Question about VinoTemp VT-52SN Stainless Steel Wine Cooler
Vinotemp not cooling - VinoTemp VT-52SN Stainless Steel Wine Cooler
My vinotemp vt60 starts cooling then stops
I sounds to me like the compressor is overheating. There is an overload on the compressor itself. Follow the wires where they go into the compressor. There will be a black wire going from the power cord to the overload. These can be purchased at appliance parts stores. Make sure there is no dirt build up on condenser coils or a kink in the tubing.
Jul 30, 2014 | VinoTemp (VT60GNV) Wine Cooler
WM-2500-HTD
Hi Lam Tran, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? I CANNOT FIND THIS INFORMATION, BUT YOU CAN DOWNLOAD THE MANUAL HERE http://www.manualslib.com/products/Vinotemp-Wm-2500-Htd-2522211.html or maybe here http://www.homedepot.com/p/Vinotemp-Wine-Mate-Wine-Room-Cooling-Unit-WM-2500-HTD/202032773 which might enable you find the relevant part numbers, which might be useful. The manual can also be downloaded, I suspect, from vinotemp website. The parts you list are not amongst the replacement parts commonly sold by the manufacturer (see their list of replacements), so I suggest talking to their customer service or support (by whatever method is most convenient for you, if you have not already tried this) http://www.vinotemp.com/Customer-Service.aspx As a long shot you might try fining the spec of the parts and buying and fitting non-manufacturer parts which meet the specs. 4.May.2014
May 04, 2014 | VinoTemp WM2500HTD (250 cu. ft.) Wine...
Lower zone will not cool. 45 bottle model.
This is a VT-45 (not a TC32 as mentioned), right? If its just the lower zone that isn't cooling, it could be a few things that are happening. Most likely the fan isn't working or there is a sensor issue monitoring temperature for the lower zone. I'd recommend having a service person diagnose to be sure. Otherwise, have you contacted the manufacturer, Vinotemp, for help as of yet?
Oct 02, 2010 | VinoTemp (TC32GB)
Our 18 bottle vinotemp cooler quit cooling, the electrical is ok
Sounds like the cooling unit, i.e. heat sink and controller chip. $35 + $10 shipping from vinotemp, and you install yourself. I'm looking at the same thing (on the 28TEDS), though mine came after having to replace (for $45 and my own installation, incl. soldering) the circuit board. I hope yours doesn't go, too. I've read of others. Pretty poor quality parts they appear to use. I'm trying to find somewhere to buy the controller chip on its own, as the heat sink is simply a hunk of metal. Hopefully that's do-able, as it is with computer cpu's.
See:
http://www.vinotemp.com/Browse.aspx/446/Replacement-Parts
Dec 28, 2009 | VinoTemp VT-18TEDS 18-Bottle...
Vinotemp (VT-60), cools, but doesn't turn off regardless of the temp setting. It will run, cut off for aprox 5 seconds, then continue running. Is thermostat broken? Can it be repaired?
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
http://www.vinotemp.com/Resources/Documents/VT60.pdf
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Nov 05, 2009 | VinoTemp VT-60 Wine Cooler
This VinoTemp vt 60 just quit working. No
if the evaporator coils are warm, you have a leak and no refrigerant.
Aug 25, 2009 | VinoTemp VT-60 Wine Cooler
Cools, but not below 60 degrees
It sounds as though you may have to replace the cooling system on the unit, to order it you can call Vinotemp @ 800-777-8466
Apr 18, 2009 | Refrigerators
Vinotemp VT-16TEDS has light on but doesn't cool
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Vinotemp wine cooler won't cool
It sounds like your control module is bad. Vinotemp does list the replacement part as available at a cost of around $35
Nov 14, 2008 | VinoTemp (VT60GNV) Wine Cooler
VinoTemp VT-52SN Stainless Steel Wine Cooler Logo
76 people viewed this question
Top VinoTemp Refrigerators Experts
Vernon Taylor
Ilia Bichin
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
