositions of two numbers
(2^5)*3*(5^4)(7^3)*11 and (2^3)*(5^6)*(11^2)*7
The prime factors that are present in both decompositions are
2, 5, 7, and 11
From the two decompositions select the smallest power of each common prime factor. They are represented in bold fonts.
2^3, 5^4, 7, 11
The highest common divisor/Highest common factor is
(2^3)*(5^4)*7*11
Mar 27, 2014 | Casio Office Equipment & Supplies
Can you do the highest common factor on an fx-83GT PLUS casio calculator
The calculator has no application that will find the highest common divisor (or HCF) but that should not be difficult to do by hand.
Now look at the two decompositions. If a prime factor is present in both decomposition it must be in the HCD /HCF, with the smallest of the two exponents. Do that for all prime factors
Example;
2, 5, 7, and 11
2^3, 5^4, 7, 11
(2^3)*(5^4)*7*11
What is the highest common factor of 8 and 13
There are no common factors, other than 1.
Mar 16, 2014 | Office Equipment & Supplies
Math is fun has a great article on how to find the GCF of two numbers:
http://www.mathsisfun.com/greatest-common-factor.html
To find the common factors, you have to list all factors of both numbers:
96: 1, 2, 3, 4, 6, 8, 12, 16, 24, 32, 48, 96
124: 1, 2, 4, 31, 62, 124
Oct 21, 2013 | Android Apps
What is the greatest common factor of 72 and 132
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
12 is the highest common factor between those two numbers.
12 multiplied by 6 equals 72.
12 multiplied by 11 equals 132.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Jan 18, 2012 | Android Apps
Android Apps Logo
401 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
