Question about Optoma Pk320 Pk320 Pico Pocket Projector
Optoma pk320 purple screen
Hi I'm Andrew from Greece and I have a technical problem with my mini projector. Periodically as it is working the image is turning to purple instead of white. The menu and everything is purple. It was working, it was working normally, the ventilator inside is seemed ok and it is connected with HDMI cable with my laptop. Also I always have the battery and the power adapter connected (battery and power adapter are original accessories). Where can I find a service center to send my projector for maintenance and to fix that problem?
Marrie
  • 563 Answers
SOURCE: optoma h57 purple tint
Hi tassos2000
I'm afraid this is indeed a Mainboard problem that will require either repair or replacement.
You nearest dealer / repairer of Optoma Projectors in Greece is in Athens , details of the company is as follows:
LEC Hellas S.A.
31 Salaminos Street
Athens
Attica
14343
Tel : +30-210-2851948
They should be able to sort you out mate.
Thanks for using Fixya and good luck !
Posted on May 27, 2008
swami nathan
  • 208 Answers
SOURCE: Optoma EP716 Projector
Make sure that the resolution shown by the projector matches with that of the computer resolution. Many projectors does it automatically.
But if there exists a problem in resolution matching, there is a chance of getting partial picture. So better check that the resolution shown by the projector matches with that of the computer.
Also, the pixel may be degraded due to,
  • Their susceptibility to heat; the organic compounds used in LCD filters - in particular the blue - can be broken down by excess heat, resulting in a degradation of image quality.
  • "Dead Pixels"; pixels can become permanently on or permanently off, and while this is barely noticeable with one dead pixel, the presence of multiple dead pixels can be a irritation.
The only way to fix the problem is to replace the 3 LCD panels which, if you could get the part would cost you more than a new one.
LCDs are really difficult to make so lots of them do actually get passed with dead pixels on them.
But i suggest you to get some advice from the service center too.....
Hope my info solves your problem.
Thanx for using fixya.
Posted on Oct 01, 2008
SOURCE: Connecting Pico projector to a Laptop...
sorry dude the usb is for charging only you need to buy a vga to composite cable and a male to male component cord both purchaseable from this web site http://www.bestofferbuy.com
Posted on Jul 19, 2010
SOURCE: ep738 not creating any image just a white grid.
HI i had the same problem with my Optoma showing the white grid when turned on, and it is not a problem of the lamp not being good good. Sounds odd, but i removed the lamp. then dropped the projector against a hard surface from say 10 inches from floor, tehen a hard tap on the side, then inserted the lamp back in, turned on the darn thing, and it showed the Optoma logo alright, with 2 vertical stripes, then i removed the lamp again, repeated procedure, and by this time the lines wer gone and i got the projector to work again, including all push buttons on panel (this wasn´t possible when i had that problem. It really worked for me. At least you can try it.
Posted on Aug 01, 2010
  • 1417 Answers
SOURCE: Is there a cable adapter I can use to project to a
hello,
The answer is yes.
what you are to do to get your self the USB coed or cable as the cast may be is to order for the cable on line at the below site (note) only if you can not get the cable at any Toshiba out let around your local area or store that deal with computer anniversary then visit the below site
www.computers-online-store.com www.NexTag.com archive.laptopmag.com www.mobilewhack.com
All the above site offer a great comparative price among them self, with the above site you can go on shopping.
Thank you and thanks for using fixya.
Posted on Oct 02, 2010
Why is HDMI input not working?
Apparently, HDMI cables can be finicky. You may have to try different ones to find something the projector "likes".
Sep 01, 2015 | Optoma Pk320 Pk320 Pico Pocket Projector
Optoma HD20 brightness changes periodically
I read the above and it ended up just being my HDMI cable contact being a little lose from me moving the unit around all the time. Just pushed it in and we're back in action!
Jun 11, 2012 | Optoma HD20 DLP Projector
I have an optoma pk301 and vga cable to connect the port I / O is the image projected in purple hue, when I move the connector the picture is normal, but put it down and turns to see purple, I said it was...
its not the projector its the universal vga cable i have the same problem trying to find where i can buy that cable no luck yet if find a place let me know thanks
Jan 18, 2011 | Cameras
I have an OPTOMA H27 projector, I am experiencing problems with the quality of the video images displayed. I set the focus by using the internal menu as an image reference. However when I view DVD/Video...
hi,
if u are using the composite video the try component video. composite video will dive u a dull image than component one. also check the distance between the projector an screen.Make sure the projection screen is between the required distance 4.9 to 40.7 feet (1.5 to 12.5 meters) from the projector.
ok
Dec 30, 2010 | Optoma H27 DLP Multimedia Projector
The image of my optoma hd803 became inverted.
Go into menu settings, look for a menu item that has to do with screen size and orientation. You'll be looking for the option to rotate the image for mounting the projector upside down on a ceiling mount.
Feb 06, 2010 | Optoma HD803 DLP Projector
Optoma h57 purple tint
Hi tassos2000
LEC Hellas S.A.
31 Salaminos Street
Athens
Attica
14343
May 26, 2008 | Optoma H30 Multimedia Projector
Optoma EP 732H Blue/purple tinge
Hi jmm521
Try using a different VGA cable as connection - WILL solve your problem !
Thanks for using Fixya !
Apr 29, 2008 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Optoma projector image yellowing
Very odd problem. Depending on the hours of the projector it could have some glass in it that over heated. Contact Optoma directly, my guess is they will work with you.. good luck
Apr 06, 2008 | Optoma H30 Multimedia Projector
Optoma Pk320 Pk320 Pico Pocket Projector Logo
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
