Question about Refrigerators
I have a fj383 Westinghouse freezer it isn't freezing the food My email is charmaine@hispeedgas.com.au
    Top Expert:
  • Refrigerators Master
  • 12,962 Answers
If you have ice on back wall of freezer compartment the self defrosting mechanism of unit is not working. check the defrost timer and defrost heating element for peoper operation.
Posted on Nov 28, 2013
  • 833 Answers
SOURCE: We have a Westinghouse WSE6100SA
This could also be an issue with simply too much food in the fridge blocking some of the air channels or that there are containers in there which are uncovered which contribute to high humidity in the box.The unit may also be left open too much.
Before blaming the manufacturer/servicer...let's look at the usage cycle.  This ice is coming from somewhere!  Do a full defrost of the unit.  Keep it closed after loading in food.  What is the temperature in the box?  40F in the fridge and 0 F in the freezer is about right.  Use an outdoor thermometer and check after an hour of closed door.
Posted on Nov 26, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
Sea Breeze
  • 4654 Answers
SOURCE: westinghouse fj383
What are your temperatures now and is the freezer bring down the tempetures OK at this point? Sorry for jumping into this gshaw71 but I just want to see a consistant drop in temperatures before we realize the freezer is not getting the meat frozen, Let us all know so as a team we can help you tinalouise, Thanks, sea breeze
Posted on Dec 29, 2009
miket756
  • 2702 Answers
SOURCE: Westinghouse WSE6100SA fridge in side by side fridge freezer free
the thermostat has broken down and needs to be replaced,, normaly when they brake down they just stay in the closed poshion so the fridge freezes up get a new one fitted and all will be well
Posted on Feb 19, 2010
Testimonial: "Thanks for you fast response, very helpful. I thought this may be the problem but wasnt sure. Are the thermostats easy to replace? Could I DIY, How?"
heatman101
  • 43501 Answers
SOURCE: my fridge isn`t chilling and my freezer isn`t freezing.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 03, 2010
My Westinghouse Freestyle Freezer FJ383 wobbles on the floor. How do I fix?
There are feet on each coner that can be turned to make them go up or down. you may need a person to slightly lift or tilt the unit and a pair of strong pliers to get the feet turning.
Jul 14, 2016 | Westinghouse Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Westinghouse fj383
ne of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them
Dec 10, 2013 | Freezers
Fridge compartment is freezing contents, freezer is OK however. controls have been set to lowest setting for 3days now
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Sep 09, 2011 | Westinghouse Refrigerators
I have a Westinghouse Moist Cold Cylic Defrost refridgerator the freezer is great but my fridge area is on the lowest setting but is freezing my food, ,Why is this ?
heatman101
May 02, 2011 | Refrigerators
Feb 19, 2010 | Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Westinghouse fj383
I have a Westinghouse upright freezer FJ383M-R. The red light was on bright and the top half of freezer was not working. Turns out it was a switch that turns the defrost cycle on was faulty. Serveman replaced borken part. Now it is fine. Was much cheaper than replacing freezer.
Nov 28, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refrigerators Logo
178 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
