I need to replace the programme selector on my Hoover optima washing machine, model no OPH714D, how do I do it
SOURCE: hoover optima hnl 7166
I'm Neil, Glad to be of assistance for you!
Sounds like you need service.
Try :
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Neil
SOURCE: my hoover optima washing machine
Make sure it is not on rinse hold or crease care, release if it is, make sure pump is working, and that the cold inlet valve is working., all of these things could prevent it from completing rinse cycle.
Plz rate this solution.
Thanks.
SOURCE: How do you remove the filter for a Hoover washing
I included a link on Youtube to my Nextra where I show how I clean the filter (watch it from 08:55 onwords). Just remove the kick strip and unscrew (philips screwdriver needed) the little screw on the filter itself, then turn it anti-clockwise but while you're doing this make sure you insert the kick strip underneath to gather the residual water. Repeat this operation 3 o 4 times until the sump is totally empty, make sure you don't let the kick strip fill up too much otherwise you'll be spilling water all over the place, so just turn the filter clockwise everytime you want to stop the trickle of water. It's not too complicated and it won't be too messy if you follow these instructions carefully. Good luck ;-)
SOURCE: Have a hoover optima 1400 only a few months old. i
check u have not got any blockages in the pipe that leads 2 underneath ur sink
SOURCE: hoover oph 714d optima 7kg
Hi
Error code e005 means the temperature sensor has gone bad. To fix this error you'll need to replace the temperature sensor. It might have happened that the temperature sensor wires have been disconnected from the main board. To replace the temperature sensor you'll need to disassemble the washer and inspect the drum's bottom for the temperature sensor. Also check the wires coming to the sensor fro any cut.
Please post back for any further assistance.
Daniel
