Onida black 21 high voltage at power supply around 150v
SOURCE: I have a Onida 21" TV BLack model No. Co21BLFT which does not work and ask for 'enter pass word' Can you help me
Posted on May 05, 2009
bhatgiri73
  • 106 Answers
SOURCE: Due to high voltage my Onida Television got
the power supply filter condensor got leaky in ur tv,,,,,
well it will cost 80 rs... the picture will wave ,, call a tech person to change it. value of condensor 150mfd 450v
Posted on Mar 23, 2010
  • 901 Answers
SOURCE: i have onida t v 21
Looks to be power supply problem. contact authorised service center for economical repairs.
Posted on Apr 29, 2010
caroldon
  • 17130 Answers
SOURCE: my onida 21" black color
Possible there is a fault in soldering. Poor joints in the CRT base circuit of the CRT tube will result in poor connection after some use due to the fact the heating and cooling will detach off the leads. So use a good soldering iron to touch up all the points in your main board and the CRT board and it must work provided your tube is not faulty.
Posted on Feb 07, 2011
SD Tech
  • 14553 Answers
SOURCE: i wish to know the input voltage given to Onida 32 Xaria board
Only the correct replacement board should be installed--another even if similar looking will not work.
Posted on May 27, 2012
Onida tv CO21BLKTAG
Check all the components at the main power regulator section. The voltage output from it should not raise more than 109VDC.
Sep 09, 2013 | Televison & Video
Onida black 21 crt tv fault finding
There is a power ON signal failure from the main system control IC. Check the standby supply voltage for any short or absence. [5VDC]
Jul 02, 2013 | Televison & Video
I have onida t v 21
Apr 29, 2010 | Televison & Video
How to get LOT identification number for ONIDA black 300 21 inch TV
BSC25-NO347 E1MWFL21017 , i have onida black 300 21" tv - in that LOT no is given as shown above - iam babu , computer hardware engineer, from bangalore,9986222774, - i have replaced LOT in my tv - please cal me immediately - i also need very big help from you
Mar 30, 2010 | Televison & Video
Mar 23, 2010 | Televison & Video
May 03, 2009 | Televison & Video
When we print manually the whole page comes out completly black.
edithvenzor:
Try replacing the toner cartridge first, then proceed with the other items.
Thank you and let me know what happens:
Binary Bob
Problem
Cause
Solution
How common*
Comments
BLACK PAGES
DC Controller PCA is defective. If the DC Controller turns on the laser beam continuously,
the entire surface of the Photosensitive drum is neutralized causing a completely black page
Replace the DC Controller PCA
10
BLACK PAGES
Defective toner cartridge
Replace the toner cartridge
9
BLACK PAGES
High voltage contact springs are dirty or defective. The high voltage contacts are mounted on
the High Voltage Power Supply PCA and protrude into the toner cartridge cavity
Inspect and clean the high voltage contacts. If damaged, replace the High Voltage Power Supply PCA.
BLACK PAGES
High voltage power supply circuit is defective (not supplying the correct negative voltage)
Replace the High Voltage Power Supply PCA
10
some printers have the high voltage power supply on the DC controller.
BLACK PAGES
Laser/Scanner Assembly is faulty (turning laser on continuously)
Replace the Laser/Scanner Assembly
5
BLACK PAGES
Light is leaking into the printer
Make sure that all covers are in place
possible, but not likely
Nov 30, 2008 | Office Equipment & Supplies
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
