Question about Samsung M7E HM321HI 320 GB SATA Hard Drive
Win 7 driver SATA - Samsung M7E HM321HI 320 GB SATA Hard Drive
Pci ide controller drivers
Probably need new motherboard + win 7 or 8
Dec 12, 2013 | SIIG 2 Port eSATA II PCIe Pro - 2 x 7-pin...
Instal xp on panasoc cf 71
had same problem with loading win xp proff on cf 74 toughbook mk1.
soution for me was downloading sata hdd controller from panasonic toughbook support site, loading the driver onto floppy drive, using usb floppy with driver ready to use, loading win xp profesional and on first loading win screen pressing f6 when prompted at beginning of win intallation, when on screen instructions to load sata driver appeared, i followed on screen instructions and loaded 3rd option from floppy sata drive mobile driver, left usb installed untill xp loaded and running, do not remove usb floppy untill win loaded, i really hope this helps you
Mar 25, 2013 | Panasonic Toughbook CF-27 Notebook
Win 7 not install in my pc mother board P4M800-M7 sata hdd not show
Hello here are the homepages:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=531&CategoryID=1&MenuID=16&LanID=9
Here are the other model ( version 3,1 )
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=548&CategoryID=1&MenuID=16&LanID=9
This is important when the drivers needed to be found.
But here seems to be no drivers for windows 7.
Here is only drivers for vista and xp, and there is absolutely no guaranty, the drivers will work on windows 7.
You need to setup the bios boot settings, in order to boot from the drive.
First boot device dvd drive, and second the harddrive.
This selection is urgent, when installing windows.
Other selections maybe needed, depending on the bios version.
The sata drive, should be shown in the bios main meny, when entering the bios.
I suggest you to download the manual, if you don`t have it, and read the setup install section, for basic boot procedure.
Best of luck
Feb 25, 2013 | Computers & Internet
How to install windows 7 on acer aspire 1640
Maybe the Vista drivers will do. If the Win & drivers are not listed, then more than likely the vista drives are compatible.
Mar 31, 2012 | Acer Aspire M1640 Refurbished Intel...
Hello, Where could I find a driver for WD5000KS SATA? I am trying to upgrade my desktop PC to Win 7 but when installing it, the setup could not detect the SATA HDD and asked me to load the HDD driver. ...
Check in your BIOS,first make sure the SATA controller is set to native mode and not RAID, and secondly that the BIOS can detect the drive, if the drive can't be detected by the BIOS then it's because the drive surpasses the boards drive size limitation.; If this is the case there is a chance a BIOS update may fix it but it's not guaranteed it will.
Jan 05, 2011 | Western Digital Caviar SE16 (WD5000KS)...
I want istall win xp o/s so i need to change bios setup to detect the hardisk drive. how can i change bios srtup?
Here is what you need to do to install XP on your laptop that came with Vista or Win 7.
If your hard drive is SATA (pretty much standard these days) you will need to search the manufacturer's site for a floppy disk SATA driver install package.* You will need a USB floppy drive for installing XP.
* Copy the SATA drivers (should be denoted as "F6 drivers" or similar) to a blank disk.
* Have the USB drive connected. It should automatically map as A:\.
* Go into BIOS and find a setting for ACPI Compatible and set on.
* Now install XP normally from the CDROM, and when it says "press F6 to install third-party drivers", press F6 and follow the options to get the SATA drivers from the disk.
* Complete setup as normal.
or
You can check the following link for more detailed info.
Thanks !!
Please rate the solution if it helps you.
Nov 23, 2010 | HP Compaq nc6220 Notebook
I have Toshiba Laptop L300. It does not install xp . however it easily install Window 7
Probably because you have a SATA Hard Drive. If you want to install WIN XP, you may need to change your hard drive settings. For this go to the BIOS and change to Compatible Mode or IDE or Non SATA. The Reasons that WIN 7 install with no problems is because WIN 7 has already builtIn SATA drivers on it
Nov 18, 2010 | Toshiba Computers & Internet
Samsung M7E HM321HI 320 GB SATA Hard Drive Logo
29 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
