Question about Konica Minolta Office Equipment & Supplies
Konica minolta C350 frozen at startup screen
Power comes on, Startup checks are incomplete, screen freezes with "please wait" visible, can't seem to reset it and it doesn't get to the fault codes. Is there another master reset that I can try ?
  • Konica Minolta Master
  • 6,674 Answers
Power off the machine using the main switch not the one on the side of the control panel leave that on. turn on the main with the utility/counter button depressed. keep depress should see a trouble reset touch get ok. see if restarts if not power off Wait ten seconds power on. if not might have a firmware issue copier OS maybe difficult o to find atech let along get the Konicaminolta firmware
Posted on Mar 10, 2018
  • 3 Answers
SOURCE: Error code on Konica Minolta C350
There is not a C0876 listed in the service manual. Perhaps it's a C0B76 - Finishing option Punch Unit Board Malfunction.
CAUSE: The shaft on which the gear rides is deformed. The punch unit cannot be driven from front to rear.
SOLUTION: Reform the shaft toward the punch unit rail. This will allow the drive gears to mesh properly so the punch unit can be mechanically driven from front to rear.
Posted on Aug 30, 2008
herminio_hal
  • 210 Answers
SOURCE: I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
Posted on Jul 09, 2009
firecontrol7
  • 6674 Answers
SOURCE: Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Posted on Jul 19, 2009
djklermund
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
  • 1297 Answers
SOURCE: konica minolta c350 doesn't working in windows 8
Download the PS version for printer driver on to konicaminolta support.
Posted on Mar 22, 2013
We have two Konica Minolta (Develop) c203s which won't boot up. Both working fine one day, then overnight seems to have frozen. I.e. Turn of the main power switch, the two status lights (Orange and blue)...
Try to Troubleshoot By SWITCH ON MACHINE FROM MAIN POWER SWITCH BY PRESSING UTILITY BUTTON.
-WAIT AND KEEP HOLDING UTILITY BUTTON
-AFTER 10 TO 15 SECOND, TROUBLERESET OPTION WILL APPEAR ON SCREEN, TOUCH IT AND SWITCH OFF.
-NOW ON NORMAL WAYS.
if not ok, then check the panel connection.
- after switching off and on, wait and observe if it display KONICA MINOLTA SCREEN OR Hour Glass symbol.
and let me know for further diagnostic.
Aug 01, 2017 | Konica Minolta Office Equipment & Supplies
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
Dialta di2510 not initializing
Unplug it from the wall, wait a while and plug it back in. If still not booting, Probably needs to have the firmware reloaded,or all the dimms (memory chips) need to be reseated, or the main board has failed. If you are not a tech, probably should call one.
Sep 02, 2014 | Konica Minolta Dialta Di2010 2510 Toner 2...
Recent Driver Answer
kmbs.konicaminolta.us
In the top right corner you will find the downloads link. You will find all available drivers. The C350 is a older model and there my not be drivers available for newer version computers.
Apr 10, 2014 | Minolta C350 Printer
Konica minolta size media error
i have a bizhub C350 and has this error code coming once power ON the error code C-12CC..please if any one has faced the problem i will appreciate your help....
Aug 14, 2012 | Konica Minolta magicolor 2490MF Laser...
Replacing cartridge, can't get past "please wait" message
I had exactly the same problem. Called Konica Minolta, and the best they could offer was 'Power down and then back up again". I did this but still had the same "please wait" that didn't go away. Then I powered down, unplugged the power cord, left a few minutes, then plugged in and powered up again. This time the printer went through a lengthy and noisy startup process, even printing out a status page. I then tried again, and this time immediately afte the "please wait" I got the "open door" as expected, and was able to replace the toner successfully.
I suspect though that you are right, and that the correct cartridge does get positioned automatically, and the "open door" message is not necessary. It would be nice if someone could confirm though.
Apr 10, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Sansa seems to be frozen at startup
is my sansa broke or wat. when i plug the usb cord in the sansa comes on and wen i take it out it goes off , but the screen don't come on......i suffered the problem of wen the screen do come on it stops at the sansa rhapsody part then start over back to the big sansa screen then sansa rhapsody..........someone please help!!!!!!!!!!!!!!!!!!!!!!!
Sep 11, 2007 | SanDisk Sansa e250 MP3 Player
43 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
