Question about Ovens
Set timer on teba oven
The dial is flashing 000 auto. I need to set timer so that oven works.how do you set timer .ther are 6 dials underneath the flashing dials.TIMER>GRill TIMER>A HAND>STOP>0 + 6 functions,So it must be a combination of pressing these ?thanks Spencer.
2 Suggested Answers
  • 905 Answers
SOURCE: How do I turn an
You didn't specify which exact model that you have, but here is a list of various manuals that may answer your question.
Posted on Jul 18, 2010
Power failure,now 000 is flashing on oven exterior
If the 000 is on the display left of centre, then you possibly just need to reset the clock. from left to right-....press the first button to activate the clock setting phase....press the next button to pop out the rotating timer adjust and set the time.
If it is the display above the centre control dial pls repost with the full Enr from the rating plate.
Feb 25, 2013 | Neff B1881 Single circotherm super...
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
Where can i get a manual for a built in teba fan oven. It has reset itself and the timer switches off after 2 minutes and I cannot reset to not use the timer so cannot cook anything in the oven.
Try pressing the stop/cancel button, this should clear the error, if this does not work unplug for 5 minutes and then plug back up , this should clear the display and the oven should work.
Nov 14, 2009 | Ovens
Cant fix the clock to work without the timer
if you are having trouble setting the clock times etc this is probably down to a worn bit generator this is the knob you turn to set the time they get dirty when using oven or grill and wont operate properly,the clock will need changing im afraid as there no way to open the clock without destroying it.
hope this helps
Jul 09, 2009 | Neff B1421 Electric Single Oven
Oven not heating
If it has a digital timer, make sure it is set to auto and not manual, as oven will not heat if it is on auto.
If it is a anolgue timer ,then it should be showing a hand symbol,if it is not, then turn knob or dial until it does.
If these settings are o/k, then could be a faulty element.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Ovens
Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
Nov 22, 2008 | Neff U1721 Double circotherm Electric Oven
Oven does not work
If it has an auto timer, then make sure it is set to manual operation
Nov 17, 2008 | GE Ovens
Zanussi lower oven not working
You should try to get a replacement dial first and go from there.
Oct 14, 2008 | Zanussi ZHQ575 Electric Double Oven
Ovens Logo
42 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
