Question about Ovens
T mixer large bowl lid gears broken
Large bowl lid dosent work possibly the gears. This is the second one we have had with the same problem.
How can I get hold of manual for supanova convectionair oven.
I can only suggest you contact the maker whom I do not know GOOD LUCK tho
Jan 26, 2015 | Ovens
We just moved into new flat with a whirlpool oven Model No: 6AKP524/1X. There's no manual. What are the 4 buttons on top/front for.
Unfortunately we are unable to offer assistance to those residing outside of the United States. Please visit http://www.whirlpool.com.au for assistance in your region.
Jun 09, 2017 | Whirlpool Ovens
Neff B6774.0GB replace inner glass panel
open the door, loosen the two large screws (t20x or large flat head) near the top of the inner door, this will loosen the main outer door and you can slide it up and off. Look to the hinges and you will see retaining brackets held with two t20x screws, remove these and you then slide the rest of the door off enabling you to work on it on a flat surface. Lie it down with the broken glass as the lowest part. Remove two t20x screws from the two plastic holders near the top of middle frame, slide them out and remove the middle angled frame. Pay attention to which groove in the bottom of the door they are positioned for reassembly. You are now faced with a frame with absolutely mountains of t20x screws which will all have to be removed. when this is done, lift off the frame and you are left with the inner frame, broken glass and mesh panel. carefully take off the mesh screen and discard the broken glass ensuring that you do not inadvertently throw away the black thin seal (looks like a large rubber band). Use a toothbrush to ensure all glass is removed from the inner frame and that the inner edge of the frame is free from food debris etc (This is probably what caused the glass to shatter as the microwaves are attracted to food debris and would have cooked the glass causing a hotspot, this is usually evident if you look at the starting point of where the glass broke). Give the seal a clean also and reposition in the groove around the inner edge of the first frame. position the new glass panel, position the mesh screen and the middle frame. When putting all the screws back in, alternate them. left right top bottom until they are all back in (do not over tighten). Then reassembled the rest of the door by reversing the dismantling info. Let me know how you get on, please leave some feedback.
Nov 22, 2011 | Neff Ovens
My oven display dosent work nor the oven itself it justs beeps and then nothing
greetings,
The membrane or main board has failed most likely. the display itself is built in the board...the beep usually follows some sort of fault code...its possible your having a voltage problem, like a burnt wire on L1 or L2 at the junction box or inside the oven itself. This is not easy to trouble shoot with limited info, but hope this gives you a general idea of what to look for...Bruce Denton
Dec 13, 2010 | Whirlpool RBD275PD Electric Double Oven
Creda Europa Oven an Grill Big oven has Stopped working what would be possible causes
do you mean there isnt any power going to it or it dosent heat up or it just gets warm more detail please
Dec 05, 2010 | Creda Europa E010E Electric Single Oven
I have an older (1997) GE XL144 Gas oven. The burners light but the oven won't heat. Any suggestions?
IF THE PILOT LIGHT IS LIT BUT THE BURNERS DONT FIRE IT IS PROBABLY THE THERMOSTAT. FREEZE A LARGE OVEN PROOF BOWL FULL OF WATER PLACE IT IN THE OVEN FOR TEN MINS TO COOL THE OVEN TO BELOW ROOM TEMP AND THEN TRY THE OVEN IF IT WORKS FOR A SHORT TIME THEN STOPS CHANGE THE THERMOSTAT
Oct 01, 2010 | GE JGRP17 Gas Single Oven
Oven doesn't work, but stove does
Once I opened the lid, the oven reset itself. I then closed the lid and it went off again. I did this again (lifting the lid), and the oven again reset it self. I fiddled with the wiring to the stoves and the bundle of wires, and when i closed the lid again, it did not shut down. It has continued to work.
Dec 13, 2009 | Kenmore Ovens
When oven is on turns its self off after so long then dosent come back on for sevral minutes sometimes 15
We see a common problem caused by a control board failure where the oven shuts off after about 30 seconds, as if you had pressed CANCEL. We repair oven control boards at www.fixyourboard.com.
Oct 05, 2009 | Hotpoint Ovens
Trouble Shooting
I hope by now it is working. You have probably knocked a wire off or actually have broken the burner itself. Can you check it for continuity.It may not appear to be broken but the coil on the inside may be depending on how hard the board hit the element.
Apr 16, 2008 | Kenmore 47783 Electric Single Oven
Hobart Mixer H-600 motor problem
I have new H600 motors cheap if you need them. Got rid of all my equipment and have three motors left over. If interested send an email to cumedia@aol.com and I will send you pics/details.
Dec 05, 2007 | Ovens
Ovens Logo
12 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
