Question about HP LaserJet Office Equipment & Supplies
Faded printing in the middle while very good printing on the sided. I'm using a new black cartridge that was working fine two days ago HP LaserJet P2050
    New Friend:
  • 33 Answers
Check follows : - Fuser assembly ( Teflon sleeve is proper or not ?)
Laser Beam Scanning unit.
Posted on Nov 24, 2013
SOURCE: Magicolor 2400W print fades on right side of page
Have you tried cleaning the leans at the bottom of the printer? Open the cover, pull out the drum. Under it is a long, narrow piece of glass. If it gets dusty or toner accumulates on it, it will cause streaks in the printing. If this is dirty, take a clean, soft cloth and very gently wipe it off.
Posted on Jun 01, 2008
kevin000
  • 1847 Answers
SOURCE: hp laserjet 1022 not printing
try reinstall the printer.
do a hard reset and then reset the printer from menu.
reinstall the ink tanks.
Posted on Aug 15, 2008
Corysf62
  • 188 Answers
SOURCE: Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Posted on Oct 30, 2008
  • 3 Answers
SOURCE: HP Color Laserjet 3500 printer - no black on left side of page
The folded paper solution for for me. Thanks to all for sharing!!!!
I had the same problem. No black or cyan on the left side of the pages. From this advice... I folded a stack of 4 pieces of paper in half and then half again. I took out the transfer unit and put the folded paper in the upper left corner and then put the transfer unit back in. WORKS BEAUTIFULLY! Thanks you all sooooo... much!
Posted on Jan 03, 2009
SOURCE: Faded red / pink on HP Color Laserjet 2605
you have to clean the image mirrors you can find a how to guide on hp's web site titled "fading red tones on color laserjet2600' process takes about 30mins to do.
Posted on May 11, 2009
Printer only won't print in black
My printer did that a few months ago. I tried everything to get it printing black but in the end I had to take the ink cartridge back and return a new one. Some ink cartridges dry out when they are being shipped if not stored in proper conditions.
Mar 14, 2010 | HP Officejet 6500 Wireless All-in-One...
Black ink started to print blue/mauve
Many thanks for the suggestions received. Have been told by HP to
change the black printhead - which has solved the problem!
Dec 22, 2009 | HP Designjet 110plus nr InkJet Printer
HP 1510 all in one printer won't print black.
It might be the cable ribbon to the black cartridge. If thats the case see if there are any rips in the line itself.
Jun 30, 2009 | HP PSC 1510 All-In-One InkJet Printer
PRINT FADING ON RIGHT HAND SIDE WHILE BLACK CARTRIDGE SHOWS FULL.
your cartridge is third party toner insert new hp original cartridge before cleaning
Jun 23, 2009 | HP Color LaserJet 2600n Printer
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
Printer reads out "Print Cartridge problem (Tri Color) Refer to device documentation to trouble shoot" I purchased this HP Officejet J4550 All-in-one unit new and haven't made any color pictures with it....
I discovered on mine, exact same problem, I opened the tray, removed the cartridge, and forced it back in hard and fast. It didn't work the first 12 times but after that, it got a solid connection and it worked. Works fine now. Anyway that's the problem and the problem isn't the cartridge (genuine hp cart here). The problem is on the printer side, the pins that hit the cartridge. Anyway get rough with it, slam it in and out, close the tray, if it doesn't work within 5 seconds, open the tray and do it again. It WILL work.
Mar 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP 5610 - printing fades down the page
the printer carriage might be wearing out, it happens on the 5610's, may be time for a new printer. The fading issue sounds like a cartridge issue. Try a oem?
Nov 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 6110 not printing with black ink
Hi lilacky-
Here are some HP support links that might be helpful... and a couple questions to consider.
Q: Is your new cartridge one of these listed below?
"The HP Officejet 6100 series and HP Digital Copier Printer 410 products use the print cartridges listed below:
* HP 56 black print cartridge
* HP 57 tri-color print cartridge
* HP 58 photo cartridge (replaces the HP 56 black print cartridge for six-ink photo printing)" info from: Installing a Print Cartridge
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&lang=en&rule=12548&product=79477 Is your new cartridge a refilled cartridge? Some times those have special challenges. Has your cartridge been sitting a while in the box, maybe in a warm spot? Some times even new cartridges dry out a little. Was your old cartridge low or completely gone? Just as a test, if you put it back in your printer does the old cartridge work? Any printer error messages? Can you print a test page or an alignment page for your black cartridge? These might be too many questions but here are some HP support links with some How To information for getting more answers. Please let me know if any of these are helpful. see also: Slow or No Response from Printer
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=11882&lc=en&dlc=en&cc=us&lang=en&product=79477 -JW
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
44 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
