Question about Dynex DX-L42-10A 42 in. LCD TV
How do I set the closed caption to show on the lower part of the scree instead of the center?
I use direct tv, I slide direct controller to "tv", go to settings, go to captions and have tried "captions 1-4" . every selection still keeps captions in center of screen
vortash
  • 431 Answers
SOURCE: We upgraded our cable service and now have HD
Closed caption is an extra for the TV tuner you have it may not be on the set for HD ie: your set is now recieveing it's picture from the cable box and not your TV tuner probab;y by scart or SVHS cable , and the equipment you have may not have Closed Caption capability check with your network supplier ..... Regards Vortash
PS will it work if you go back to normal tv I think it might .? and if it does case proved ..
Posted on May 01, 2009
  • 679 Answers
SOURCE: how to set up caption on my Dynex tv 32'.
Hi you can set the caption by following link http://www.dynexproducts.com/cms/documents/DX-32L152A11_10-0616_QSG_V1_EN_Final_lr.pdf.
Thanks.
Posted on Jan 01, 2011
SOURCE: I have a 32" Dynex flat screen and a black box
I HAVE THE SAME PROBLEM, HOW CAN WE FIX THIS???
Posted on Jan 17, 2011
  • 176 Answers
SOURCE: I have a DYNEX 42"
Do you have a cable or satellite box connected to the TV? If so the box is probably what is providing the Closed Caption and not the TV.
Robert
Posted on Feb 26, 2011
Testimonial: "Quick response from fellow users."
  • 159 Answers
SOURCE: cannot get closed captioning turned
Try the basic "re-boot" most digital devices respond to - pull their AC supply plug out for 10 minutes, reconnect, re-setup if asked to and problem may well have been sorted.
Posted on Sep 24, 2011
Closed captions are in the middle of the screen, instead of at the top or bottom?!!
Unless you have a control for moving the captions there is nada you can do
Dec 01, 2015 | LG Televison & Video
How do you remove braille from tv
If you are talking about the words spoken on the TV program being displayed on the TV screen as text, then this feature is called CLOSED CAPTIONING.
Most remote controls have a button called CC, or CAPTION, or INFO, or DISPLAY which will allow you to disable the CLOSED CAPTIONING feature.
Otherwise you may have to select the MAIN MENU option for your set and go into the AUDIO OPTONS or FEATURES menu. If you can find the Closed Caption settings in there, then just disable them there by setting them to OFF.
If you can provide the exact brand and model number of your TV, then we can certainly provide you with more specific instructions on how to disable that feature on your particular set.
If you have a cable or satellite set top box, then also make sure that the Closed Captioning is not being generated by that device instead of by your TV. Make sure the Closed Captioning is disabled on that set top device as well if applicable.
I hope that was helpful.
Good luck and take care.
Joe.
Dec 15, 2011 | Philips Televison & Video
How do i remove closed caption on tv - can't get menu option on remote to work - thanks.
What is the TV source? Could the captions be coming from that source? If it is, try disabling them from the Menu for the set top box (cable, satellite, DVD).
There is a menu button on the TV that will let you access the OSD if the Child Lock is not enabled.. Then the same directions apply Set > Closed Caption (Off, CC-1, CC-2, CC-Mute). If you can't access the menu directly, then the control board may be bad. Try shopjimmy.com for used parts with minimal wear (sets that were broken in shipping) or another supplier. You will need to open the TV and get the part number of the current board.
I hope this helps.
(the set-top box issue is one I have dealt with. A neighbor with an older TV needed to use the captions from the satellite receiver set to single mode to get captions for the visiting relative. This meant that both sets watched the captions until they were turned off. The main TV still showed the captions if they remembered to reset the receiver to Dual mode.)
Nov 11, 2010 | Philips Magnavox 27MS343S 27" TV
There is a black box in the center of my tv
I would suspect your closed caption settings are set to text and there is no text available on the channel . I would figue out how to navigate the tv menu to cc or closed caption settings and set it to off. Sometimes there will be a cc.. or closed caption button on the tv remote to change those setting directly.
Jul 29, 2010 | Insignia NS-LCD19 19 in. LCD TV
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
How do i enable the closed caption on my samsung tv/direct tv?
Correct solution WITH DIRECT TV is NOT going to SETUP MENU on your Samsung TV and enabling it, this won't work with Direct TV!! I'll walk you through it. Grab your Direct TV remote, hit "Menu", pan down to "Parental, Fav & Setup", next click "System Set-up", next click "Display", now at the top of the screen between "Preferences" and "Clock" is "Captioning", click on it, now the first box reads Captioning TURN IT FROM OFF TO ON! You now have Captioning.
Aug 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do i disable close captioning on a mitsubishi cs-27201c tv?
On your remote, push TV MENU button. With the center wheel ("adjust") control, scroll over to captions. Push "enter" button in center. With "adjust" wheel, scroll down until "off" shows in the box. Press TV MENU button twice and you're done! Good luck!
Apr 19, 2009 | Mitsubishi Televison & Video
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Dynex DX-L42-10A 42 in. LCD TV Logo
19 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
