Question about Ruud Rheem Weather King Furnace Air Handler Control Circuit Board 47-100436-84j
Closing vents in winter - Ruud Rheem Weather King Furnace Air Handler Control Circuit Board 47-100436-84j
    Master:
  • 571 Answers
One or two rooms is ok...anything more than that, you'll have to get someone to check you air flow.
Posted on Dec 17, 2013
SOME HEAT COMING OUT IF THE DRIVER SIDE VENTS COLD AIR COMING OUT OF THE PASSANGER SIDE VENT.
im taking it that it is not a duel climate system? the door in the box under the dash is not closing the door all the way. either there is an obstruction in the door, the seal has worn and letting hot air thru the door or the motor/cable is not shutting the door.not going to like the solution. the case needs to be removed and inspected for the problem. or if your looking for a quick fix you can install a shut off valve on the intake side of the heater core under the hood near where the water goes into the heater core so you can turn off the hot water during the summer and turn it on in the winter
Jan 20, 2011 | 2002 Toyota Camry
No air conditioned airflow from the dash vents but ok from the floor vents when on
flapper valve not closing properly..usually vacuum controlled..do you hear flapping opening and closing..this is inside the duct work
Jan 20, 2011 | 2006 Chevrolet Trailblazer
How to winterize ? i have the jandy lrz model 125000 natural gas and what to know how to close down and winterize
turn off gas valve and blow water out with air then with RV antifreeze when you see antifreeze coming out its good see you tube video on pool closing
Oct 27, 2010 | Jandy Legacy LRZ 125000 BTU Millivolt...
Vent below clock puts out alot of heat
That is the oven vent and it will throw alot of heat when the oven is on... that is very normal operation...the oven needs to be vented to for various reasons...
This can be a great benefit in the winter time but is very uncomfortable in the summer...so limit the summer use and use it like crazy in the winter...
heatman101
Sep 14, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Blower stopped and won't restart
check fuel,air filters. Mine did the same thing and fuel was bad after sitting over winter time. Always run blower out of fuel when closing it for winter and ALWAYS replace with new clean fuel at start of next year
May 30, 2010 | Echo 001106 Power Blower Helper Handle...
Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Apr 27, 2009 | General Electric PVM1870SMSS Microwave...
No air coming through the vents
Sounds like the door that brings in fresh air is not closing enough so when you get to moving it is not letting the cab recirculate the inside air and bringing in some from the outside which comes from the bottom of the windshield on the outside. along with when you get to hitting the gas going down the road you might be loosing a little vacuum and that door going to your vents might close a little.. ? what you thinkin? just a few ideas might not be a fix though thanks Jerry
Apr 21, 2009 | Chevrolet K2500 Cars & Trucks
Can i cover my outside house vents in the winter?
you should never cover any vents, they are there for a reason, to keep you safe from fumes, damp, etc.. (If talking about vents that are outside you home). If you are talking about appliance vents then you run the risk of them breaking if you cover the vents, due to overheating
Vents that are outside the home including boiler vents etc... exhume all of the carbon dioxide that is bad for you. Vents that are there to stop damp, if blocked may cause you to have a problem with damp in the future.
Jan 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ruud Rheem Weather King Furnace Air Handler Control Circuit Board 47-100436-84j Logo
29 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
