Question about Acer Aspire 8920-6048 Notebook
Roxio Back on Track Repair kit . - Acer Aspire 8920-6048 Notebook
Need recovery disk for hp mini 2140
Hi
you could try this if it helps
There are two ways to access Roxio BackOn Track to recovery the computer, either through the boot menu, or through the Windows Start menu.
    You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored.
    1. Press the power button to turn on the HP Mini.
    2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.
    If you can access Windows, in addition to restoring your computer to a previous working state, you use other options, such as Disaster Recovery.
    1. Click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track
    Hope this helps you
Aug 19, 2011 | HP Mini 2140 Notebook
I couldn't restore my mini hp. How to restore factory my mini hp? As i couldn't find ways to restore it from my mini hp. By the way, my mini laptop doesn't have any CD rom drive.
Roxio BackOn Track is a suite of backup and recovery tools which includes the following: · Disaster Recovery? · File Backup? · Instant Restore? Accessing Roxio BackOn Track There are two ways to access Roxio BackOn Track?through the boot menu or through the Windows Start menu. Use the boot menu option if you cannot access Windows. You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored. You must be able to access Windows to use the other options, such as Disaster Recovery. To access Roxio BackOn Track using the boot menu, follow the steps below. 1. Press the power button to turn on the HP Mini. 2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.To access Roxio BackOn Track using the Windows Start menu, click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track.Backing up your hard drive using Disaster Recovery 1. In the left pane, click Disaster Recovery to expand the options, and then in the right pane, click Backup Drive . 2. Select the hard disk drive from the drop-down list in step 1, click inside the text box in step 2 and add any comments that you want to add, select a destination drive from the drop-down list under Destination Selection , and then click the large circle button at the bottom-right of the screen to continue. 3. Wait while Backup Drive creates an image of your hard drive. Restoring your hard drive Prior to restoring your hard drive, you must have created a disaster recovery set. To restore your hard drive using Disaster Recovery, follow the steps below. 1. Shut down and power off your HP Mini if it is not already powered off. 2. Connect an external USB optical drive to the HP Mini. 3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc. 4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer. 5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.For more information, please see the Help within the Roxio BackOn Track software.
Mar 20, 2010 | HP Computers & Internet
Hey my hp mini keeps asking me what program i want to open a program with.even when i try to open up something as simple as solitaire it asks me what program to open of solitaire with. how do i get rid of...
1. if it is XP operating system you can do roxio back on track which can be accessed from windows. start- all programs- roxio- instant restore.
2. if it is windows 7 you can do a recovery of the computer.
Mar 01, 2010 | HP Mini 1000 Netbook
Roxio xingtone ringtone makerprogram wont connect to internet. and this wont allow me to use application. why,and or how to fix
turn off firewalls, open add or remove programs and right click on roxio xingtone ringtone and click repair and restart ur computer if u still have same problem check the validity of the program ,as roxio has a expiry date
Nov 20, 2009 | Roxio Xingtone Ringtone Maker
Is there anyway that I can fix my tv with out replacing anything? the blue and red in the tv is fine but the green is off track and making the picture look funny it is shifted downward. It there anything i...
No,Ur convergence it dead,require changes ICs and resistors.U know how to solders?Buy a convergence kit replaced what in that kit.Websites have the kit.Tv repair World.com,Tv repair kits.
Nov 04, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
No Drive Detected
make sure your system is lightscribe compatible, here the roxio will work. good luck
Aug 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Cannot make mp3 files from cds
Don't bother using Roxio for this - use Windows Media Player 11.
1. Open Windows Media Player
2. Run the mouse over the "Rip" tab - a small aroow should appear underneath the word "Rip" - click on the arrow and a drop-down should appear.
3. Select - "Format" - change to "mp3"
4. Now insert your CD and press the Rip button - by default, Windows Media Player will store the mp3 files in the My Documents --> My Music folder
Now use Roxio to make a CD out of the Mp3 files
-Tha Mp3 Doctor
Mar 20, 2009 | Roxio Easy CD & DVD Creator 6...
Burning DVD from Windows movie maker and audio is funky!
after copleting save it in u r system as .dat format.
then use nero n select make video dvd
ur's kishore
for more help catch me on +919985064600
+919963674002
friends_kishore@yahoo.co.in
Feb 10, 2009 | Roxio Easy CD & DVD Burning
Roxio Easy CD creator 6 gives only tracks #s
I have not solved it.
Your site said that it was free and so I asked.
Thanks
Nov 18, 2008 | Roxio Easy CD & DVD Creator 6...
CD Burning
i would try to dl latest nero.com use nero alot better did u try to go to roxio.com and download latest software verison k thx nick
Oct 06, 2008 | Roxio Easy CD & DVD Burning
Acer Aspire 8920-6048 Notebook Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
