Question about Plumbing
Elkay ezfs81b The water does not always shut off when the right push bar is used to turn on the water flow. How do I troubleshoot this problem and fix it?
    Novelist:
    Champion:
  • 227 Answers
A little WD-40 can go a long way.
Posted on Jan 18, 2014
My Elkay water fountain is clogged up, water does not drain properly, how do I unclog
To unclog the elkay water fountain just look out for push button catridge and and turning it to adjust how far it is pushed or you can even try with chemical drain cleaners like draino or liquid plumber or CLR(Calcium,Lime and Rust Remover) & if still the problem hire plumbing repair services.
All Plumbing Repairs
Apr 29, 2015 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Water fountain elkay model # edfp17c
Feel the water coming out of it to determine if its the cold water side of the hot. More then likely you broke something and to determine what it is will require you to remove it. Home Depot has sink bolt removal tool that makes it much easier. After you find where the problem is then contact manufacture and usually they will send you free parts to fix or complete new one.
Mar 12, 2014 | Elkay Home
The water flow is coming out at about a third of the usual flow. What is wrong? and how to fix this problem?
Try removing the faucet aerator. Turn both hot and cold water on and see if flow is adequate. Clean or replace aerator if that's the problem.
Apr 23, 2011 | Elkay BLH15C Lustertone Self-Rimming...
Elkay drinking fountain M#erpb28c continuously runs, having problems getting mounting nut back onto bubbler, seems basin should come off for access, however needind a reapir manual or access instructions...
The Elkay fountains are turned on by a solenoid powered valve. There is a rubber grommet in that valve assembly that gets holes in it and then water gets behind it, causing the valve to stick on. To test that it is a solenoid problem, turn the water on and then unplug the power to the fountain--if the water continues to run you have a solenoid problem. You'll need to replace the solenoid and I've detailed how to do it with all the steps and lots of pictures on my blog: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Feb 22, 2011 | Vacuums
HOW DO YOU GET THE EKLAY WATER FOUNTAIN APART TO REPLACE SOLENOID SWITCH
I have written up the entire process with all the steps and lots of pictures on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html
Sep 16, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Restricted flow old kitchen faucet
While not always the case, low flow is usually caused by a plugged aerator. The aerator is the device that softens the water flow as it comes out of the faucet. Unscrew it, remove it, and clean any debris out of it.
Before you put it back, turn the faucet on briefly to flush any other debris out and to see if the water pressure is better. If not, there could be a cartridge (if equipped) issue of some piping problem.
Mar 14, 2010 | Elkay Plumbing
Water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
