Reset instructions for PIR floodlight
I have lost instructions for setting up a Homebase PIR floodlight so it detects movement and turns off after the preste time.
    New Friend:
  • 52 Answers
There should be a screw adjustment under the PIR unit. Clockwise direction increases the amount of time it stays on and anticlockwise decreases the amount of time it stays on. It's usually a small hole which you can see a slot in which you turn with a screwdriver.
Posted on Nov 24, 2013
How do I het the MM7581 Security floodlight to operate properly?
Here's the link and I'm sure you will get the solution of your problem
Best Manuals
Aug 11, 2016 | Cars & Trucks
Does anyone have the instructions which come with a micromark MM18033 500W Floodlight and WIREFREE PIR SENSOR? Thank you
Yes.
e-mail me at iclarke@rockelectronics.co.uk and I'll send you the 4 sheets f.o.c.
Sep 29, 2014 | Electrical Supplies
Cooper ms34w wont turn off stays on night an day without movment
Have you had a look at the underside of the motion detector the should be some things for you to a just it with
Mar 25, 2014 | Cooper Lighting Flood Lights. 180 Degree...
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
Nov 12, 2012 | Woods Outdoor Lighting Timer
Got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Jun 01, 2009 | Black & Decker Garden
HELP l need instructions for Homebase LF320 air cooler
I have the same unit, also given to me, and there really isn't much to it. Remember, it's an 'air cooler, not an air conditioning unit. Works fine as a floor standing fan on L, M and H settings (lo, med and high) but, if you want the air to cool slightly, freeze the blue ice packs and then put them in the base of the unit and top up with cold water until the level indicator on the front says full (red ball hits red arrow, like in a kettle). Then, turn on as normal and run the 'Cool' function along with your desired fan setting (L, M or H). I tend to add a few extra ice packs. The 'Cool' setting drags a fiber membrane into the water and over the intake surface, thus cooling the air slightly. Nothing like real air con but better than nothing on a day like today. 'Swing' throws the air around a little and 'Mode' gives you bursts of air, and that's about it to be honest...
Apr 07, 2009 | House Brand Dryers
My motion sensor stopped working--the lights are full on all day.
Good Morning -
Make sure the bulb is point in the right direction and don't use an incadescent? bulb like a 60 watt bulb.
make sure you use floodlightor spot light bulbs so theydon't shine on the sensor.
Have a Great Day!!
Dec 09, 2008 | Electrical Supplies
Televison & Video Logo
440 people viewed this question
Top Televison & Video Experts
Electro Med Services...
