Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Netgear WN111V2 adapter is disconnected
I have had my netgear router & adapter for abt 5 years now no problems? I got an AVG update and it seems to have knocked out my adapter connected to my XP Computer?? The wireless network is fine as I can access the internet on my laptop Windows 7 and my I pad? Can anyone advise me how to fix this please??
  • Jacqueline Dillimore
    Jacqueline Dillimore Nov 24, 2013
    Problem Solved!!!! Many Many Thanks!!!!
  • NetGear Master
  • 17,093 Answers
Uninstall the AVG program or see what the firewall settings are.
Posted on Nov 24, 2013
  • 9 Answers
SOURCE: netgear wn111 adapter doesnt work
have u tryed downloading latest drivers??
Posted on May 06, 2009
anandg27
  • 1272 Answers
SOURCE: Netgear Wireless adapter not working
Hi, Follow the steps below to configure the wireless adapter settings on the XP system:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 29, 2009
Boneysin
  • 15 Answers
SOURCE: Netgear WPN111 wireless adapter won't connect
Is the computer Windows 98 SE [Second Edition] ?
What is the exact error message that you get ?
Posted on Mar 29, 2008
vincent721
  • 240 Answers
SOURCE: netgear wireless adapter disconnects from router randomly
check for firmware update for your adapter...since it usb..u need to put it in open..i believed the USB extension is included when u purchased that.
do not connect the USB adapter to a USB hub unless the HUB is powered so that it can performed better. Connect it directly to your PC slot
Posted on Mar 13, 2009
redhaze89
  • 854 Answers
SOURCE: Netgear wireless N USB adapter wont connect to my netgear router
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
For wireless N USB adapter
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Posted on Aug 16, 2009
Netgear WN111v2 Adapter disconnected
Is the Netgear Wi-Fi Management software installed on the computer? If it is, you may have a conflict between Window's built in Wi-Fi Manager and the Netgear Wi-Fi Manager. If it isn't, you may need to install it.
Assuming it isn't, there's links to download the software at the Netgear Global Download Center.
I would default to the most current version, if you're running Windows XP, you may need to install the v2.1, however, I would assume the v3.1 would be backward compatible with XP.
Install the software and follow the prompts that will guide you through the installation/setup.
Now, if the software is already installed, you need to find the program and configure it through that avenue. If that does not fix the issue, you should uninstall the Netgear software, remove the Wi-Fi adapter and reboot the computer. After it completely boots back up, you should either plug in the Wi-Fi adapter, let Windows recognize it and install the drivers, (they should still be in the system even after you uninstalled the software). Once Windows successfully locates and installs the drivers, reboot the computer again, (no need to remove the adapter). Once Windows completely loads again, open Start, Control Panel, and System. On the resulting window, click the hardware tab at the top then click the "Hardware Manager" button in the middle about 1/3 down the window. Click the "+" next to "Network Adapters" and verify that your WN111v2 is indeed installed.
Assuming it is at this point, close out everything but the Control Panel and open "Network Connections". Find the wireless adapter there, (may be listed as "wireless connection2" depending on how many times it's been installed). Right click on the wireless device and select "Show Available Wireless Networks"
I'm also uploading a video showing what needs to be done.
Establishing WiFi Access in WinXP
Jan 27, 2014 | NetGear Computers & Internet
Netgear WN111V2 adapter disconnected
you may have to reset the wireless network and the computer and restart the network first then the computer
Jan 27, 2014 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I cant turn off the MAC filtering on my netgear wn111v2 adapter
MAC address filtering is turned off on the wireless router.
You cannot turn MAC address filtering on the wireless adapter.
Jul 14, 2011 | Computers & Internet
I am currently running internet on a NetGear wireless WG111V3 adapter and I am trying to install the NetGear wireless WN111V2. As far as I know I have all of the correct drivers and also updated Windows...
1 Download using the button below to a convenient place such as your desktop.
NOTE: After downloading, DO NOT RUN THE FILE YET. Please proceed to Step 2.
Download Link
2. To properly install adapter software, please remove drivers that were previously installed.
To uninstall, go to Start > Programs > NETGEAR WN111v2 adapter > Uninstall NETGEAR WN111v2 adapter or through ADD/Remove program
3. Unplug the WN111v2 adapter from your computer.
4. Run the file you just downloaded and follow the on-screen install instructions.
Mar 01, 2011 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Why is the transfer rate of wn111v2 only about 1% of max?
Perhaps it has to do with the speed of the Network Connection?
Nov 28, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Netgear WN111v2 software won't install
Hi, Visit the link below to download the latest drivers for the adapter:
http://kb.netgear.com/app/answers/detail/a_id/7528
Install the adapter using these drivers and configure the wireless connection.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 27, 2009 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Netgear DG834G V4 Website connection problems
Please try to use a difrent DNS service.
For example open DNS:
Primary: 208.67.222.222
Secundary: 208.67.220.220
Jan 14, 2009 | NetGear DG834G Router
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
74 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
