Question about General Electric 20 Amp, 1 Pole Thick Type THQL Ground Fault Interrupter Ge
Electric is off in 2 rooms but no sign of braker off.
No power to outlets and lights
  • General Elec... Master
  • 5,245 Answers
Push breaker fully off and then back on.
What have you tried so far?
http://waterheatertimer.org/Troubleshoot-household-electricity.html
What kind of breaker?
Are all outlets off on same breaker, or just some of them?
Gene
g
Posted on Nov 25, 2013
How to wire in an on-off switch for ceiling light from power source going to living room.
Pretty easy if you can get the wires from the existing wall outlet. Just run a wire from existing outlet to the where you want the new light. Install inside an approved ceiling electrical outlet box and then run another wire to where you want the switch or switches. If you go to home depot or the library you can look at the books with diagrams on how to wire it. You can skip the wall switch if you use a light with a pull chain.
Sep 20, 2014 | Electric Electrical Supplies
Active Smart Control Fridge Freezer E402B.Has just shut down.Going fine than it just shut down.No power.No lights,No compressor,No fans?????The power outlet that provided power to fridge seemed very h
first check the braker in the electrical panel for that line. the braker with the problem will be in the mid posison. reset it by pulling allway back and then all the way on...
Mar 30, 2014 | Refrigerators
There is no power to the speaker, the green light is not showing. We have changed the plug fuse but this was not the problem
If you're talking about a powered subwoofer pluged into an electrical wall outlet check the wall outlet. One of my kids could not get a lamp to turn on in the den. It turned out the outlet was switched off from accross the room by a wall light switch. To check your electric wall outlet, plug in something, like a lamp, fan or a clock and see if it turns on. If not, look for wall light switches and flip them on and off. If it (example fan) dosn't turn on, you have a problem with your house electrical system. Probably right there at that outlet.
Sep 08, 2011 | Revel Audio Players & Recorders
Where are the fusses Iblew the braker and now ther is no power to the stove even when braker back on
There are no fuses for this....
With your description it would seem more like the wiring is bad at the terminal block where the cord hooks fast at the block, the outlet is bad where the cord plugs in, or there is a wire burnt off inside the range...
All of these are common causes of the type of failure you have experienced...
I would start with the outlet and check for power with a meter there and then follow the power till you find the problem...
To adequately troubleshoot this you will need to have a meter and know how to use it...
heatman101
Feb 19, 2011 | Kenmore 91112 / 91114 / 91117 Electric...
Our kenmore elite quiet pack 2 front load washer appears to have no power at all. No lights, no codes, nothing. Worked as expect just 2 days prior. No brakers have been tripped on the electric panel...
Always start with the simplest thing, verify that the outlet is good before troubleshooting the machine. I cannot tell you how often the home electrical is the problem not the machine.
Nov 27, 2017 | Kenmore Elite 45986 Front Load Washer
How many outlets will this carry?
While there is a practical limit for the number of outlets on a 15 or 20 amp general purpose lighting circuit in a _residence_, the National Electric Code (NEC) does not impose a # of outlets per circuit limit (residential ONLY).
However, some electrician's design general purpose lighting circuits in a residence using a point system. An outlet is 2 points and a light is 1 point. So, for a twenty amp circuit, (10 outlets x 2 points) = 20. Or, (5 outlets x 2 points) + (10 lights x 1 point) = 10 + 10 = 20. Or (8 outlets x 2 points) + (4 lights x 1 point) = 16 + 4 = 20. However you want to mix it up.
Now, if this is for a Commercial building, the the NEC allows no more than 180 VA (Volt Amps) per outlet. 180 VA / 120 Volts = 1.5 Amps.
20 amps / 1.5 Amps = 13.3 outlets. Drop the .3 and one determines that 13 outlets are allowed on a Commercial 20 amp circuit.
Also, if the 20 amp circuit is considered a continuous circuit (ON for more than 3 hours a day), then it can only be loaded to 80%. 80% of 20 amps = 16 amps.
Aug 07, 2010 | General Electric 20 Amp, 1 Pole Thick Type...
Lost electrical power at 2 outlets. No TV power
wires could be crossed or burnt out
Jun 14, 2009 | Televison & Video
Marley B2451 wall heater
These are only 1500 watt heaters.
They 'could' heat a 20 x 20 foot room (with good, tight construction), with a slow temperture rise.
Check the company web site at http://www.qmarkmeh.com/
Doug
Jan 22, 2009 | Marley Electric Hydronic Baseboard Heater,...
Frigidaire FGF337ECC - electric issue
SOUNDS LIKE YOU MAY HAVE SHORTED SOMETHIN ON THE CLOCK IF YOU HAVE SWITCHED OUTLETS (AND KNOW FOR SURE THAT OUTLET HAS POWER). IT MAY BE POSSIBLE YOU BLEW A BRAKER AND THE OTHER OUTLET IS IN THE AME LINE.
Feb 08, 2008 | Frigidaire FGF378AC Gas Kitchen Range
General Electric 20 Amp, 1 Pole Thick Type THQL Ground Fault Interrupter Ge Logo
66 people viewed this question
Top General Electric Electrical Supplies Experts
Rob Bridges
Level 1 Expert
ken skalski
David Harrelson
David Harrelson
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
