Question about Briggs & Stratton Garden
Briggs 407777, type 0121-E4
I have a 21 hp lawn tractor that when the blades engage I lose considerable power and the engine dies shortly thereafter. I have replaced spark plugs and properly set the gap, changed oil, checked coils, and added fuel stabilizer. I am preparing to regap the valves. Am I on the right track? Now the engine dies as soon as I engage blades.
    Top Expert:
  • Briggs & Str... Master
  • 12,962 Answers
The engine is not developing power and the presence of a load causes it to slow down and quit all together. Is there some sort of timing advance on that motor? In a car if the timing is not right that is exactly what happens when you put the car into gear and try to use it.
I would not mess with the valves till I check out the timing.
Posted on Nov 24, 2013
SOURCE: craftsman lawn tractor wont start
your fuel filter could be plugged
Posted on Jan 19, 2009
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
moretons
  • 155 Answers
SOURCE: oil capacity for 14.5 hp briggs engine
That would be 1.2lt to 1.4lt from empty
Posted on Aug 12, 2009
SOURCE: John Deere 115 lawn tractor - won't start.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Posted on Aug 18, 2010
Www managemyhome com
bad safty switch or shorting pto if pto replace it but i think one of your safty switches is bad
Aug 26, 2014 | Craftsman YT 4000 42" Briggs Stratton 24...
Got a Craftsman DLS3500 lawn tractor, did not come with a owner's manual, and having a problem keeping it running once the blades are engaged and/or try to put it in gear to move it. The engine dies...
well first an owner's manual is how to operate it, not repair it. you can buy small engine repair books on amazon.com and eBay.
there are several safety switches to keep the mower from hurting people. all these switches are connected to a common relay which disables the engine unless the switches are telling it AOK. there are hundreds of identical questions posted here every summer about the craftsman lawn tractors and the problem relates to a bad safety switch or the relay. you are going to have to examine each of them and do some trouble shooting
Aug 28, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have briggs and stratton powered mower with the 18.5 v-twin ohv intek engine modle 407777 type 0121-E5 CODE 000512ZYG MY PROBLEM IS THAT MY CRANKCASE IS FULL OFA GAS OIL MIXTURE THE OIL FILTER ALSO...
When the float in the carb sticks, it allows fuel to drain into the cylinder, that runs pass the rings into the crankcase. When the crankcase is full the pistons cannot go down, and the starter won't turn the engine. Drain all the oil gas mixture, and refill with proper oil. Replace float, needle and seat in the carb bowl. Throughly clean fuel passages, and bowl. If motor won't turn, remove spark plug and turn over engine a few times to remove gas oil mixture from the cylinder too.
Oct 02, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have a 15.5 hp ohv briggs n stratton on a craftsman riding mower when I engage the blades or let out on the clutch the engine dies out tried disconnecting seat switch ,replaced spark plug and fuel...
There is a switch underneath the seat that will shut the engine down if the mower is engaged and you are not on the seat...that switch is bad and it thinks you are not on the seat so it shuts you down...
heatman101
Aug 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lt1000 20hp. briggs electrics on carb it will run when you pour i
Check fuel lines for clogging.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have a 2005 18.5 hp poulan riding lawn mower, wouldnt start so i replaced battery and solenoid and 20 amp fuses, startyer was checked and fine. Finally got it started and now it won't mow, blows 20 amp...
most likey you have a short . how do you ingage your blades by button or lever. if the button type look for a shorted wire . look for a bad wire some times mice get in to it and chew wires .
Apr 09, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have rjdeing lawnmower with a BRIGGS&STRATTON 13.5 OHL WHEN YOU PUT IT IN GEAR AND ENGAGE THE BLADE IT LOSES POWER WQNT RUN. FAMLEY 4BSXS.3442VM 275943
if you mean that when you let off the clutch pedal and/or engage the blades, the engine dies, lift the seat and make sure the connector is firmly plugged into the switch attached to the seat.
Sep 28, 2009 | Briggs & Stratton Garden
Let me know.
Regards,
May 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
95 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
