Question about Canon iR 2016i Black and White Copier
Problem with copier canon ir 2016 seting language from france to english
Language seting
  • 28 Answers
SOURCE: CANON IR2016
hi... try to clean up your copier... usually dust accumulates inside the copier that's why paper inserted will always jam....always see to it that you copier is free from dust and other small particles that would cause your machine to get errors....
Posted on Feb 28, 2008
fer_nan_14
  • 76 Answers
SOURCE: copier model canon ir 2016 (down load stand by )
hi if yo have knowledge on electronics try to remove the boot rom and memory and let the machine for 10 minutes,then put it back the memory and boot rom,and turn on the machine.if the same thing try to update the firmware using sst
Posted on Mar 06, 2009
SOURCE: Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Posted on Apr 09, 2009
SOURCE: canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
Posted on Apr 20, 2009
  • 117 Answers
SOURCE: canon ir 2016 problem E019
Product : imageRUNNER 2200/2800/3300(i)/2220N(i)/3320N(i) Title : E019
Error :
E019-0000 is displayed on the control panel.
Workaround :
This error code is the indication of the waste toner container being full or a problem with the detection mechanism. Actions to be taken are:1. Turn the machine off and check the waste toner container. If the container is full, empty the container. Clean the inside and outside of the container's neck with alcohol. Be sure that the neck is clear and not soiled with toner before placing it back into the machine. Turn the machine on and check to see if the code went away.
2. If the container isempty and the code is still displayed, check the neck of the container. Turn the machine off and check the container,if the neck is dirty, clean the inside and outside with alcohol before placing it back into the machine. Turn the machine on and check to see if the code went away.
3. If the machine still displays the code after the bottle is emptied and the neck clean; check the sensor, the sensor connections to and from the DC controller PCB for continuity, and the proper positioning of the sensor. Replace the sensor if it is damaged or excessively soiled with toner.
Posted on May 07, 2009
Language setting to English in canon ir2016i
Dear User,
press additional setting in canon ir 2016 photocopier.then choose language setting tab now select the language by pressing + or - button then save it. it may work.
Oct 16, 2016 | Canon imageRUNNER 2016 All-In-One Laser...
My english language is deleted from language seting in canon ir 3300. how does i load the english language?
To be able to select languages on the control display panel of the imageRUNNER, first you have to flash the machine with the languages that you need. You can do that by installing system software for English language. Then proceed to the the steps below to select the desired language. To Select the Desired Language:
1. Go to Service Mode, *, 2 and 8, *.
2. Select Copier.
3. Select Option.
4. Select Body.
5. Press the right arrow and scroll to the 3rd screen.
6. Select RMT-LANG. For English, it should read en.
7. To change the language, hit the +/- sign until you find the desired language.
8. Select OK.
9. Then power cycle the machine.
Dec 06, 2014 | Canon IR 3300 Digital Copier
The fusing unit needs to be replaced or repaired. Contact your dealer or service person
Nov 20, 2011 | Canon CLC 1140 Copier
I HAVE A NEW CANON IR 2016 COPIER/PRINTER.
I have canon ir 2016 printer.How I install it .
Jul 31, 2010 | Canon Office Equipment & Supplies
How do I change the the language setting from
To Change the language to English-Press the additional funktion key (The sircle with a star button)
Scroll with the arrows untill no 12 press OK.Scroll untill English is displayed.Press OK
Let me know
Dec 04, 2009 | Canon iR 2016i Black and White Copier
Canon ir 2016 cannot/wont connect to computer via usb
Nov 14, 2008 | Canon ImageRunner 2016 Copier
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Dec 04, 2007 | Canon CLC 1140 Copier
Canon iR 2016i Black and White Copier Logo
21 people viewed this question
old marine
old marine
