Install games im trying to install bigfish games and get error ..could not load local temp nys 6143 tmp
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
The 6143 error may be caused by windows system files damage. The corrupted windows system files entries can be a real threat to the well being of your computer.
only advanced users should try this.
Posted on Nov 26, 2013
4 Suggested Answers
yourpc
  • 190 Answers
SOURCE: why can't I download bigfish games on my new PC?
The 2 most common problems for this are:
1:You may be having an issue with Internet Explorer. Try resetting Internet explorer to factory settings and the reinstall your adobe flash, shockwave and reader since these will not be in Internet explorer anymore. The instructions for the reset are located here:
http://www.icompute.info/IE7_Restarts.htm
The instructions are the same for IE8 and the page describes this for a different issue but all your doing is resetting Internet explorer.
Or 2: Your antivirus is not allowing you to installing your program. You may need to disable your antivirus while doing the install. Most antivirus programs allow you to temporarily disable them because they realize that the antivirus can interfere with installs.
Hope this helps.
Posted on Sep 19, 2009
Nitin_Master
  • 846 Answers
SOURCE: error loading c:domcume~1\locals~1\temp\tmp27.tmp
Use this tool http://info.prevx.com/downloadcsi.asp
It might help you solve your problem
and also scan your PC with http://download.cnet.com/Spybot-Search-amp-Destroy/3000-8022_4-10122137.html
Posted on Oct 27, 2010
joelwilcox
  • 1274 Answers
SOURCE: ho to fix problem name blue screen
can you post the actual blue screen code?
Posted on Feb 01, 2012
Setup has detected that the file 'C:\DOCUME~1\Jennifer\LOCALS~1\Temp\VSD335.tmp\SQL Server Compact Edition\SSCERuntime-ENU.msi' has changed since it was initially published.
Hi Remove you Temp file and installation again, now you did not get this error.
How to Remove Temp file
1) Go to Run and Type %temp% and press enter
2) Temp window will open select all and press the delete
Thanks
May 24, 2012 | NEAT Receipts Mobile Scanner
TMESSAGE.TSF: GetLastError: 64 (40)
When do you get this message? Is it a home PC or office network?
Cause:
This problem occurs when the TEMP or the TMP environment variable has a space character in the folder name. For example, the following TEMP environment value may cause this problem: D:\Documents and Settings\UserName\Local Settings\Temp
Resolution:
To work around this problem, change the value for the TEMP or the TMP environment variable for the system account and for the user account that will be used to install SQL Server 2000 64-bit. If you want to restore the values for these variables after the installation, make a note of the values before you change them. To change the environment variable values, follow these steps:
  1. Create a folder at the root of the local drive and name it TEMP.
  2. Click Start, right-click My Computer, and then click Properties.
  3. In the System Properties dialog box, click the Advanced tab.
  4. Click Environment Variables.
  5. Repeat the following steps for both the TEMP and the TMP User variables:
    1. In the User variables list, select the TEMP variable, and then click Edit.
    2. In the Variable value box, type %drive%\TEMP, and then click OK.
      Note %drive% is the local drive where you created the folder in step 1.
    3. Repeat steps a and b for the TMP variable, if it exists.
  6. Repeat the following steps for both the TEMP and the TMP System variables:
    1. In the System variables list, select the TEMP variable, and then click Edit.
  7. Click OK two times to close the System Properties dialog box.
  8. Click Start, click Run, type cmd in the Open box, and then click OK.
  9. At the command prompt, type the following command to verify that the TEMP and the TMP environment values are equal to%drive%\TEMP:
    set t
  10. At the command prompt, in the root of your SQL Server 2000 installation folder, type the following command: setup.exe /l*v C:\TEMP\setupfail.txt
Note If you want to restore the values for the TEMP and the TMP environment variables after the installation, follow step 2 through step 7 to restore the original values.
Hope this helps you.
Dec 29, 2010 | Computers & Internet
Upgrade for settlers downloads but won't run
I had this issue as well. Download the patch directly from the website, and run it locally. Afterwards the updater won't find a newer patch, and goes directly to the game. I don't know whether this will break again once a new patch is released, but you should be able to manually install it again at that time. Patches can be found at http://www.ubi.com/US/default.aspx under support --> patches.
This link may take you directly to the right place.
http://www.ubi.com/US/Games/Info.aspx?pId=5923&tab=download&dcId=63
Aug 02, 2009 | Ubi Soft Entertainment The Settlers: Rise...
Memory Module & hardware conflict
Dear Sir
Please try latest service pack from net and check. Some hardware devices are not compatiable.
Mar 12, 2009 | Toshiba ZA2000P02 - Satellite...
Computers & Internet Logo
David Payne
David Payne
